Question about Boating
WATER PUMP IMPELLER CHANGE I HAVE A 1998 NISSAN OUTBOARD 3.5 HP I NEED TO CHANGE
WHAT TO REMOVE LOWER UNIT
  • 508 Answers
SOURCE: how to remove shift rod linkage to pull lower unit
goto local library get book on unit!!! :)
Posted on Jul 07, 2009
  • 677 Answers
SOURCE: outboard motor overheating
Mate.The powerhead(engine block) is clogged.Don,t run it anymore untill its cleaned out or the motor will cook.Take the heads off 1st and see whats in the water jackets.It will probably be blocked.A build up of white 'gunk' is the main indicator.If thats the case,a complete cleanout is needed.Hope this helps
Posted on Jul 27, 2009
  • 677 Answers
SOURCE: replace water pump impellor 15hp yamaha outboard
Put the motor in neutral.On the leg of the motor there is a little side cover plate.Remove.Undo the bolts.This is the gear change linkage.At the cavitation plate,there is 4 bolts.Remove.If the lower housing does not drop,give it a soft whack with a soft hammer.When dropped,you will see the prop shaft and the gear linkage.Lower it all the way out.Its easy to work on if you put the lower skeg in a vice.Take the water pump apart BUT!!! have a look at which way the impellar blades are pointed.Grease the new impellar as you put it back in and turn it at the same time to get the nodes in properly.Heaps of grease to protect all the bolts.Makes it easier next time.Hope this helps
Posted on Nov 16, 2009
Testimonial: "cheers much appreciated "
  • 677 Answers
SOURCE: I have 1987 Johnson 20 hp outboard motor and need
The g/box in your motor holds about 1/2 litre of oil.It comes in usually 1 litre bottles.Squeeze it in the bottom hole with the spout fitted to the bottle untill it comes out the upper hole and then quickly put the screw plugs back in.Hope this helps
Posted on Dec 03, 2009
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Posted on Jan 13, 2010
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
How to remove lower unit from leg of 7hp. eska sears outboar
Don't know if this will help, but there are some educational videos on YouTube:
https://www.youtube.com/watch?v=HRpfaOiXxWo
I hope this helps you out!
Feb 12, 2017 | Sears Garden
Removing the lower unit on a 1992 Evinrude short shaft 50 hp
Under Lower Carburetor is a Bolt Going Through The Shift Rod Remove This Bolt--Then Undo All Bolts Holding The Lower Unit--The Lower Unit will Then Come Out Don't Turn The Shift Shaft As It Is Threaded And Will Change The Set Length,If You Do Have To Remove It Then Crew It Fully In Counting The No Of Turns So That You Can Set It Back To The Original Position
Good Luck
Mar 23, 2013 | Boating
I cant find the blower motor
If you mean the climate control blower motor, it's usually under the dash on the passenger side on Hondas.
1990-93 Accord
  1. Disconnect the negative battery cable. If so equipped, disable the Supplemental Restraint System (SRS).
  2. Remove the glove box.
  3. Remove the glove box frame (lower support) Fig. 2: Remove the glove box and frame 86806004.gif
  4. If not equipped with air conditioning:
    1. Remove the three screws and remove the heater duct.
    2. Remove the blower mounting nuts. Unplug the wiring from the blower motor, resistor and recirculation control motor, then remove the blower assembly.
  5. If equipped with air conditioning:
    1. Lift the carpet in the passenger compartment. Remove the side cover (kick panel).
    2. Remove the control unit bracket nuts; unplug the five connectors and remove the control unit bracket.
    3. Remove the retaining band, then remove the blower lower covers. Do not break the tabs on the lower covers.
    4. Remove the retaining nuts and remove the blower assembly. Fig. 3: Air conditioned models require the removal of the control unit. Handle it carefully 86806005.gif
      Fig. 4: Remove the lower covers from the blower unit 86806006.gif
      To install:
  6. Install the blower unit and tighten the retaining nuts.
  7. On air conditioned vehicles:
    1. Install the lower covers and the retaining band.
    2. Install the control unit bracket and carefully engage the wiring connectors to their proper location.
    3. Install the kick panel and reposition the carpet.
  8. Connect the wiring to the blower assembly. For non-air conditioned vehicles, install the air duct and tighten the screws.
  9. Install the glove box frame and install the glove box. Note that some of trim on the frame is held with 2-sided tape; replace the tape when reassembling as necessary.
  10. If applicable, enable the SRS.
  11. Connect the negative battery cable.
1988-91 Prelude
  2. Remove the glove box and frame (lower support).
  3. Remove the 4 screws and remove the heater duct. Fig. 5: The glove box and frame are secured by several small screws 86806007.gif
  4. Remove the 3 mounting bolts.
  5. Unplug the wiring connectors from the blower motor, resistor and recirculation controller. Remove the blower motor assembly.
  6. Reinstall in reverse order. Make certain the blower mating surfaces are tightly sealed.
Jan 08, 2011 | 1992 Honda Accord
How do I check the oil level in the lower unit of a 70 hp Johnson outboard?
remove the bottom drain screw first then place a tube of the proper lower unit oil in it. then remove the top screw and gently squeeze the tube of oil and when full it will slowly come out the top drain hole. when it does replace the lower plug first then the top plug second. make sure the seals are in good shape and plan on changing the oil in the lower unit yearly for proper maintainence. make sure you buy oil designed for your particular type of motor. good luck.
May 29, 2010 | Boating
How to remove the complete roof top ac unit , 1980 GMC Tioga RV
Shut off Any AC power (hydro) to it, remove ceiling assy (inside part) and you'll see 4 bolts going up through lower assy, and into base of upper assy (roof unit) . Remove those 4 bolts and any wiring harness connected from lower to upper unit. Lift it off. If your just replacing the upper assy, leave hydro wires hooked up to lower assy , and let it hang, while you clean surface on roof for new install. Re-install 4 bolts and tighten equally until gasket is approx 1/2 thickness it was before tightening. Re-install wiring harness plug in to lower unit etc. If not replacing, but removing entire assy (upper and lower) be sure to Marette and tape hydro wires as well as any 12 volt wires, and tuck away safely. Install a vent on current opening , or whatever you choose.
Sep 28, 2009 | Dometic Rooftop RV Air Conditioner
Replace drum cleaning blade
take the toner hopper off take dev unit out lower handle on umber one unit remove screw in drum pin remove primary charge assy remove screw lower right of drum frame remove screw upper left frame un plug connectors unit slides out
Oct 31, 2008 | Canon NP 6545 Copier
Boating Logo
147 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
