Question about 2wire PC Port Phoneline HomePNA 10Mbps USB Adapter
HP laptop cant connect i internet using vista
I just got a new HP laptop, its an HP G60-125NR. My sister also just got the same exact laptop. Her computer can connect to our router and the internet no problem, but mine wont. I just get the message "Windows cannot connect to 2WIRE...". I have a NetGear router connected to an AT&T 2WIRE modem, and I'm using vista home premium
I just called HP and they talked me through it
Posted on Jan 04, 2009
Just purchased an emachine laptop, have tried to access the internet wireless and the laptop is requesting a network key, I have the key and have also taken the laptop to my sisters home to access wireless...
Go to your router and turn it off for 15 seconds. Then get a toothpick and push in the reset button in when you plug it back in. Do not do this until the router is working again and fully lit. Then push the reset button.
Now go to where it says connections you should have your access name click connect and put in the password you know will connect you. If this will not connect then it is a software issue and not the hardware you will have to delete and start over reconfiguring a new wireless connection. It is not the product it is the configuration that is the issue.
Something between you Internet Provider and the password may need to be reset then you will have to go to this link. 192.168.1.1 this will take you to the router page. Look for wireless connection then remove the password and create a new one. Save on page and go. Now go and re-log in again using the new password. Try this out see what happens.
Jan 22, 2011 | E-Machines eMachines Desktop PC
Im having trouble connecting to xbox live. Everything works fine when my sister's are NOT on their laptops. However, as soon as they start browsing the internet, I experience lag (although my connection...
Sounds like there is an issue with bandwidth on your internet connection. Either you have a lot of sisters using your bandwidth, your ADSL connection is on the slow side, or both. Your Xbox isn't getting the bandwidth it requires to operate smoothly.
There are ways to configure your router to allocate bandwidth to connected devices in proportions that you set. You could have 70% and they have 30%.
Also check that they're not watching streaming video or downloading stuff at the same time you play. Alternatively just hide their laptops. :)
Mar 03, 2010 | Belkin F5D8236-4 Router
New laptop computer with windows 7 - unable to connect. all other laptops/computers connecting fine. Can see the SSID in the list but won't connect.
Hi, Check the following cause for your problem.
1. Check whether your network adapter is installed.
2. Check the secrete password is same for your new laptop , if not apply the secrete password fixed by you to other systems to connect the network ( By default SSID is the password fixed in most factory)
3. Check whether you have addressed the router in the web address page, if not consult your router documentation to find the exact router model address and when you connect with the router home page it will ask you for the user name and the password you can find it in the router documentation
From your question these are the possibilities, still facing problem kindly comment with more details of your exact problem..
Thank you
Jan 25, 2010 | D-Link DIR-625 (790069292637) Wireless...
Im staying with my sister for a couple of weeks and was wondering how to set up my hp pavilion laptop to wirelessly access her router?
You will need to scan for available networks and located her router by the SSID printed on the bottom should be either a WEP or WPA-PSK encryption key this is required to connect, this is not needed if you want to connect using a ethernet patch cable.
It is a good idea to use your laptops wireless network cards own connection software to avoid disconnect problems I suggest that you disable windows own able WZCSVC to avoid any disconnect problems.
Dec 04, 2009 | HP Pavilion dv9000z Notebook
Dell xp wont connect to the internet thru this router.
I think that the settings in your sister laptop is the problem. See if it is using static ip ad and if it is using it, try to use dynamic to get an ip to the router.
Apr 14, 2009 | Computers & Internet
My sister's computer won't connect to our wireless router
go to start>run and type in cmd
then type in ipconfig /release
Once you have done that see if it will allow you to connect to the connection you would like.
Feb 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I set up my router, which says it's connected to my computer. I have also set up my wireless on my laptop. It keeps reading that I'm not connected to the internet. The wireless adapter has worked on my...
router internet connection takes more time to connect to the internet,sometimes it took 10mins before it got the connection. make sure 1rst if the laptop was connected to router as LAN
then goto controlpanel ,then networkconnection and rightclick Local area connection,click repair
Sep 14, 2008 | Computers & Internet
2wire PC Port Phoneline HomePNA 10Mbps USB Adapter Logo
605 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
