Question about Epson Stylus Nx415 Color Inkjet Printer 34ppm Pcs Photo Black C11CA44231 Eps
Epson nx415
When going to print from Windows xp or Vista or a image editing program I could go to Epson's Printing Preferences and click a drop down menu to choose "Exact size" to print- the size of the image for whatever photo frame I was putting the picture in. Today I scanned a photo(8x10), resized the image file in Photo Explosion to 6.5X10 but now the Epson printer does not show the drop down menu with exact size on it. Epson now shows on the Layout page a drop down menu with auto expand and retain size- I click the retain size but it does not retain the size- it expands to full page size. Any ideas?
2 Suggested Answers
Inky
  • 691 Answers
SOURCE: Epson R300 printing only in top left corner of page
Change the paper settings in the driver when you go to print. If you have it set to 10x15 it will only print a 10x15 patch in the corner.
Go to START, PRINTERS AND FAXES then right click on R300 and select PROPERTIES. Click PRINTING PREFERENCES and set the correct paper properties. Click OK all the way to desk top and the settings will be saved.
On the printer panel press ADVANCED, scroll down 3 times to PAPER SIZE and press OK. Select A4 and press OK.
Posted on Dec 02, 2007
I need the printer program to printed
get all the software for this product from here :
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=128287&prodoid=63083741&infoType=Downloads&platform=Windows
Mar 03, 2011 | Epson NX415 All-In-One Printer
WHEN PRINTING PHOTOS LINES APPEAR
Hi, It is unfortunate that you are having this difficulty with your printer. One of the best solution that we can give to you is run a series of head cleaning. Please try the following steps below to clean the print head in most effective way:
1) Make sure the printer is turned on but not printing. Make sure there are no error lights or messages appearing in the LCD.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink, your printer will require service.
Tirzo
Jun 13, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Lost my manuel !
1. Make sure the printer is turned on but not printing.
2. Load letter size paper.
3. Click on START.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4. Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5. Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6. When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7. If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8. If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9. Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Pls dont forget to rate solution, thanks!!
May 02, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Printing Problems with Photos
you can try this one just to isolate if it is an issue with the software or with the hardware itself
it is just for windows users only
3) Click on START.
Mar 07, 2008 | Epson Stylus Photo R220 InkJet Printer
Problem printing
3) Click on START.
Dec 29, 2007 | Epson STYLUS CX3900 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
Please confirm that the head cleanings were done using the most effective method listed below.
3) Click on START.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Printing Problems
In Windows 98/ME/2000:
1. Go to START, SETTINGS, PRINTERS.
2. RIGHT CLICK on your Epson printer name; left click on PROPERTIES.(PRINTING PREFERENCES in Windows 2000).
3. Go to the MAIN tab.
4. Place a check beside BLACK INK ONLY.
5. Click APPLY then OK.
In Windows XP:
1. Go to START, CONTROL PANEL, PRINTERS AND OTHER HARDWARE or PRINTERS AND FAXES. (Select VIEW INSTALLED PRINTERS under PRINTER TASKS if no printers appear).
2. RIGHT CLICK on your Epson printer name; left click PRINTING PREFERENCES.
3. On the MAIN tab.
5. Click OK.
Remember to repeat these instructions and remove the check from BLACK INK ONLY when printing photos or color images.
Dec 28, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Dark red prints with lines throught the picture
3. Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. Right click your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then right click the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL, HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. Right click on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
5. Follow the instructions on the screen to clean the print head. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
Dec 23, 2007 | Epson Stylus Photo R320 InkJet Printer
Printer doesn´t print using the mangenta ink cartridge
try this :
3. Click on START.
Dec 20, 2007 | Epson Stylus C63 InkJet Printer
Printing in blue only
try this:
1) Make sure the printer is turned on but not printing. Ensure there are no error lights or messages appearing in the LCD.
3) Click on START.
Dec 12, 2007 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus Nx415 Color Inkjet Printer 34ppm Pcs Photo Black C11CA44231 Eps Logo
53 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
