Question about Toshiba E-studio 655 Copier
Fixing error code c449 toshiba e-studio 655 copier
My toshiba e-studio 655 is displaying an error code c449 and ls failing to do anything,How do l fix it.
5 Suggested Answers
  • 990 Answers
SOURCE: what is error code f105 for an toshiba e-studio 520 copier?
Dear sir; There have your solution, try to turn power off and on, if can not reset , you have to replace HARD DRIVE, f105 is hard drive problem. good luck! if you need more help please let me know, HAVE A HAPPY HOLIDAY !!!
Posted on Dec 20, 2008
  • 990 Answers
SOURCE: error code c440
Hello sir; C440in this machine,it means fuser unit problem, but it can be reset the procedure as follow;
1, hold down "0" and "8" keys while turn on the power.
2, enter 400 press start.
3, enter 0 press set or enter.
Posted on Jan 07, 2009
  • 10 Answers
SOURCE: Error code H4-00 and machine is "locked-up" in scan mode
go into service mode 05 400 set to "0" switch copier off than on
Posted on May 19, 2009
  • 643 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
How to solve e studio 2309a printer error c449
That error code has to do with heater problems, or voltage on the heater. I don't think it's fixable without a tech.
Jul 20, 2017 | PRINTER Office Equipment & Supplies
Toshiba Model e studio 2303 A.Trouble showing Error Toner.Need a solution.
Technology Time: Toshiba Error codes
www.mytechtime.com/2011/04/toshiba-errors.html
Toshiba E-Studio machines do not display service code automatically. ... All codes, except fuser errors are reset by turning the machine off and back on again. ... holding down "0" and 8" keys, enter 251 to set PM limit, and 252 to see the number of copies that have been run since the last PM. ...Toner transport motor problem.
Mar 21, 2017 | Toshiba Office Equipment & Supplies
My toshiba studio 181 displayd tool sign its blink . is this asking for maintanance ? icant do anything ts cannot coppying . what should ido? please help me out .
What is the error codes is displayed with "7-segment LED" while pressing the [CLEAR/ STOP] button and the digital key [8] simultaneously
Sep 24, 2016 | Toshiba e-Studio 181 Digital Copier
C449 error code in toshiba e studio 2540c
error C 449 Heater lamp abnormality after abnormality judgment (temperature abnormality at high temperature)
first of all just reset error with simulation may just malfunction error procedure for rest error for heater related.
turn copier off
hold down 0 & 8 while turning it on power switch
then press digit numbers 4 0 0 then press start key
then 0 key and set
Jul 26, 2014 | Toshiba e-Studio 2540C Multifunction Color...
Fixing code error e774
i think it is RADF problem
Jul 16, 2014 | Toshiba E-studio 655 Copier
''toshiba e-studio 720 error code c473
This is an overvoltage error....Really need a tech to fix this...could be bad wall voltage....or the thermostat in the IH unit...or the fuse in the IH unit...or the logic board....
Oct 31, 2009 | Toshiba E-STUDIO 720 Copier
Wrench - Toshiba Studio E-28 error code C82.
could be a sensor blocked and the machine thinks there is paper present follow the small holes on the tray to locate sesor also keep in mind u can unplug the sorter and ur copier will work
Mar 20, 2009 | Toshiba e-STUDIO 282 Black and White...
F120 fault on Toshiba estudio 232
HOW TO RESET ERROR CODE F-120 IN TOSHIBA STUDIO 232
Jul 09, 2008 | Toshiba e-Studio 232 Black and White...
Toshiba E-Studio 160
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba E-studio 655 Copier Logo
724 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
