Question about Riso Office Equipment & Supplies
Riso 220UI says to check settings
I am trying to make a master and it says to check setting
3 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Riso RZ 220UI
1-need to find out if image is on the drum, make a copy and stop it open and look is there toner on the drum itself? yes then the problem is with the Seperation
2-No, then the problem is with the Transfer
Posted on Sep 05, 2008
  • 242 Answers
SOURCE: estou com problema na minha
TEST MODE 0888 START .
Posted on Dec 01, 2010
Riso RZ 220UI shows horizontal bars
you have to change the whole unit of your led light. the bar with all those led lights are attached or soldered. hope to be of help.
Jan 03, 2014 | Riso Office Equipment & Supplies
Error code A-01 -201
Which model of Risograph?
Error type A01: Master mis-feedError point 201: Master-positioning sensor does not go to ON even after the write pulse motor is activated durcing the paster-positioning, master cut, or master-loading operation.
Try this:1) Pull out mastermaking unit and rewind master roll, then re-set master in place.2) Check write pulse motor and its gear
Sep 18, 2012 | Riso Office Equipment & Supplies
How to find a riso 220ui on network or what is the ip address associated with a riso or how can the address be determined?
go to driver downloads at riso.com and download the riso admin tool. much easier than the web interface. test mode/print 95 if you need a config sheet with ip, for example if your subnet mask still isnt letting you see it.
Jan 08, 2012 | Riso RZ220 Duplicator
My riso is showing A-17 & -209
A17-209 means: Cutter HP switch is OFF when master-making starts or when master material is set in the master making unit.
Mar 24, 2011 | Riso RZ220 Duplicator
The riso rz 390 ui does not print the scans complete
Please check the setting of paper size. It may be set to a smaller format and therefore the outer original area is not transferred to the master.
If you meant someting other than please explain ...
Feb 03, 2011 | Riso RZ390 Duplicator
Riso in Jam and on the creen say: Check setting and red light on number 4. When I press * key it say -227 and P-08. I don't know what to do please help. Thanks
I found an error D08-227. Have you scrambled 'D' and 'P'?
Error type D08: Master making unit not set Error point 227: Master making unit lock sensor is still OFF when the master making unit is set in position (timeout: 5 seconds).
Hint: Check mentioned sensor.
In addition:Error type P08: Communication error with CI
Aug 10, 2010 | Riso RZ220 Duplicator
Riso RZ 220UI
Sep 05, 2008 | Riso RZ220 Duplicator
104 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
