Question about Motorola Mobility StarTAC ST7868W Cellular Phone
How do you disassemble a StarTac St 7868w
I know what to do once I get the case off the guts of my StarTac ST7868W, I only need to know how to get the thing opened up without breaking the housing.
  • Anonymous Feb 06, 2009
    Me too. Need to remove case to repair with my spare
  • Ed Every Mar 11, 2009
    Same thing. Have spare, need to open the housings.
Motorola boom driver
First check if it's a Compatible one. Read user's manual for compatibility of your Boom Headset. If it's compatible, you should once again try to install it, but first uninstall partially installed or erratic installations previously made, then re install it. Before doing so, take Backup of your Phone.
Apr 28, 2014 | Motorola Mobility StarTac Boom Headset
Tip
DIY Replacement Ignition KeySubject: DIY Replacement Ignition Key Title: What to...
Title: What to do if you need a replacement ignition key
Overview:
There are times where you may need a replacement key. This can be the cause of a lost key, a key going bad, upgrading from the non all-in-one key to the all-in-one key.
Please keep in mind that if all keys are lost, there is NO WAY to program a new key to you car and a replacement TWICE module will have to be found with a key, either new (costly) or used and be married to the car via the dealer.
Symptoms:
Need a key, key is giving intermittent "bad key" messages and will not start the car, etc.
Experience Level:
Easy
Tools Needed:
Probably none, or a small tool to take the door off of a key via the hole in the side for the all-in-one key.
Time Needed:
Not much.
Parts Needed:
Key Blank from Dealer about $40 This is cut to your car.
Key Top from Dealer about $40 This is the "key guts"
all-in-one guts from Dealer about $90
all-in-one guts from ebay about $30-$60
key door from dealer for all-in-one key about $15
Procedure:
There are a few cases that can be covered
Case 1: Non All-in-one key replaced by non All-In-One key.
Subcase A: Have a non all-in-one key that is going bad
Solution: The dealer will have a replacement top for the key. Get the top, replace the top of the key and have it reprogrammed for the car. Total cost about $40 + $30.
Subcase B: Replace with all-in-one key because they are neato and / or the other key is lost.
Solution: Order the "Key Blank" from dealer and obtain the guts for the all in one key from ebay or the dealer. Have keys programmed by dealer. Total cost about $35 + $30 + guts cost.
Case 2: All-in-one key replaced by All-In-One key.
Subcase A: Have key but is not working.
Solution: Get guts and have it programmed. Cost about $30 + guts cost.
Subcase B: Lost key, need a new key
Solution: Get Key Blank and guts and have it programmed. Cost about
Outcome:
Very nice. Replacing the non all-in-one with the all-in-one dramatically increased the range of the remote. over the banana style remote.
Notes:
- Replace the battery in the guts if you get them off of ebay.
- You have to have all keys and remotes to dealer for programming.
- The guts for the non all-in-one key do not have the remote guts
- The guts for the all-in-one key have the security and remote in one
- The key shaft from the ebay all-in-one key can be discarded
on Jan 17, 2010 | Saab 9 5 Cars & Trucks
How to replace battery in braun 5720
Braun Select Models Electric Shaver Disassembly Tutorial
1. Remove two screws on the bottom, where the power plugs in. Need to remove two ribber plugs first.
2. Pull from shaver head and remove shaver "guts" from case. (It will be hard to remove as it is encased in rubber to make it waterproof, but keep wiggling and tugging)
3. Remove old batteries and replace with new ones.
4. Re-assembly is reverse
Nov 08, 2013 | Braun 360° Complete 8985 Electric Shaver
I have bought a motorola startac M501 on ebay the problem is it comes up with 'enter phone unlock code' when i turn it on..I dont know the code..how do i find this ir is there a way of unlocking it?
look up google....nam programing for motorola startac.....
its something like fcn,fcn,0000000000000...then rcl it opens
frequencies and security codes....mobile info number of the phone etc......scroll down to security code(3digit)punch in the new one..there is one more security code i think....do the same......it will not take (000)1-9 only....
eaaassssyyyyyyy.
Feb 01, 2011 | Cell Phones
Old pre 911 ST7868W phone died purchase used exact replacement model and want to know how to activate relp?
if you have a spare unit,don't bother to take apart the old broken one. Contact your service provider's Tech Support and tell them you wish to replace your broken Startac with another unit and give them the replacement units ESN. They can add the new one to your account,it will replace the broken unit. All ESN's are unique. You can REPLACE one with another,you can't take parts out to (legally) substitute one ESN for another.
May 19, 2009 | Motorola Mobility StarTAC ST7868W Cellular...
Motorola startac st7868w only transmits with earbud & ext mic -
dear vjmusa ,
step 1 : open ur cell phone .
step 2 : check clearly the pcb board either any damage or not
step 3 : check the components of the pcb.
step 4 : most probly the small tiny capacitor might have broken .
step 5 : check with multimeter so that u can recognize the connectivity of the circuit board
check with the buzzer .. might have loose contact with the surface of pcb
or just do small scratches on the pcb , where the buzzer touches ..
so that it will get the connectivity and works fine ..
Jan 02, 2009 | Motorola Mobility StarTAC ST7868W Cellular...
B&k amp st 2140
There are a few fuses inside the amplifier. The case lid will come off pretty easily once you remove all the screws. You can visually inspect fuses looking for the blown one (filament will be broken), or use a multimeter for ceramic fuses. However, the fuses in my B&K ST-1400 do have transparent cases. If once you replace the fuse, it blows again, then that would suggest an underlying problem.,
Cheers Jeremyt
Jun 16, 2008 | B&K AV 125.7 7-Channel Amplifier
Motorola Mobility StarTAC ST7868W Cellular Phone Logo
274 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
