Question about Sony Walkman NW-A808 MP3 Player
Walkman sony r 33021 can we replace battery
Once charged it will not last long time
  • 76 Answers
SOURCE: sony walkman 4GB NO RESPOND/FROZE with screen saying"WALKMAN"
there is a reset button hold it down for 10-30 seconds....prolly what you are doing is not allowing the comp to disconnect thru icon 1st before you dissconnect the mp3 player.....btw if you do this to often the computer can start acting up
Posted on Dec 02, 2008
SOURCE: My Walkman won't charge
What I did when I got this error was to push the reset button on the bottom of the player itself... Mine rebooted and took a charge from the computer. Hope this all works for you.
Posted on Jan 01, 2009
Press the reset button and plug it into the charger afterward. The music won't be lost trust me. It just resets the time settings, as well as the music equalizer.
Posted on Jan 10, 2009
SOURCE: The battery seems to be dead, and it won't recharge
yaeh....it is replaceable ....you can get it done at your nearest sony service center....
good luck...
dont forget to rate me.....
Posted on Apr 15, 2010
SOURCE: my sony walkman nwz-e436f won't charge on my
**** your wife...
Posted on Apr 23, 2010
My kindle fire does not keep its charge. I can use it one time and during the ap it goes dead
If you charge the device fully, meaning 100%, and while using it with a simple app it doesn't last 2 hrs. then you need to replace the battery. Next time it goes dead, don't turn it on, instead plug the charger and let it charge to 100% while the device is off. Once is fully charge, use it as you would normally do. But still,it needs a new battery.
Apr 30, 2015 | Tablets & eReaders
I have a portable DVD player,Yukai 700 I have charged the battery several times , but it only lasts five minutes in its dead. Once I charged it for three hours done for seven hours in the last time 24...
This means that the battery is unable to hold a charge any longer. THe only option in this case is to replace the rechargeable battery for your Yukai 700. A battery has a charge life meaning you can only charge it for a set number of times. It seems that it has already exceeded that.
Aug 14, 2008 | Mustek Televison & Video
Tip
Mobile phone battery not holding charge and going flat to quick
hi, now this is a very common problem the only thing you can try is to let the battery go totally flat and keep switching it on untill the phone wont even light up.
Then what you need to do is give it a full charge for at least 8 hours this may lengthen the time your battery takes to go flat.
Now what the shop should have told you and didnt and what they should tell you in the owner's manual and dont is that once a month you are supposed to let the battery go totally flat and then do full recharge.
Doing this will ensure you get maximum time out of the battery and it makes the battery last at lot longer before you need to replace the battery.
If after doing this your battery only last an hour or two then the chances are the battery needs replacing so if you do this just remember to let it go flat at least once a month as the battery never does a full charge due to the fact that the battery never goes totally flat so this then causes bad cells in the battery so follow those rules and your battery will last longer than normal
on Dec 03, 2009 | Cell Phones
Does wireless chargers lasts for longer time?
It is easy to use wireless charging pad than wireless charger.It provides extra protection to your phone as well while charging the phone middle of nowhere.It turns off automatically once your phone is 100% charged.It is of QI standard and is compatible with nexus 5 as well. You can plug it in when power is off or you are traveling.It is so easy and convenient.And about you asking if you could use it properly it will last for longer term.And here I give you a link of some charging pads and wireless charger.Those are some longer lasting products.
http://www.amazon.com/dp/B00I03LLUM/
Feb 11, 2014 | KONNET Technology KONNET PowerV Duo Wii...
Battery will not charge
Not much to go on with your description ;-]
Generally if a rechargeable battery will not charge or the charge does not last long you need to replace it. This is true for laptops or camera batteries and anything else. Very rarely is it a problem with the charging circuit.
Rechargeable batteries like Lithium Ions are good for about 500 charge cycles. If you dischagre it to zero all the time or leave it on the charger and never really use the battery you can kill them off quite a bit faster. You can make them last longer by never using more than a half charge. By charging only when needed, and by discharging it to zero about once a month. Then you can get 2-3 times the use out of the battery.
Sep 02, 2011 | Computers & Internet
Samsung d900 . battery run on half an hour during call and if it is sleep mode then till 4 hours only
Please check the adapter voltage and the charging of the battery when placed for full charging. Once the charging has confirmed to be full remove and try once again to see if the phone indicates. Now clean the terminals and connect. If the battery does not last , it is possible that it must be replaced. Please confirm with a battery from a friend and buy ONLY the original with warranty.
Apr 26, 2011 | Samsung SGH-D900 Cellular Phone
My batteries keep going flat
Digital cameras EAT batteries. Buy only the best. If you don't mind paying a lot, use lithium batteries. They last longer but, the price doesn't actually make them a savings. They are only more convenient. If you have rechargeable, they lose their ability to accept a full charge after a while. Once they've been charged about 400 times, their life gets shorter each time you use them.
Jan 06, 2010 | Pentax Optio 430RS Digital Camera
Toshiba Camileo h20 battery problem Toshiba Camileo H20 camcorder bought in July O9 Worked fine on 2 week holiday and have recharged the battery 2 or 3 times since. Latterly battery charge didn't last very...
It's eight years old now, and if as you say it has had intermittent use, then the battery will probably have died unless charged at last once a month.
Mar 27, 2017 | Toshiba Video Cameras
Acer 5315 Battery cHarging Problems
All rechargeable batteries have a limited life, and as they age their charge capacity reduces over time and you get shorter and shorter time between charges.
Recharage batteries have a finite number of charge and discharge cycles and batteries over 2 years old are considered nearly worn out. Worn out batteries won't charge up at all.
Jun 30, 2009 | Acer Aspire 5315 Notebook
Charge
Charging the Player
The player needs to be charged before it can be used and every time
the battery gets low. It takes approximately 2.5 hours to charge the
Player. Once fully charged, the Player lasts approximately 8 hours.
To charge the Player:
Remove the USB cover on the Player.
Connect the Player to the PC using the Flash Plug.
The Player will begin charging. The battery indicator should begin
to flash, alternating red and green.
Once the battery is fully charged, the indicator light will stay red.
Note: If this is the first time the Player is connected, wait until
Windows detects the Player and follow the prompts to install it.
Mar 15, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Sony Walkman  NW-A808 MP3 Player Logo
147 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
