Question about Refrigerators
Pelonis water dispenser YLRSO.7-5V/C-15 WATER DISPENSER
WHEN i INSTALL THE INVERTED WATER BOTTLE IT OVERFLOWS
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
SOURCE: Sunbeam water dispenser Model YLR2-5-90HZ3 Ser# 2003
water leak from inside the refrigerator
Posted on Jul 16, 2008
  • 272 Answers
SOURCE: Water dispenser no longer dispenses water. Ice maker still works
Has it stopped completely or just slowed to a trickle. If a trickle you need to replace the filter. If stopped either the feed line to the fridge has been pinched/shut off or the internal line has frozen, or the valve is no longer functional.
Posted on May 25, 2009
  • 123 Answers
SOURCE: as the washer is filling with water, it overflows
hi there......this problem is usually caused by a build up of detergent in the hose leading from the soa disenser into the wash tub....remove the soap dispenser....check for accumulated detergent under the drawer....and in the top of the fill hose....easy removed with a little patience and warm water....
regards Sir Galahad
Posted on Aug 16, 2009
  • 464 Answers
SOURCE: Kitchenaid refrigerator water dispenser not working
you may need to replace the water inlet valve. it is a dual valve, one side for water and one side for ice. part #2304833. see the attached breakdown #10. perhaps this will help.
Posted on Oct 26, 2009
Slow drip from refrigerator water dispenser
Sounds like a defective water control valve W10408180
Change that out and I believe you will be fine. If you have questions please let me know, Thanks Sea Breeze
May 03, 2012 | Whirlpool Refrigerators
On spin the water comes up the dispenser tray and overflows
Pull the dispenser drawer all the way out, there will be a flat part which you push down to slide the drawer out, Then you can get to the inside to give it a clean, next you can remove the top by undoing the 2 screws at the back and sliding it off, you will see the hoses that run to the dispenser and you can clean them with a bottle brush.
Mar 10, 2012 | Washing Machines
Soap dispenser overflows with water
Need to know how old machine is etc. dispenser could be clogged.
May 19, 2010 | Kenmore Elite 45986 Front Load Washer
Detergent dispenser fills with water
the black pipe behind it is blocked turn of power take off lid and youll see a soft pipe going to the tub give a few squuezes and it should clear
May 17, 2010 | Washing Machines
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
After emptying our water dispenser for cleaning,
There should be no crack or pin hole in your water bottle.
Water bottle should be air-tight to make proper pressure inside bottle.
Whenever lose pressure, water overflow with no bubble.
Just replace water bottle with no crack or pin hole.
Good luck.
leey05
Dec 07, 2009 | Hamilton Beach Water Cooler with Storage...
Pelonis Hot & Cold Water Dispenser, water not cold
I too am having just room tempature water coming out of the cold
dispenser and I have had mine for 1 month.........
Nov 03, 2009 | Kitchen Appliances - Others
In the last 2-3 months I have purchased 2 of the Sunbeam Combo Water Dispensers and both of them overflow. After setting the bottle in the ''no spill receptacle'' after awhile they will overflow around the...
I would say that the dispenser is at fault. These water dispensers use gravity to release the water and won't allow overflow. The air pressure in the bottle comes up through the dispenser as water flows out. Your dispenser is not seating against the bottle correctly. Look inside at the gasket material that the top of the bottle rests on when it is in the inverted position. That's where the problem lies. The leak is happening right there where the bottle rests down in the reservoir. Look at that seal, it's damaged. Leaking...
Sep 22, 2009 | Kitchen Appliances - Others
Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
ck inlet just inside door upper left could be blockage in line from dispenser into tub especially if you have been using dry detergent remove detergent drawer and ck for blockage from that end too
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
