Question about General Electric WHDSR209DWW Top Load Washer
GE top load washer only makes a tick, tick noise but won't run a load
Everything is plugged in. Water is on. Washer will not run a cycle, only tick tick tick from the select cycle knob area and it will agitate. It will not fill with water or spin. To get it to run a cycle starting with running water, I must hold the load size/reset knob over on reset. I know this because it was the only way to finish the last load I put in it! I have unplugged it to try to get it to reset, like I've been told to do before. Even left it unplugged all night, still no change. If everything runs when it's in "reset" mode, then it's not a belt, like some have suggested...What would it be?
3 Suggested Answers
  • 289 Answers
SOURCE: My Top Loading GE washer will not agitate
nead the mod#
Posted on Jan 19, 2010
  • 11 Answers
SOURCE: I have a GE whdsr209 washer. Stuck on filling with water.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
Posted on Jul 28, 2010
My GE top loading washer is making a clunking noise during agitation. Everything else okay
The problem may be in your agitator. The spline may be worn out. It is located under the spindle. Are your clothes becoming clean. That noise might be the agitator not fully engaged.
Feb 06, 2013 | GE Washing Machines
Ge washer won't let water spin out
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
If timer makes ticking noise with fill up water without washing what is major concern
No, that is the pressure switch switching from fill cycle to agitate. It should be a fairly load click.
May 06, 2011 | GE WBSR3140DW Top Load Washer
Ge front load washer won't go into rinse cycle.
Check the cold water hose. My brand new machine had this behavior until I discovered a kink in the cold water hose - works great now.
Jun 03, 2009 | GE WSXH208A Front Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
General Electric WHDSR209DWW Top Load Washer Logo
26 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
