Question about Toshiba E-studio 2500 cbc939390, Copier, Multifunction Copier
Resetting the counter on a Toshiba e studio 2500c
Looking to reset the counter, or find a solution to the empty the disposal toner cartridge error that will not clear even after we reset the machine
    New Friend:
I reached the total print counter 109219 and want to re set.
Posted on May 23, 2013
2 Suggested Answers
  • 226 Answers
SOURCE: I am looking for the error codes for Toshiba fax
here is the link for toshiba
http://www.visualhawk.vcc.ro/toshiba_error_codes_en.html
Posted on Jul 21, 2009
Dispose of used toner error.we already clean the toner bag.and also the sensor behind it.and also check the alignment the area.withih the toner.what is the other way to fix this error.or maybe this have...
399 (0)
start 6 (2)
Most commonly the waste toner bottle is located on the front of the toshiba copier, however, on certain models they are located on the back left side of the machine. On the right side of the machine is toner bag filter, which often appears to be the waste toner bag as it possessed waste toner and developer. If you are sure you emptied the proper container, then I suggest resetting the counters in service mode.
The process:
1. Turn machine off, press and hold "0" and "8" simultaneously while you power the machine on, after about 15 seconds the service mode will display, press "399" and then press "0" and then "set."
2. Turn off machine, press and hold "start" "6", then after the service mode loads, press "2", then reset the number to 0 by pressing clear.
3. Reboot machine and see if error clears.
-David.
Oct 31, 2010 | Toshiba Office Equipment & Supplies
Toshiba studio 352 dispose of used toner
The waste toner bottle is located behind the front cover, you should be able to open the cover and remove the clear plastic container. After emptying the container, you need to make sure that the portion of the container that comes in contact with the sensor on the machine side is clear of any toner, as the sensor sends a beam of light through it to determine if the container is full. After doing this, you may need to reset the machine.
-David.
Oct 30, 2010 | Toshiba e-STUDIO 352 Black and White...
Why toner empty error in samsung sf 565p
I have an SF-555P and have installed numerous cartridges. The last one was a Samsung brand and it didn't have the little fuse taped on the top. I never knew what this was fur until I had problems. When I first installed the new cartridge the "Toner Low" display remained lit. I shook the cartridge and it persisted but it printed well. Then about 100 pages later I got the "TONER EMPTY" and the printer stopped. After researching the issue I found that the fuse is actually a reset for the printer counter and when the new cartridge was installed without the fuse, it never reset.
You will need a 5X20 Fast acting fuse, no greater than 315 ma. You can buy a 4 pack from Radio Shack for about $3 (P N 2701046). Install it with a piece of electrical tape in the slot on the toner cartridge and make sure the contacts are exposed. The printer will blow the fuse and reset the counter. Don't use a bigger fuse, a slow-blow or anything that won't burn open quickly or you will be buying a new printer.
Mar 18, 2010 | Samsung SF-565P All-In-One Laser Printer
The error indicator is staying lit constantly on Toshiba e-studio
The drum counter reaches 25000 copies , it's time to change the drum and reset counter .
Enter the reset mode by pressing : # - * - c - * .
then press : 20 - start -01- start - CA - CA .
Hope this will help .
Feb 28, 2010 | Toshiba e-Studio162D Copier
Toshiba E-Studio 3511 Check Color Toner Cartridge
there is a sensor above the coloer developer unit clean it or change the sensor
Sep 30, 2009 | Toshiba E-Studio 3511 Color Copier
Toshiba E-Studio 202L cartridge does not match manufacture
Did you replace the waste (used) toner cartridge or the empty toner cartridge? These copiers have 2 "cartridges" .... one is waste (used) toner, the other is "new" toner for copying / printing etc. Some newer copiers have All in One units....Drum, New Toner, Waste (used) Toner. If you replaced the Waste Toner container (or dumped it) that should reset the code or error message.
Jun 23, 2009 | Toshiba e-Studio 202L Copier
Empty used toner not clearing
you have to go into service mode and reset counter.in your manuel
Dec 23, 2008 | Toshiba e-Studio 350 Copier
Toner empty display
If you are using the Toshiba supplied toner cartridge then properly changing the cartridge should automatically cause the unit to reset. If not, try turning the copier off, unplug it from the wall for 3 minutes then plug it back in and turn it on.
Dec 22, 2008 | Toshiba E-Studio 160 All-In-One Laser...
Toshiba E-studio 2500 cbc939390, Copier, Multifunction Copier Logo
290 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
