Question about Durabrand DVD-1002 DVD Player
Very Very Low volume.
I've correctly hooked up my dvd player to a couple of tv sets now and for some reason, although i have each the dvd player and the television volume up to full blast there is a loud hum and little volume output from the dvd player. When I touch the tips of the A/V cords it produces a sound through the television and have tried other cords so I know it is the dvd player that is the problem. Please help if you can.
  • 5 more comments
  • Anonymous Jan 02, 2009
    I'm using the regular A/V jacks in the back. The volume is there but is barely audible.
    I'm using the line out jack.
  • wagali Jan 02, 2009
    That was me who mentioned earlier that I am in fact using the Line Out Jack.
    I've also crossed lines (left and right) and have used them individually at a time. Still nothing. I've also tried switching the switch on the back which corresponds with cable/aux etc. but nothing has changed. The Video works perfectly.
    Of course I would call customer service to assist me if it in fact existed. Apparently Lenoxx went of out business and the lines have also been disconnected.
    On this particular dvd player there is no headphone jack. It used to work at a normal level of volume but now, hooked up the same way the sound has deteriorated.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Are you using the line out jack or the headphone jack for sound?
  • 2,794 Answers
The line out jack isn't amplified. Try using the headphone jack. You can control the volume using the controls on the dvd. Whatever source you are plugging it into doesn't have an amp powerful enough to boost the audio.
Posted on Jan 02, 2009
  • Tim Babcock
    Tim Babcock Jan 03, 2009
    There have been several problems with those players. The manufacturer went out of business last year while Wal Mart was still selling them. You may be able to return it for a new player. You will find several threads on here about information on how to do it if the customer service department doesn't do it.
Volume too low on toshiba portable dvd sd-p91ske
see the causes and fix it:God bless you
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 21, 2012 | Televison & Video
I'm trying to hook up my dvd player to my tv and dish network system. I had disconnected it a couple of months ago before having some renovations done in my house, and I can't get it back to how...
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV. Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Make sure your TV set is tuned to the correct channel and input and you're all set. If you need further assistance please reply here and I will see to it this gets resolved.
Daniel Busa
DISH Network
Customer Service
May 22, 2011 | Emerson EWD2204 DVD Player/VCR
Audio Issue
You may have tried this, but when you hook up audio out from TV to audio in on reciever, did you try the different input options for the reciever. Often times, audio in is an aux1 or aux2 setting on the receiver. If it is working with the DVD player, it is functional, you just have to get the wires hooked up and get the reciever on the correct setting. Also, even if you have TV audio out correctly configured to audio in AND on the correct input setting, the TV volume will have to be UP as well as the receiver volume. NOT ALL THE WAY UP (you'll blow your speakers), but up about 25% for you to hear it.
Jul 29, 2009 | Audio Players & Recorders
Have to turn the volume to 80-100 to hear the tv in my bedroom
If it's just playing DVD's that the volume is low some DVD players have their own volume control.
You could look at the back of your tv and see if the dvd or psp is hooked up to a "line in" or a 'variable' input. The Line in is a constant audio source. The variable will be also affected by the volume on the TV.
May 31, 2009 | Televison & Video
Rca f36648 & rca HOME THEATER
Have you tried just hoooking up the DVD player by itself? Is the DVD player output setting correct? Also, make sure the "video input" is set for the correct channel that you are viewing (i.e. Channel 3).
Jul 31, 2008 | RCA F36648 36" TV
Low volume on playback
The volume control on the TV does not affect the recording. However, if you were recording from a set top box, and you turned the volume down on the box and not the TV, then this would cause the problem you describe.
If this is the case, then try to keep the STB volume at maximum and only use the TV volume control.
Also, some DVD players and VCRs have a lower output than the standard TV tuner, so an increase in volume is usually needed.
You might want to try some test recordings to see what happens.
May 08, 2008 | Sansui VRDVD5000 DVD Recorder/VCR
FLM 3232 television low volume
I hooked my tv up and there is no sound coming from the tv. I do not have surround sound just the tv. How do I make it work I need volume please
Oct 15, 2007 | Polaroid FLM-3232 Television
Durabrand DVD-1002 DVD Player Logo
95 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
