Question about Kenwood KAC-9103D Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
All it has on it is bass boost, frequency, and sensativity.. how do i adjust the wattage. cause im hooking it up to two alpine type r subs and there only rated for 500 watts rms max. and the amps mono amp so i cant be putting 900 watts rms which is what it puts out to each sub. how do i adjust this
  • 15,935 Answers
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Posted on Jan 03, 2009
    New Friend:
I had a question,I have 3 JL Audio 12" subs with this kind of amp n I don't know how to adjust the amp to make it sound nice n clear...Does any one know how I can adjust my Bass Boost,Frequency(Hz),Sensitivity?
Posted on Nov 16, 2012
Kenwood KAC-9103D Car Amp problem no sound when i hook it up ?
Posted on Nov 16, 2009
Reduce the amount of boost or, better yet, turn off the bass boost. With your installation, overemphasis on the bass is causing the rattles and distortion
Nov 16, 2012 | Kenwood KAC-9103D Car Audio Amplifier
How many watts in a Kenwood kac-9104D
Kenwood KAC-9104D
Product Features
  • Mono subwoofer amplifier
  • 500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
  • Variable low-pass filter (50-200 Hz at 24 dB per octave)
  • Bass boost (0-18 dB at 40 Hz )
  • Subsonic filter (15/25 Hz, 18 dB/octave )
Jun 29, 2011 | Kenwood Car Audio & Video
Can a kenwood KAC-6104D amp power 2 subs? what subs would go well with this amp?
dependent upon the wattage of both the amp and speakers in same olm configuration. Too much amp is a good thing, too little is a bad thing as it will burn up your speakers and amp
Mar 09, 2010 | Kenwood KAC-6104D D Class Mono Power...
No manual for my amp.
  • Class-D Monoblock Amplifier
  • Bass Boost Level and Frequency Remote Included
  • Variable Low-Pass Filter: 50 - 200 Hz (24 dB/Oct.)
  • Variable Input Sensitivity: 200mV - 5V
  • Phase Shift: 0° / 180°
  • Variable Infrasonic (Subsonic) Filter: 0/15Hz/25Hz (18 dB/Oct.)
  • High- and Low-Level Inputs
  • 1 Ohm Stable
  • RMS Power Output:
    • 500 watts x 1 chan. @ 4 ohms
    • 900 watts x 1 chan. @ 2 ohm
  • Preamp Outputs: 1 Pair
  • Bass Boost: 0 - 18 dB @ 40 - 100 Hz (Variable)
  • Dimensions: 15" L x 11-5/16" W x 2-3/8" H
Oct 05, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Not gettin enough bass
Hello saini_jatt_2, On the JBL3501 700 watt monoblock, you have adjustments for low pass and a setting for boost marked DBO, allowing you to select and boost the frequencies sent to the subs. If your amp is not the 3501, but a different JBL amp, the settings may be different. Set the LP to either the white dot (about 100Hz) or slightly below to about 80Hz. Set the HP to about midscale or slightly higher. Set the boost to wherever the bass sounds best. One other setting that will affect bass volume is the "input level" or gain control. It should have been properly set by your installer, but you can "tweak" it for best performance. Turning it up increases the sensitivity and matches it with the output from your head unit. Too high will cause distortion. Too low will result in less bass. So you want to set it just to the point that you begin to hear the distortion and then back it off slightly until the distortion disappears. Hope this helps.
Jun 05, 2009 | JBL GTO1202D Car Subwoofer
How to adjust the controls and gain on my kenwood 9104d 1800w amp
Hook the speakers in series to decrease your chances of blowing the amp and/or speakers themselves. And at high volumes make sure that the bass control is set for flat response.
Jun 25, 2017 | Car Audio & Video
Sony gtx 500 cd deck/ kenwood 8104d tuning
Set your HPF and LPF on the headunit to match the crossover on the kenwood amp.
I have the same amp, it's really not difficult to figure out. Try these settings, For the AMP: Bass Boost: 0 Crossover: 150 Level: 1
Now just go into the menu for your head unit and make sure you set the crossovers to 150 or whatever option you have, just make sure they match.
Simple.
Feb 27, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Kenwood kac x621 kenwood kac6402
May i suggest removing the equilizer unless you can adjust the settings for each amp seperatly. The amps themselves will allow you to add bass boost and treble boost. I think the problem your having is trying to run to much bass through your system causing it to distort badly.
Feb 25, 2007 | Kenwood Excelon KAC-X621 Car Audio...
Kenwood KAC-9103D Car Audio Amplifier Logo
624 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
