Question about Seagate DAT Scorpion 8 DAT Tape Drive
Drive Will Not Accept Tapes
I have many of these drives (about 30) all have different problems. One of the more common is the drive will not accept the tape. I have cycled power, I know Im using the correct tape, but the lights on the front of the tape drive never quit, remain constantly lit. The drive is empty though.. Thanks
  • 1 more comment
  • Chris Walker May 14, 2007
    This site sucks rare inebriated monkey c0ck
  • Chris Walker May 18, 2007
    Youre right - very impatient - had the boss breathing down my neck "YOURE SUPPOSED TO BE ABLE TO FIX ANYTHING !!!"
    Thanks for your insight
  • Chris Walker May 31, 2007
    Jackboy - Thank You so much - I have taken your advice and purchased cleaning products for the tape heads - and so far Ive 100% success
    Your help just let my company bill nearly $10,000 more....Thank You
    Genius:
  • 2,985 Answers
You are so impatient/ The problem with tape drives is the ferrous compound coming off the tape over time and building up- Each tape will need stripping and a good clean out with Coproponal Alchohol
Posted on May 18, 2007
  • john ash
    john ash May 25, 2007
    Happy stripping then a very sooty job -I've done a few.
SOURCE:
Not accept the new tape clean tape drive
Your question is not very clear.
Is the drive not accepting a new tape or is it not accepting a new cleaning tape?
LTO Cleaning tapes have a life span of between 20 and 50 cleans and once they go above this they expire and do not work again. I suggest you try using a brand new cleaning tape to try the cleaning cycle again and then try your backup again with a brand new tape too. This should eliminate all your media from you list of problems.
If the Superloader continues to either reject tapes or the cleaning light / alert persists then i am afraid it will need to be sent for repair as it is likely the read write heads will need replacement / service.
Visit the link below and they should be able to help and offer a full warranty too.
Autoloader Repair Service Adv Exch loan units available
Mar 07, 2014 | Quantum SuperLoader 3 LTO-3 Tape Drive
HP SureStor DAT24 won't exit clean mode, won't accept tapes
give it cleaning tape >>> once it finishs cleaning it will eject cleaning tape then you will be able to put any other taps
Apr 08, 2013 | HP Surestore DAT24 DAT Tape Drive
I have a Sony Video8 Handycam CCD-FX340 NTSC. It will not accept a tape. I can hit the eject button and the tape mechanism will come up and pop open. If I close it without a tape, it will go back down....
This problem can be caused by condensation. Leave camera and tapes in a warm dry place for a day and try again. If that doesn't help, there may be a tape threading fault. This can be something as simple as a broken drive belt, but still will require professional attention.
Oct 28, 2010 | Sony Video Cameras
Hello, I recently replaced an IBM 20/40GB DDS4 internal drive that was not working(would not accept tape, broken door hinge) with an exact same drive refurbished. I was told today that the drive did not...
i resolved the problem myself by removing the new drive and comparing it to the old 1 the jumpers were configured differently so i changed them and all was fine .. thanks anyway
Jan 20, 2010 | IBM Refurbished 20/40GB DDS/4 4MM INTERNAL...
What is a leader tape look like and how do I finf
The tape leader is a band of flexible plastic with a hook on the end that is attached to the reel inside the drive.
When a damaged tape is used in the drive or when the drive is faulty, the tape leader can miss hook the leader and it pulls through and just flaps around on the internal spool leaving the drive unable to accept any tapes and failing self test.
Re-thread the lape leader round the guides and past the head and hook the square hole in the leader back onto the plastic hook just in front of where the tape usually sits and power on the drive and see if it passes self test.
Although this is often just a damaged tape that causes this it can also suggest a faulty drive so dont use any important tapes in the unit till you are sure the drive isnt totally 100%
I have used www.tape-drive-repair.com who are pretty good for this kind of thing and not too expensive - if you need to send the drive away for repair / exchange
Jul 29, 2009 | Quantum DLT 4000 DLT Tape Drive
Wont accept cleaning tape
Make sure there are no pending jobs on the drive, if the drive is expecting a tape and gets a cleaning tape it will spit it out. Also, has the cleaning tape been used a lot? They have a limited life cycle and if they have exceeded their max uses they may not work.
Nov 13, 2008 | Dell PowerVault 100T DAT72 DAT Tape Drive
Old Tapes work new ones don't
I'm having this exact same issue and according to the DELL tech it is common. What I had to do is keep using the tapes until they started passing. I bought 2 brand new cleaning tapes and ran two cleaning jobs before it would pass. My daily tapes are passing, and after several retrys my weekly tapes are passing. Since my Monthly tapes occur so infrequently, I'm just taking one of the Daily tapes out of the rotation and using a Monthly tape until it passes. It's either this or buy a new tape drive.
Oct 28, 2008 | HP DLTVS80 (C750760008) Tape Drive
Tape Backups
i cannot access the tape media but the engine shows that its running properly whats the problem
May 28, 2008 | Quantum (BH2BA-YF) (BH2BAYF) DAT Tape...
Benchmark VS80 Tape drive giving Bad Media messages
Sounds a bit strange - I've seen this happen when tapes are re-used in a different drive but not when re-used in the same drive. You could try degaussing (magnetically wiping) the tapes. This should effectively make them appear as new ones.
Apr 07, 2008 | Benchmark DLT1 DLT Tape Drive
Newly Inserted Tape Ejects Automatically
Usually the drive mechanism is made up of rubber rollers, belt, etc. If these are worn out (in time), the drive mechanism will slide and will not be able to rotate the tape. If the cam cannot detect the movement ?n the tape then it will efect it.
May 14, 2007 | Panasonic PV-GS31 Mini DV Digital...
Seagate DAT Scorpion 8 DAT Tape Drive Logo
136 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
