Question about Electrolux Refrigerators
Circuit board water dispenser eres31800x - Electrolux Refrigerators
4 Suggested Answers
  • 159 Answers
SOURCE: door front water and ice inop
the bord is usually where the switch's are in front. There behind the push buttons. I would make sure your getting power to the bord and go from there. If you do have power there replace the bord. If not you will need to locate the tech sheet for the wireing diagram and trace the circut for the dispensor. Good luck
Posted on Jul 19, 2007
aasc
  • 1606 Answers
SOURCE: Hotpoint fridge dispenser works on water but not ice
If the little green lites show up , you do not need a circuit board . If you get a hum or buzzing noise when pushing for CRUSHED ice , then the auger motor is frozen up . Remove the ice bin and use a hair dryer directly on the forks which turn the dispensor . The heat will transfer into the motor , defrosting the armature . Try closing the freezer door ocassionally and pushing the arm to test if forks turn .
Posted on Aug 09, 2009
pappapumpdaf
  • 635 Answers
SOURCE: model 253.54673304 water is not dispensing from
You replaced motors? Did you replace the water solenoids on the back of the Fridge also?Sounds like you have either a wire or 2 disconnected from your cold water solenoid in back of the box, or your refrigerator compartment is freezing at the bottom and blocking your water flow to the cold water valve. Your cold water tank is located at or near the back and bottom of your refrigerator.
Posted on Mar 13, 2010
How to change the light bulb in the outside ice/water dispenser
Question about Maytag 22.6 cu. ft. Side-By-Side Refrigerator with PuriClean II Ice and Water
The light on the outside door (where the ice/water dispenser is) won't turn off. It is dimmer than when you hit the 'light' button, but it stays on constantly when the door is shut. The 'light' button works and turns the bulb brighter, but when you turn it off, it just dims and doesn't go out. The light shuts off when the door is open and turns back on when its closed. Model Number MSD2456GEB
Posted by linsdesk on Aug 31, 2011
Aparajita Batabyal
  • 3,513 Answers
Re: The light on the outside door (where the ice/water...
Hi
Reprogramming your refrigerator to only light up when the dispenser is in use saves energy and keepsyour house darker at night. The light is controlled using the buttons above the water dispenser mechanism.Press and hold the "Lock" or "Lock Controls" button for three seconds to activate the controls if they currently are locked.Tap the "Light" button to switch off the light.Press and hold the "Lock" button for another three seconds to lock the controls from further changes. The light now only comes on when the dispenser is active.
If the above procedure won't work then this will be the cause of a faulty switch. This light switch is an integrated part of the dispenser control circuit board. This will require you, or your service tech to replace the entire dispenser/ice maker control board. It will be located just behind the dispenser fascia, mounted on a bracket. the actual light switch circuit is mounted on this board.
Try this procedure:-
Shutdown the unit for five minutes. Simply unplug the unit for this length of time. This will reset the board, and possibly, fix this fault if it is not to severe. If the shutdown dose not correct the switch action, simply replace the dispenser/switch control circuit board.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Jul 25, 2015 | Maytag Refrigerators
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Fails to dispense ice from the ice maker
There are two possible reasons.
1) Check the main circuit board (Mostly on back side of refrigerator)
2) Check the circuit board behind the dispenser control.
This boards are available online and its user replaceable. If you are handyman you can even fix the boards(Replacing Diode/capacitors) if minor problems are there.
Jan 13, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Water wil dispense, but unable to change to ice dispense. None of the bottoms will work, including lock and light.
It sounds like your control panel has a short, please call your Jenn-air rep for assistance. thank you.
Oct 11, 2010 | Jenn-Air JCD2389G Side by Side...
I have a frigidaire model frs26lf8cw1. i had to replace the dispehenser board now when i plug the board in the ice maker will not stop dispensing ice, not sure what to do?
My kenmore started dispensing ice and water for no reason. After unplugging, I removed the cover from ice/water dispenser and discovered a burnt circuit board. Leave the board unplugged until you can obtain a good circuit board.
Oct 09, 2010 | Refrigerators
Water dispenser will cycle and dispense water
HI. These symptoms are a strong indication of a malfunctioning activation switch. This switch is part of the dispenser circuit board. Try to reset the board by unplugging the unit for 3 minutes. Once the three minutes have passed, simply plug the unit into the power socket, once more. If this erratic switch action persist, you will need to replace the dispenser board switch, or board.
Dec 11, 2009 | Jenn-Air JCD2290HES Side by Side...
MAYTAG ZIG-ZAG FRIDGE-FREEZER WANT DISPENSE WATER
Sounds tome that there is a short in the dispenser control circuit, keyboard or Control Board. If you had the model number I could help you better than this. I possibly would be able to walk you through this, Let me know, Sea Breeze
Nov 19, 2009 | Maytag ZigZagW / B Side by Side...
Water dispenser is not working no water dispenser
If the light is dimming when you try to get ice (dimming then getting bright in cycles) then thisis a common problem and GE will fix it. The Main circuit board on the back goes bad causing the ice\water dispenser to quit working then eventually the fridge quits cooling. Call 800-386-1215 and tell them the problem. There is a recall for the board
Oct 13, 2009 | Hotpoint HSS25GFP Side by Side...
Aug 09, 2009 | GE Refrigerators
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Refrigerators Logo
Top Electrolux Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
