Question about Frigidaire Electric Dryer
Frigidaire gallery series dryer code dn what does this mean?
the dr
  • 447 Answers
SOURCE: error code
what is the code???
Posted on Jan 05, 2008
SOURCE: Frigidaire Gallery Heavy Duty Front Load Dryer problem
it's probably the nylon bushings that the drum rides on. they wear out and the drum rides directly on the pad that the bushings attach to.
Posted on Sep 02, 2008
Krazytech
  • 725 Answers
SOURCE: error code HO on frigidaire gallery series dishwasher
If your hot water isn’t hot enough it will display “HO” while heating the water to operating temperature
Posted on Sep 07, 2008
AlmostBob
  • 550 Answers
SOURCE: I have a Frigidaire gallery
the dryer circuit will be clearly labelled in the house box, there will be two fuses or a single two phase breaker for this circuit.
there are not usually electrical fuses as such IN a dryer, there are thermostats to regulate temperature, and a thermal fuse, that cuts the power totally to the heat element if air temperature rises above its melt point.
the element itself has a limited life span and may fuse/burnout.
to test electrical components.
Unplug dryer
open case, by removing the front,
described elsewhere in any of the 'changing belt' threads
locate the thermal cutouts, on the fan housing or exhaust duct and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
3aca526.jpg5d18df6.jpg thermal cuttouts look like these ~1inch accross.
locate the heat element and disconnect one wire to isolate it from the rest of the circuit, test with ohmmmeter, no-continuity replace, continuity reconnect wire
while you have the dryer open de-lint the fan and exhaust ducting, most common cause of element or themal fuse failure is air flow restriction
7713ef8.jpgce0732c.jpg you get a lot of lint out of the fan even when proper cleaning is done, and clean out the ducting right to the exterior walls
95b69b0.jpgthis was the rather extreme result of not cleaning the duct (brainiac placed a wire across the terminals of the burnt out thermal fuse)
Posted on Oct 23, 2008
  • 104 Answers
SOURCE: Our four year old frigidaire gallery series dryer stopped drying.
knackered
Posted on Feb 01, 2009
Dryer gallery series e68
Good Morning Friend,
I understand you want to know how to replace the board on your Frigidaire dryer, model# GLEQ2152ES, due to receiving an E68 code. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to replace the board with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Dryers
Error codes for a frigidaire gallery series model gleq2152es0
Check out this affinity manual for error codes on electrolux dryers
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2012 | Frigidaire Dryers
I have a Frigidaire Gallery Series dryer that has developed a squeek when drying. The dryer is about 3 years old.... and doesn't do it all the time
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 27, 2011 | Frigidaire Gallery Series GLHS269ZDB 36"...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a gas Frigidaire Gallery dryer. There is an error code "LOC". I can't get it to work now.
This indicates there is an error with the door lock mechanism. It will most likely need to be replaced. This will prevent the dryer from working and is a safety feature to prevent injury while the dryer is in operation. It is fairly quick and cheap to repair.
Oct 07, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
201 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
