Question about Ovens
I have a smalvic oven, when i turn on the gril and close the door it turns off after 1 minute.
2 Suggested Answers
  • 38 Answers
SOURCE: oven door won't close tight - light stays on
Replace door hinges.
Posted on Mar 08, 2009
Oven door will not open after self-cleaning.
Can you please post make and model in comments?
Do you have a users guide?
Nov 25, 2015 | Ovens
Whirlpool TXFE366LVQ. When I turn selfclean after few minutes it shuts itself off and displays code F5E2
An F5 error code indicates that you need to check the oven door or the latching switch. The switch is used when cleaning the oven, for safe closure. If you find that the door or the latch switch do not function, you may need to replace them
F5-E2 means latch during clean error; the door and latch switch need checking and possible replacement.
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
2. If door not latched:
  2. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
  3. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Hope helps.
Jul 14, 2011 | Ovens
I get the error code FSE1, lock won't engage message for the bottom oven everytime I turn on the top or bottom unit. The message will not go away until I turn the top unit off. The bottom lock keeps...
F5 - E1 Self clean latch will not lock
1. If door latched:
  4. Re-apply power.
Note: Applies to all F5-E... codes.
Apr 19, 2011 | KitchenAid Architect KEBS208S Electric...
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
F5 error door locked
F5
- E0 Door switches do not agree (condition
exists when door switch is closed indicating an open door, and latch switch is
closed indicating a locked door) 1. If door latched:
    step C.
  4. Re-apply power.
    step C.
5. If
6. If failure
Note:
Dec 27, 2010 | Whirlpool RBD275PD Electric Double Oven
Code F5E5 after using self cleaning on KEBC107 Kitchenaid.
Hi, f5e5 stands for clean temperature not reached after 30 minutes. You should check your door gasket, hinges and you latch to make sure the door is sealing. You can take a piece of paper like a receipt and put it in the door and pull it out with the door closed to feel for resistance on the paper. If there is no resistance on the paper then the door is not sealing. you can try hitting the stop clear button for 3-6 seconds if that does not take the error code off then turn the breaker off for about 30 min.
In some instances, this could just be a glitch and a reset could be performed:
  • Press and hold any key for 1 minute to clear R failure code from memory.
  • F2 will appear.
  • Press CANCEL and observe for 1 minute to ensure operation is correct.
Nov 10, 2010 | KitchenAid KEBC107 Electric Single Oven
Cleaned oven and now the fan will not quit and door is still locked has been over 2 1/2 hours since cleaning over.
the timer in the control panel is still regeristing heat! and when the sensor weakens with age it keeps the circuit closed till all heat is gone in the oven area~ to get the door open? unplug the oven or trun off the pwoer to it!! for 15 minutes then turn it back on and it will release you just need to replace the oven heat range sensor for the self cleaning cycle
Jan 23, 2010 | Ovens
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
