Question about GPS
Navman Fuel 3200 Tech Support
Can you refer me to or do you offer tech support for the diesel 3200 fuel flow meter?
thanks in advance for your reply
bunnydawg
  • 5158 Answers
SOURCE: Crown macro tech 3600VZ AMPLIFIER
Haven't found one yet tho i'm wondering... what issue/problem are you having with the amp ?
Robert
Posted on Sep 14, 2008
SOURCE: 93 TOYOTA HILUX ( 22RE ) STARTS THEN STALLS AFTER 1-2 MINUTES
Try cleaning the throttle body.Check the air-gap for the pick-up coil inside the distributor assembly(use a brass feeler gauge)
Check valve clearances if needed(possible tight intake valve adj.)
Check base timing(follow instr. via under hood label)
Hope this helps.
Posted on Mar 17, 2009
  • 15 Answers
SOURCE: 2005 Ford F-250 6.0 PSD No Start
Seems like a low injector control pressure situation. You may see plenty of oil pressure on the gauge but the high pressure oil that opens the injectors is probably passing through a blown STC fitting at the back of the high pressure pump or something of that nature. Check for smoke out the tail pipe, if there's smoke, I could be wrong. If you checked the glow plugs (make sure you have 12 comming and going through the relay, just because it clicks does not mean it's working) than you more than likely have compression, the last thing you need is fuel. To get fuel you need high pressure oil. Your truck should have an ICP sensor on the right valve cover toward the front. You can back probe or make a breakout harness to pins... ok I don't know what two pins but there is only three. Anyway backprobe the sensor and see if you have more than .82V while cranking. If you do not, go to the IPR (injection pressure regulator) which is behind and below the turbo. It is a round solenoid valve sticking out of the high pressure oil pump. This valve will have the connector pointing down and toward the back of the motor in it's "weather protecting" position. You can rotate this valve by hand so the connector is easier to get to but don't force it and break it. You will then need to apply 12V and a ground to this valve. Do not supply the voltage for more than 120 seconds though or you could burn the valve up. with 12V to the valve see if it will start. If it will you may have a power supply problem to the valve. If none of this helps let me know, the rest of the troubleshooting is pretty involved.
Posted on Apr 16, 2009
junmag
  • 175 Answers
SOURCE: ONLY WORKS WHEN THE AIR FLOW METER IS DISCONNECTED
If you have check engine light, it could be Accelerator position sensor 1, apc 2, tps1, tps,2. If you dont have MIL could be Air flow meter. Also there is actually 3 small filters in the gdi pump not 2.
Posted on May 21, 2009
alicantecoli
  • 22306 Answers
SOURCE: bmw 325tds diesel flowing back to tank when parked
usual problem ,valves in injector worn for the fuel pump.easy quick fix this one ,fit a non return valve in the inlet pipe,check flow direction on valve when fitting and evan better as well is another in the bleed off return pipe .valves available from a motor factor or a specialist garage like bosch or lucas ,cut pipe and fit the valve with a piece of rubber pipe to connect the valve in line.or listen to the people who want to milk the golden cow and have the whole injector pump overhauled .
Posted on Dec 23, 2009
Mk3 mondeo engine loud ticking like grinding all the time.just had problem with injectors.had all 4 replaced.the garage says piston slap
Is this a new noise your hearing? If your mechanic has correctly diagnosed the noise find more info here:
http://www.autos.ca/auto-tech/auto-tech-noisy-engine-it-might-be-piston-slap/
The distinctive noise of a diesel engine is variably called diesel clatter, diesel nailing, or diesel knock. Diesel clatter is caused largely by the diesel combustion process; the sudden ignition of the diesel fuel when injected into the combustion chamber causes a pressure wave. Engine designers can reduce diesel clatter through: indirect injection; pilot or pre-injection; injection timing; injection rate; compression ratio; turbo boost; and exhaust gas recirculation (EGR).
Find more information more here: Diesel engine Wikipedia the free encyclopedia http://www.autos.ca/auto-tech/auto-tech-noisy-engine-it-might-be-piston-slap
Aug 30, 2017 | Cars & Trucks
Fuel gauge went nuts, ran out of fuel. Replaced sensor in tank. Still bad. Fuel gauge stuck on half now. No faulty wires to find. Tech says control panel is fine. Help 2000 dodge 2500 ram diesel
Fire tech and get a new one. LOL
Did that get checked and replaced by a Tech. ?
Fuel sending units are real easy to check with the ohm meter replacement may not have been necessary at all
Nov 06, 2016 | Dodge Ram 2500 Cars & Trucks
Fix my fuel gauge on my 2006 Ford F 350 diesel
Are you ready to pull a fuel tank ? Inside the fuel tank is the fuel sending unit.The instrument cluster is hardwired to the fuel sending unit, which is a variable resistor controlled by the action of a float arm. When the fuel level is low, resistance in the unit is low. When the fuel level is high, the resistance is high. The instrument cluster uses the input from the fuel sender and commands the fuel gauge indication according to the fuel level data. Do you know anything about automotive electrical systems ? Do you own a volt meter and do you know about code setting capability potential in new vehicles ? It is possibly for a problem in the fuel sending unit circuit to set codes in the smart junction box.
Fuel Gauge Tech How To Properly Diagnose Faulty Fuel Pump Sending Unit
Jan 15, 2015 | Ford Cars & Trucks
How do I wire a Beckett 12v diesel burner? I have a Beckett 12v burner igniter with a fire eye, a high limit switch, and a flow switch. This unit came with all the wires cut and missing a t stat and...
first do you have a fuel solenoid???i am a burner tech for thirty plus years.fuel solenoids are mounted on the fuel pump.flow switch.high limit switch and thermostat are connected in series to feed the fuel solenoid.
Aug 16, 2013 | Briggs & Stratton Pressure Washer...
Hi Would appreciate amy help you can offer! I
More then likely it has a low charge, or the metering device is plugged. Need a appliance repair tech, or refrigeration tech to look at it.
Aug 15, 2013 | Refrigerators
Have code P0171 on 2013 Escape
P0171 FORD - Fuel Injection System Too Lean Bank 1xicon.jpghttp://engine-codes.com/p0171_ford.htmlForum CodePossible causes- Intake air leaks
- Faulty front heated oxygen sensor
- Ignition misfiring
- Faulty fuel injectors
- Exhaust gas leaks
- Incorrect fuel pressure
- Lack of fuel
- Faulty Mass Air Flow (MAF) sensor
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced
Nov 05, 2012 | Cars & Trucks
Fault code p0171 what the problem
P0171 - System Too Lean Bank 1
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes If the P0171 is combined with the P0174 code, it's very likely that the problem is caused by an intake leak. If there are no intake leaks, the next step is to replaced the air filter and clean the air flow meter. If the problem persist the front oxygen (O2) sensor may need to be replaced.
Oct 09, 2012 | 2001 Renault Sportwagon
Scanned my computer , came up with a PO 171 and 174 what does this mean?
P0171 AND P0174
P0171 - System Too Engine Cylinder Lean Bank 1xicon.jpghttp://engine-codes.com/p0171.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes Dirty air filter of faulty air flow sensor are common causes for the P0171 code of the problem.
P0174 FORD - Fuel Injection System Too Lean Bank 2xicon.jpghttp://engine-codes.com/p0174_ford.htmlForum CodePossible causes- Intake air leaks
- Exhaust gas leaks
- Lack of fuel
- Incorrect Positive Crankcase Ventilation (PCV) hose connection Tech notes The codes is usually set when there is an intake leak after the air flow meter, before replacing any parts check for loose or broken hoses and intake gasket leak. On Ford some models dirty air filter, and dirty or faulty air flow sensor are the cause of the problem.
Jul 27, 2012 | Cars & Trucks
How do I set a diesel pump timing for a Toyota Coaster 3400cc (Toyota Diana)
We do not have diesels in this truck (thank goodness, noisy smelly things) in the US so have no tech info on them. Sorry
May 23, 2012 | Toyota Cars & Trucks
My Audi A4 2000 TDI year 2005 has run on two tanks of Bio fuel recently and it hasn't recovered... started stuttering. Fuel system has been flushed out, air flow mand air flow meter has been changed but...
Audi 1.9 TDI and 2.0 TDI engines with pump-nozzle injection system, (year 2005 included), don't have permission to run with Bio fuel !!!
First you must replace fuel filter, interflow a quality Diesel additive (for 60 liters Diesel fuel dosage) fill up tank with Diesel fuel and run at least 300 km on highway at 3000-3500 rpm in 4-th gear.
I recommend you Foerch Diesel Reiniger System additive! I use this additive from 3 years ago and is certified on Audi TDI engines!
Dec 04, 2009 | 2000 Audi A4
GPS Logo
107 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
