I'm currently trying to fix an Inspiron 1545 that has issues with the touchpad and mouse keys. I am not able to use the touchpad as I normally would. When using the touchpad, it doesn't recognize when I'm clicking on a folder or file. I've disabled/enabled the touchpad and also reinstalled the drivers, but it still doesn't function like its supposed to. In addition, neither of the mouse keys is working. When I pressed the right mouse button, I didn't get the appropriate menu options. As a last resort, I did a full restore and that still didn't fix the problem. Will I need to replace the touchpad/mouse keys?
SOURCE: Cannot disable touchpad.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=EFB3FA8537BFDD4DE030030ABD620900&doclang=en
This link is the answer to you problems.
Good luck my friend.
SOURCE: Dell Inspiron 1525 noisy right button on touchpad
Normally all the mouse buttons make a click sound when you press a button, some makes, the click is louder that other makes.
Purchase a mouse that is more to your tastes.
SOURCE: How do I disable the touchpad?
Try disabling the touch pad in the device manager. If that don't work unplug it from the motherboard. You will have to take the bezel and the keyboard off to unplug the touch pad.
SOURCE: Dell Inspiron 1545: I accidentally disabled the
ok so if your touch pad isn't working you need to get in to your control panel there look for device manger then look for the disable touch pad and enable it hope this helps
tip plug in a external mouse so you can get to the control panel
SOURCE: I believe one of the new E5400 laptops in my
replace the palmrest. It appears you have covered the non-hardware troubleshooting
