Question about Toshiba e310 Pocket PC
Toshiba E310 hello I have a PDA that said the main battery needed replacing it was showing that it was charging that the charge indicator was going down . I replaced the battery And left it to charge for the three hours on the sheet that came with the battery. it is charged to 15% and stopped still says is charging but goes no higher . Is there a procedure to get it to accept the new battery
5 Suggested Answers
  • 903 Answers
SOURCE: PDA e310, e330 or e740 together with Windows NT 4.0
The Toshiba Pocket PC's e310, e330 and e740 are designed to work together with Microsoft Windows 98, Windows 98SE, Millennium, Windows 2000 and Windows XP. Microsoft Windows NT4.0 is an older operating system, which does not work together with the Toshiba Pocket PC's e310,e330 and e740. Technical background: The Toshiba Pocket PC's have a USB and a Infrared interface to communicate with a Computer. Unfortunately, Microsoft Windows NT4.0 does not support USB nor Infrared. Windows NT supports a serial connection, but the serial interface is not available for the Pocket PC's e310,e330 and e740. Note: There is the possibility to synchronize a PDA over Network or Modem but the ActiveSync Software, which is responsible for the synchronization, will need a "first sync" to establish a "partnership" with the PDA. This "first sync" can only be done via USB.
Posted on Sep 07, 2005
  • 903 Answers
  • 903 Answers
zappa
  • 44 Answers
SOURCE: battery wont charge
did you think about checking the charger?
Posted on Sep 15, 2005
TOSHIBA PORTEGE G910 POWER MANAGEMENT problems
try xdadevelopers for this solution,best site for xda pda problems
Mar 23, 2010 | Computers & Internet
I have had this charging overnight but it won't charge. What should I do?
Hello Friend,
It depends on what you mean by charging overnight.
1. When you connect the charger, it shows on the phone that it's charging but after a while if you unplug the charger, it's still not charged: if it's the case, that means the battery is dead and needs to be replaced.
2. When you connect the charger, it doesn't show the phone charging: in this case it can be the charger brocken or the phone charge connector is faulty. you can verify that by moving the charger connector a little bit and see if it will start charging, if not you can try with another charger. if it doesn't charge even with another charger, at this time i will say for sure that the phone charge connector is faulty and needs a repair.
Best Regards,
Oct 30, 2009 | Toshiba e310 Pocket PC
Battery charge indicator seems faulty.
Solved own problem. Bad conection between pcb and battery contact pins. Reheat each battery pin on the pcb carefully until solder reflow occurs then remove heat. PDA now repaired
Aug 03, 2008 | Fujitsu Pocket Loox 410 Pocket PC
The Battery will not charge
I do have a manual, but not at work with me. However, I do remember seeing an explanation for a switch that is located on the lower left hand corner of the pda that you would have to use a paper clip to reach. I would wait for someone else to verify, but I suspect this is a hardboot type of reset instead of the button located on back that is accessed via the paper clip. This second switch located on the bottom of the device was a batter disconnect or lock out or something like that.
Just my humble thoughts.
I've done lots with the Ipaq series but not so much with the Toshibas. I helped my 10 year old daughter buy this one used off of ebay with her allowance so we had to go with a low cost pda.
j
Apr 21, 2008 | Toshiba e310 Pocket PC
Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Jan 06, 2008 | HP iPAQ H4150 Pocket PC
Battery wont charge
Sep 15, 2005 | Toshiba e570
Battery problem?
the problem is based on the backup battery and the Battery charging Electronic of the Pda. The only chance for you is to contact a Toshiba Service Partner for a repair of the Pocket PC. The Mainboard of the PDA has to be replaced.
Sep 08, 2005 | Toshiba e740 Pocket PC
Sep 07, 2005 | Toshiba e330 Pocket PC
Sep 07, 2005 | Toshiba e310 Pocket PC
Sep 07, 2005 | Toshiba e740 Pocket PC
Toshiba e310 Pocket PC Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
