Question about Kenmore 64952 Electric Dryer
I have a kenmore 90 series dryer, the drum belt broke, bought a new one, but cant figure out how to get it on, too much slack in the belt, not sure where it goes on
  • 91 Answers
REMEMBER BELT GOES AROUND IDLER PULLEY AND ATTACHES TO MOTOR SHAFT ,PULL BELT W/ HANDRUN BETWEEN ROLLER, AND PULL BACK AND ATTACH ON MOTOR PULLEY AND THAT ITS
Posted on Jan 03, 2009
Kenmore 80 series the drum will not turn but dryer gets hot
more then likely, the belt broke that turns the drum.
Jan 24, 2012 | Kenmore Dryers
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
Nov 14, 2011 | Kenmore 659 Electric Dryer
Cannot put the drum belt on
make sure the bracket is properly cliped to the base and the iderl wheel is twords the tub
pull the bel together under the tub, take the loop, pull it under the pully, lift the pully slighltly, place the loop on the motor
Oct 14, 2009 | Kenmore 74602 Gas Dryer
Cant figure out how the belt tensoner works to hold the belt tight i have a kenmore 70 series electric dryer
There are 2 slots underneath the motor pulley.
The flat part of the tensioner goues in these slots.
The roller wheel will then be on your left.
With the belt around the drum, run the belt under the wheel and through the tensioner, then over the motor pulley.
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Belt and assembly trouble. Please help!!
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Mar 05, 2009 | Kenmore 62722 Electric Dryer
Drum won't turn
sounds like a broken belt, common kenmoore belt number 341241.
Nov 03, 2008 | Dryers
Putting dryer back together
from front with belt around drum ..gather slack and push under idler and around motor pulley right to left...recommend doing it before reinstalling front place rollers on front panel under front lip of drum and lift ..easier than trying to reach under front panel and will a little more slck in belt
Sep 13, 2008 | Kenmore 63012 Electric Dryer
Motor removal and replacement on a kenmore electric dryer 90 series model# 110.86984110
remove screw at each end of console. pull & flip back out of way. remove top, remove bottom panel, slide putty knife to release both retainer clips. remove screws to remove door panel assy. remove belt, remove drum. remove motor clamps & remove wires from motor conector.good luck.
Aug 07, 2008 | Dryers
Good afternoon I'm a bit confused???? I'm knee deep with a dryer repair, (Sears Kenmore model # 110 97292100 gas front loading dryer) and everything is disassembled in my garage. The belt broke - that...
Its a bit frustrating to say the least just trying to explain this one,so I'll give you my best and with patience you'll get the belt on.Follow the picture below closely to get the idea of how the slack is made up. Please Rate This !!10ff711.jpg
Jun 22, 2008 | Dryers
Kenmore 64952 Electric Dryer Logo
114 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
