My whirlpool sm 8525079 quiet 2 washer is squealing during the spin cycle. Any idea what would cause this?
2 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: whirlpool model SM 8525079 fills with water but
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Posted on Jan 17, 2010
Whirlpool sm8525079 rev
I will help you provided a serial I need a model number check the tag on the washer not the book. Whirlpool authorized
Feb 11, 2014 | Washing Machines
Whirlpool washer 8525079 has 2 problems. First, with heavier loads the auger barely moves. Probably the dogs from what I'm reading. Second, during spin cycle, it sometimes will spin and sometimes won't....
I found replacement agitator dogs at a local appliance parts store. Pretty simple fix for the worn-out dogs. The parts came with installation instructions.
If the drum won't turn by hand, then it's probably a stuck drum brake just above the transmission. You can fix it by putting a little dab of silicone grease on the inner surface of the cup-shaped brake drum, and then working the drum back and forth until the grease comes in contact with the brake shoes. You can do this from the bottom of the machine without removing any panel - just tip it over on its back.
Oct 25, 2013 | Whirlpool Washing Machines
How do I increase the water level on my Whirlpool Ultimate Care II SM 8525079 Top Load Washer
You have a faulty water level switch. Replace the switch to get the correct water levels. Here is the switch to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 12, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool model SM 8525079 fills with water but will not agitate or spin
Jan 17, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer banging during spin cycle. Seems to be off balance. sm 8525079
there are balacing feet on the underside of the washer on each front corner.....they turn like a screw.....
Nov 16, 2009 | Washing Machines
Squealing noise during spin cycle
The spin cycle activates the fast mode on the motor, squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
Jul 08, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
