Question about Samsung RM255LASH Side by Side Refrigerator
Samsung rm25 freezer isnt making ice or freezing
4 Suggested Answers
  • 736 Answers
SOURCE: my side by side kenmore refrigerator, freezer isnt freezing
in the back of the freezer there is an "evaporator coil" .. that has many fine fins and is used to cool the air .. you dont normally see it because there is a panel bolted over it ... if the door was left ajar for awhile then ice forms on the evaporator and stops air from flowing thru it ... the result is that it cant cool the freezer properly ... if this is the problem then you can fix it by taking everything out ( use an insulated tote to store things or use a neighbors frig overnight .... turn your refrigerator off or unplug it ... open both doors and let it thaw out for a day or overnight ... put down towells to collect the melting ice .. you can even blow warm air into the bottom of the freezer to make it thaw faster but be careful not to overheat plastic parts .. once the unit is completely free of internal ice then it should start to work again like new ..
Posted on Nov 12, 2009
SOURCE: Freezer side tmp flashes/makes noise/inside back panel iced
The freezer side is off. The temp is flashing on the meter in front of the refrigerator. This is a Samsung RS2545SH. Does this freezer have a reset button or what shall I do.
Posted on Feb 01, 2010
Sebin
  • 712 Answers
SOURCE: ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Posted on Apr 21, 2010
Samsung refrigerator has 21 E code flashing
Freezer fan error. Most likely the fan in your freezer has stopped working completely
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Jul 05, 2016 | Samsung RF260BEAESR 25.5 cu. ft. French...
Bosch side by side isnt freezing
call a repair service locally , but with what you tell us , it may be too late for a fix
Oct 09, 2017 | Bosch Evolution® 500 B20CS50SNW Side by...
Ice cream will not freeze, but will make ice cubes.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
My freezer isnt as cold as it should be, top part of fridge isnt as cold and ice maker isnt freezing water
find the air vent and see if there is anything in front of them to prevent the air from recirculating. ice could be in the vents to,
Apr 13, 2010 | Freezers
It has stopped making ice and isnt freezing ice
Clean the coils on the bottom and make sure the fan is operable.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 08, 2010 | Refrigerators
My side by side kenmore refrigerator, freezer isnt freezing
the fan in the freezer is not working to blow the cold air in the freezer you need a new fan you need a repair man it will cost you $300 good luck i have the same problem don't buy samsung they are useless that why home depot don't sale samsung
Nov 12, 2009 | Samsung RS265LABP Side by Side...
My freezer isnt working
this may sound stupid but is the ice maker turned on? Does it say "ice" in the display? If it does, check to see if the ice level arm is jammed into the upper position also make sure that the ice bin is in place (it actuates the ice maker switch) make sure there is no ice stuck to the top of the ice maker
Jun 16, 2009 | Sub-Zero 700TC Bottom Freezer Refrigerator
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Feb 06, 2008 | Samsung RM255LASH Side by Side...
Samsung RM255LASH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
