Question about Samsung Washing Machines
I have a Brada washing machine BBRE1065HOWW, problem with clothes still wet after spin cycle, have tried every setting and does not matter, I checked hoses to make sure not plugged, checked belt on motor looks brand new, when it spins it only spins for about 30 seconds stops and spins again, leaving clothes wet, any ideas where problem might be?Thanks
SOURCE: Washer not spinning right and not completing a cycle
Sounds like you need to replace the carbon brushes on your washing machine motor
Posted on Mar 16, 2007
  • 139 Answers
SOURCE: hotpoint Aquarius WMA46 front loader
I 've had this problem a few times with these machines.
Some solutions that have worked for me are.
1 change the motor.
2 change the wiring loom
3 change the board.
The most common one is the motor even when the it has decent brushes the motor just will not pick up speed on the spin cycle.
hope this helps.
Posted on Dec 14, 2007
  • 250 Answers
SOURCE: spin cycle leaves clothes very wet
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Feb 09, 2009
  • 3600 Answers
SOURCE: Brand new GE Profile leaves clothes soaking wet
It is under warrenty call the store where you bought it and have them look at it. If you mess with it it will void your warrenty, belt may not be working or transmisson may not be shifting. The house call will be at no charge.
Posted on Sep 10, 2009
Testimonial: "thankyou for the help, I thought I had just made a bad buy. They sent someone out right away and it turns out this particular machine had a bad part."
SOURCE: Whirlpool washer model WFC7500VW1 came up with
that same thing is happening to me and i dont know what to do!!
Posted on Jun 27, 2010
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
I have a 2 month old Speed Queen top load (542) after the spin cycle, the clothes are still very wet
i assume the majority of the water is being pumped from the machine? if the clothes are very wet check your "fabric Select" setting and ensure you are not wahing on delecate handwash or wool wash (knits) setting, in this setting there will be a very slow or no, spin so the clothes will not stretch and have to be laid out to dry this is normal. if you are on a Permpress or regular setting the spin should be faster, also check your cycle selection is for Regular or permpress and spin is not missed .
I hope this was useful
Feb 15, 2013 | Speed Queen AWS52NW Top Load Washer
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Washer spin cycle
Hi joystoy
I would start with the belt. it sounds like the belt is going and that is the least expensive to fix. try that, if that doesnt work then i would call a repair company to look at it.
brent
Sep 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
