Question about HP Office Equipment & Supplies
I ran out of black ink; I cannot get the new cartridge to go in to its slot correctly. Help
The cartridge u have isnt for ur printer.
compare the new cartridge to your old one.
and figure out a difference.
I hope this helps.
gd luck
Posted on Jan 02, 2009
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    I ran out of the other color cartridges, and just bought a new black ink cartridge only. So can it work without the other color cartridges, and only on the black ink cartridge, because every time I try to...
    No many of the printers will need to have both the color and the black cartridges to work...
    You will have to purchase and install a new cartridge to get it working correctly.
    heatman101
    May 17, 2011 | Brother MFC-290C Printer
    How do I load the ink cartridges into the Canon Pixma printer MX320?
    1. Make sure that the power is turned on, and open the Paper Output Tray.
    2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
    The FINE Cartridge Holder moves to the replacement position.
    3. FINE Cartridge.
    (1) Pinch the tabs and open the Ink Cartridge Locking Cover.
    (2) Remove the FINE Cartridge.
    4. Prepare the new FINE Cartridge.
    (1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
    5. Install the FINE Cartridge.
    (1) Put a new FINE Cartridge in the FINE Cartridge Holder.
    The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
    (2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
    Push down the Ink Cartridge Locking Cover until it clicks.
    (3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
    (E) Closed correctly
    (F) Not closed correctly (the cover is tilted)
    6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
    Oct 05, 2010 | Canon Office Equipment & Supplies
    My black ink ran out so I replaced the ink
    Hi:
    I have used the printer series that you have for years, and once in awhile, I get a new cartridge that won't immediately print. Often, there is just a bit of dried ink residue on the print head, and that won't allow the cartridge to work correctly.
    Some simple things to try are :
    1) Remove the black cartridge. and take a damp paper towel and gently swab the print head area. Next, apply some pressure to the sides of the black cartridge, until you see black ink oozing out of the print head. Repeat if needed. Once the ink starts flowing, blot off the excess, and install the cartridge.
    If you can't get ink to flow, then the cartridge might be bad. Most of them have an expiration date on the packaging.
    Mar 31, 2010 | HP DeskJet 960c InkJet Printer
    I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
    Hello there:
    This problem is usually due to a print head that needs to be replaced
    I have provided the information that you will need ok
    best regards mike
    This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
    • Low ink levels
    • Ink cartridge approaching expiration date
    CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
    1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
    2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
    3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
    4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
    5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
    Identifying parts of the printheads Use the table below to identify the parts:
    1. Printhead handle
    2. Printhead tower
    3. Copper contacts
    4. Plastic tape
    5. Ink nozzles
    c00064460.jpg Do not touch:
    • Copper contacts
    • Ink nozzles
    • Printhead tower
    Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
    Ink
    1. Buy only genuine Dell replacement cartridges. Dell states their printer cartridges cannot be refilled with ink and that only their cartridges work in the printer.
    2. Bring the cartridge carrier of the printer to the center so you can access the ink cartridges. Open the cover of the printer and the carrier slides to the center. Make sure the printer is turned on.
    3. Remove the old black ink cartridge to use the color cartridge. If you allow the old black cartridge to remain in the printer, you will get error messages that the ink is low. The printer may also keep reverting back to the black ink as the default color when printing.
    4. Open the package of the new color cartridge carefully. Remove any blue packing tape that's on the ink cartridge. Take care not to touch the gold area or you could damage the cartridge. Insert the new color cartridge into the correct slot in the printer, the right side of the cartridge carrier. The ink cartridges aren't interchangeable; they need to be placed in the correct slot.
    5. Close the cover on your printer after installing the color cartridge. Run a print test to make sure the color cartridge is installed correctly. Use the Dell Ink Management System to monitor your printer and all-in-one functions. Thanks Thiru
    Jun 15, 2009 | Dell 810 All-In-One InkJet Printer
    HP C6280 with new ink cartridges shows cartridges empty
    First make sure you are placing the right
    color cartridge into the right slot.
    Most Printers are touchy about the
    installation of ink cartridges. If the
    instructions say to press the cartridge
    into the slot until you hear a loud click,
    that's what they mean. If at first you
    don't succeed, remove the cartridge and
    reinsert it into the slot again and press
    on it hard till it clicks.
    Then your printer should work properly.
    Hope this is of some help. Bud
    Feb 03, 2009 | HP C6280 All-in-One Printer
    New Cartridge error message
    Follow the steps below to remove and replace the empty ink cartridge.
    1. Turn the printer on.
    2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
    3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
      NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
    4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
    5. Remove the new ink cartridge from the packaging.
    6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
      NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
    7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
    8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
      NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
    9. Close the ink cartridge door.
    after Doing this all Follow the next step :-
    Please Try This, I am sure it is going to workout.
    Resetting the All-in-One
    Press the On (fa37665.gif) button to turn off the unit.
    • Disconnect the power cord from the back of the unit.
    • Connect the power cord to the back of the unit.
    • Press the On (a477fdf.gif) button to turn on the unit.
    Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
    After changing cartridge, printer will not print, z645?
    First... check to make sure you removed the yellow tab from the new print cartridge
    put the ink cartridge back into the printer
    click Start
    click Control Panel
    open Printers and Faxes
    click (or double click to open) your printer icon
    click on Printer menu
    click on cancel all documents
    Then try printing again.
    If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
    Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
    18 people viewed this question
    Seeker5211
    Seeker5211
