Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
USB to Sata Ide drive
My USB to Sata Ide drive is not showing up. It is not in disk management either. What should I do?
  • 42 Answers
If your sata drive is new then you will have to fdisk and format it before the pc will allow it a drive letter even though you are using it through usb. Did your Usb to Sata come with a driver disk? You will have to run it before the drive will work.
Dale
Posted on Jan 04, 2009
Hi, I have a segate barracuda 7200.9 160 gb hard disk which was working fine with my desktop but when i am connecting it to laptop thorugh USB it is showing in device manager as portable media.. showing in...
I would suspect that Windows is screwing things up, your laptop cdrom drive should be "d" drive and your portable usb drive should be the "e" drive. You could try to change the usb to "e" in disk management, failing that I would reboot the laptop with usb drive connected to see if Windows straighten things out.
May 14, 2017 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Transfered XP to internal Sata disk with controller . MOBO A7V8X-X, BIOS version 1014. Disk is recognized during boot. Disconnected all IDE drives. System won't boot from sata disk. Booting from CD results...
get to the bios boot section
( on starting the computer hold down the delete key until the bios screen shows
in that section you will see boot preference
organize the sequence that the unit will boot from save and esc
so sata hard drive =1
cd=2
external hard dive =3 etc
Sep 11, 2017 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Connecting to console for format
I assume you mean a USB HDD, you plug in the USB, then go to My Computer, Icon, right click, and select MANAGE, now when the window comes up, go to Disk management, find you RAW drive, select it , right click, and select Format, prior to this the software should have asked you if you wish to "Initialize" the new drive, answer YES to that question, and then proceed to Format. Format in NTFS, leave all defaults. After this reboot, and you will then be able to use the HDD as normal.
If it is a SATA or IDE, then the task is still the same, except that you plug it into either the IDE Cable, or the SATA cable. Then you perform exactly the same as if you did the USB setup. If using SATA or IDE. always check, the "Jumpers" usually they are noted on the Drive itself, If using with another drive, the drive's jumper must be changed so the drive will run as a Slave. On a USB setup the drive on the USB cable must be Master. Jumper accordingly.
Apr 17, 2010 | Fortinet, Inc. FortiGate 200A Antivirus...
I WANT TO INSTALL LOCAL DISK D ON MY COMPUTOR?
i lose my local disc d in my komputer,my dvd rom can read a disc.how can i instal
Sep 16, 2009 | Dell Dimension 4600 PC Desktop
Max Hard Drive supported?
first tell me form which device u attched.ide or sata.
or usb
if sata then u have enable sata in bios checkit in bios.
also check if usb port .
or ide as your harddisk conection method.
Nov 27, 2008 | Computers & Internet
Sata DVD burner
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Oct 22, 2008 | Computers & Internet
Install sata drives on abit av8 motherboard (vista home)
Right click on my computer, click on manage. Then on Disk Management. See if the drive shows up . If it does you can format it by right clicking and select format.
Sep 28, 2008 | HP xw4600 Workstation Linux Installer...
Sabrent 5in1 USB-DSC5 USB2.0 to SATA & IDE cables HDD not in Windows Explorer
There shouldn't be any problem accessing FAT32 drives of that size.
Check your disk management (right-click "my computer", hit "manage" and then click on the "disk management")
It should tell you what kind of formatting the disk is, and what the drive-letter is.
If it shows as being FAT32, then you're fine. If it doesn't, the FAT has been corrupted and may require a disk rescue or some kind of disk fixing utility.
Assuming it shows the partition as healthy and FAT32, but it doesn't have a drive-letter, right-click on it and "change driveletter". Pick a letter and hit OK. It should now show up!
Aug 19, 2008 | Sabrent (USB-2535) (USB2535) IDE...
My PC detects the USB Drive but it doesn't appear in the My computer display
HI
PLEASE GO TO MY COMPUTER RIGHT CLICK ON IT AND GOTO MANAGE IN MANAGE U SEE DISK MANAGEMENT AS SOON AS U CLICK THE DISK MANAGEMENT AND YOUR HARD DRIVE IS CONNACTED UWILL NOTICE A POP UP IF NEVER BEEN USED BEFORE THE HARD DISK AND THEN FOLLOW THE INSTRUCTION...AND IF IT WA S USED BEFORE THEN U GO TO DISK MANAGEMENT U WILL FING YOUR DISK LISTED SO U JUST HAVE TO SAY CREATE VOLUME AND FOLOW THE INSTRUCTION...
IF ITS IDE JUST BE SURE FOR THE JUMPERS...
Jun 03, 2008 | Samsung Spinpoint M HM121HI 120GB SATA...
80 GB disk drive
Hi, I can help you with problem. Is the new 80GB drive partitioned and formated?
Sep 16, 2007 | Compaq Armada E500 Notebook
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
168 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
