Question about Wahl Deluxe Home Kit 8645-500 Hair Trimmer
Wahl Designer Trimmers Vibrate really bad
How can I fix the trimmers where they don't vibrate so bad? It is hard to hold the trimmers because of the vibrating.
5 Suggested Answers
geokohler
  • 304 Answers
SOURCE: wahl designer clipper
Have you been oiling the blades? If you ran out of oil you can use any light machine oil available at any hardware store. If you feel comfortable opening the unit you will be able to see the electromagnet inside and watch what is going on. If all else fails Buy a new set (the exact kind) and keep the receipt. Swap them out and return it from the store where you purchased it. You paid good money for them and they should not have died so quickly. The store will get full credit for it when they return it to the manufacturer so it is not that morally bad. The manufacturer should bare the burden because of the poor quality control that allowed your clipper to die in such a short period of time. Hope you find this solution helpful and the last option is a surefire fix...
George
Posted on Jul 25, 2008
rick_stokes_
  • 61 Answers
SOURCE: wahl designer clippers cutting skin
The overlap of the "top blade" in relation to the "bottom blade" is set too close. The top blade has to be back a little bit to prevent this from happening. When changing blades this may have got set wrong. Loosen the two screws holding the bottom blade on and you can move the bottom blade in relation to the top blade to fix this.
Posted on Sep 27, 2009
rick_stokes_
  • 61 Answers
SOURCE: loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
askmannyssha
  • 76 Answers
SOURCE: Where can I buy attachments for Wahl Super Taper.
Manny's Sharpening has the Wahl attachment for $3.00 ea any size from 1/2" to No 9 323 263-4697
Posted on Mar 30, 2010
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers ยท 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
Purchased a used stihl fs 96 this winter. Just got it up and running and it shakes so bad I think I lost a filling
I think that is a solid shaft drive which should reduce vibration vs a flex shaft. If you can pull the drive tube and then run the engine it should tell you if it's the engine or the shaft/gear head giving the excess vibration. I would start by just removing the gear head first as there are a few bearings in there that could fail and cause it to vibrate badly.
May 25, 2014 | Garden
Vibration coming from cutting blade through the machine Stihl hl75k
Do you have bent blades.? Try removing the 'driveshaft' and adding a coating of grease, the shafts can become dry within a plastic liner and start to vibrate
Apr 21, 2014 | Stihl Garden
How do i replace the start rope on my craftsman bushwacker model number 358.795800?
Your starter rope may not be the only problem you have. Could it be that you had a hard time starting the unit? If so it could be crankcase bearings are worn and is causing unit to vibrate, which in turn damaged the starter.
Oct 09, 2013 | Craftsman Garden
On a Wahl Beard Trimmer 9876-536 -- what's the button on the side of the trimmer for?
The button info requested is almost 2 years old, but on my trimmer the button to the left of the power swt on the side is to lock the trimmer blade in the front or rear position. It is kinda weak and you can still move the blade if you push it. (I do seem to have the same one shown in the picture here.)
Later!
The Shadow
Nov 17, 2010 | Wahl 9876-500 Beard Trimmer
How to change the spool
Plastic got wrapped arround end of trimmer and melted arround the end of shaft into bearing causing trimmer to vibrate when running
Sep 01, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
This is a very good shaving machine and i want another one
You can get these wahl trimmers from Nose Hair Trimmer, that can be used for removing unwanted hairs from nose, ears and eyebrows.
This place would provide you most attractive deals on these branded trimmers with free shipping service.
Apart from wahl trimmer, you can also get recommendations for various other branded trimmers that are hygienic, comfortable and safe to use.
lowcost2.ru_2015.05.08-12.19.02_984580_electric_shaver_nose_ear_face_hair_removal_trimmer_clipper_dlya_nosa_y_ushey_y_brovey3-lmanv4snjocb41esrne4nwpm-3-2.jpg
Dec 03, 2009 | Wahl Vision 180 Beard Trimmer
Re-assembling my Wahl Beard Trimmer Model # 9918C
Turn the trimmer off. Put your thumb under the teeth of the attachment. Push Up. The attachment should snap off. Replace the beard trimmer in the slot. Hope this helps.
Jun 04, 2009 | Wahl 9916-800 Groomsman Beard Trimmer
Wahl Deluxe Home Kit 8645-500 Hair Trimmer Logo
29 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
