Question about Dimplex Compact Electric Flame Stove Heater
Heater fan stop working after a couple of muinutes
When you turn the heater on the fan will blow for a short period and then stop. The heater will continue to put out a little heat, but even when you turn the therostat to its highest position the heater coils will not come on.
  • 1 more comment
  • Marlene Buzard
    Marlene Buzard Jan 05, 2009
    contact: www.dimplex.com or call: 1800-668-6663 ext. 358
  • jeanne60 Jan 29, 2009
    we have the same problem, fan stops working after a a few minutes. Our dimplex electrolog airheater is only 1 yr old. ser# 26007D2F 478. Model 6901050600. Have used it for about 3 months. Bought it at Lowes, but they don't carry parts. Any advise? My email is jeanne60@telus.net
  • timwear Mar 17, 2009
    I have the same problem, i isolated the over heating switch to ensure it was not faulty and while doing so observed the fan motor slowing down and when not enough air passes over the heating coils the fire place switches off. I hav'nt figured out the fan problem yet but it has to be something with the set up off the fan as it kicks off at different times sometimes 5 mins others 40 mins. What a pain in the ***!
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Posted on Jan 26, 2011
Renault Megane Dynamique 1.6 2004 - Fan heater stopped working and wet footwells
you have a leak in you heater core you have to take it out to check it or replace it the steam is from your heater and your heater resistor is in the same place so it may of got wet and shorted out.
Jan 28, 2014 | Renault Megane Cars & Trucks
Tip
Scania Fault Codes
000 00 No Fault
01 001 less than the rated voltage - heater works
02 002 higher than the rated voltage - heater works
004 03 Short circuit fan (D2I)
005 05 Short-circuiting the wires from alarm (D2I)
009 09 Heater off system TRS (D2I / D9W)
010 0A higher than the nominal voltage (heater stopped)
011 0B voltage less than the nominal (heater stopped)
012 0C overheat - fuel pump is turned off
013 0D temperature sensor recorded a high temperature
014 0E big difference values of t. Dutch. overheating and Dutch. regulation. t (D3W / D9W)
015 0F heater overheated many times - the heater is turned off (D2I / D9W)
017 11 Reusable overheating (t exceeds the second threshold) (D3W)
020 14 Candle / rod defective bulbs
021 15 Short candles / kernel bulbs
022 16 switch faulty lights / lamps kernel (D2W)
023 17 Internal defect relay control R2 candle / bar bulbs
024 18 Short-circuit switch controller candle / bar bulbs
025 19 Short-circuit diagnostic socket
029 1D fan air gap 5 does not operate R3
030 1E air fan does not work in all positions (R3-D3W)
031 1F air fan does not work in all positions (R3-D3W)
032 20 Air fan does not work in all positions (R3-D3W)
033 21 Air fan does not work in all positions (R4-D2I / D9W)
034 22 No contact with solenoid valve system COOL. (D2W / D9W)
035 23 No contact with the relay average performance
036 24 Short-circuit relay average performance
037 25 Do not rotate water pump (D2W / D9W)
038 26 No contact with the fan relay cab heating (D2W / D9W)
039 27 Short cab heating fan relay (D2W / D9W)
040 28 Short electromagnetic. COOLING valve system. (D2W / D9W)
042 2A Short circuit water pump (D9W)
043 2B Short cable from the computer to the heater fuel pump (D9W)
047 2F Short circuit of the fuel pump
048 30 No contact with the fuel pump
050 32 Heater run many times but have not worked (relay R3)
051 33 Flames emerged immediately after pressing the start button heater
052 34 No start (restart purge)
053 35 Stop flame during startup
36 054 Stop flame position max. productivity
055 37 Stop the flame in a position average performance
056 38 Stop the flame in the position of poor performance
057 39 Flame sensor short circuit (photoresist)
058 3A heater is turned off, but the flame in the combustion chamber (D2W)
059 3B Water temperature rising too quickly (D9W)
060 3C No contact with the sensor temperature control
061 3D sensor short circuit temperature control
062 3E No contact with the potentiometer (D2H / D2I)
3F 063 Short potentiometer (D2H / D2I)
064 40 No contact with flame sensor
065 41 Flame sensor short circuit
071 47 No contact with the sensor overheating (D3W / D9W)
072 48 Short-circuit overheating sensor (D3W / D9W)
073 49 Overheating sensor recorded the fastest increase in temperature (D9W)
090 5A Spontaneous error
091 5B high surge (high-voltage wires, CB-radio, etc.)
092 5C Faulty heater control unit - fault ROM
093 5D Faulty heater control unit - faulty RAM
094 5E Faulty heater control unit - fault EEPROM
096 60 Temperature sensor faulty heater ECU (D2I)
097 61 Faulty heater ECU (D2I / D2W / D9W)
255 FF cleared but faulty memory EEPROM
source
http://truckmanual.weebly.com/scania-fault-codes.html
on Dec 20, 2016 | Cars & Trucks
Buffalo 85 fan not blowing
sounds like the fan is not working, can you isolate the fan and run it by itself with out the burned, this will tell you if it's the fan motor or some sensor that's the trouble
Apr 28, 2013 | Heating & Cooling
The heater stop working a couple days after i added a radiator cleaner and the heater stop blowing warm air today, is there a fues to replace or did the heater valve get clogged
If the fan wont blow air at all then it is a fuse. If the fan works and the car is warm you have a clog somewhere. you could try pulling a heater hose off when the car is cold to check for flow.
Dec 19, 2012 | 1990 Ford Thunderbird
INSTRUMENT CLUSTER AND BLOWER MOTOR QUIT TOGETHER.
Belief it or not your problem may be at one off your electric fans, also a possibility your a/c compressor coil shorted, so disconnect your a/c condenser fan and your a/c compressor check them for short and replace has needed, here is the logic every time you turn your heater on defrost it will cycle your a/c and it will blow your fuse, there is a circuit breaker on fuse box by left kick panel way up make sure it is in good condition push on it and you will feel it click if trigger, is not spring back it may be at fault to, replace it. good luck
Mar 22, 2017 | Toyota Cars & Trucks
We have an electric fireplace - the blower fan is now not working - was working fine - but just stopped
Don't despair, it's very common with electric fireplace/heaters. They weren't built to run long periods of time and most fail within one year.
A couple of things may have caused your problem. These fans get clogged with dust, lint and/or pet hair and is puts a strain on their continued operation. If you're fortunate enough to still have your Owners Manual, it will show/tell you how to access the fan motor and blades under the lower portion of the firebox. Clean the fan and motor using a vacuum cleaner, that has a hose and a brush attachment. Attempt this only after you have unplugged the fireplace from the wall. If you have a can of compressed air with a straw nozzle (like you clean your computer with) use that to blow out the nooks and crannies. Reassemble the bottom of the firebox, plug in the cord and give it a try.
If that didn't solve your problem, either the fan motor is bad or the switch to turn the fan on is bad.
Those parts you'll have to purchase directly from Dimplex USA.
Hope this helps you solve the problem.
Feb 10, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
1988 bmw 325is heater keeps blowing 30amp fuse, tried to find a short but me heater blower fan isnt working what could be the problem. cant keep a fuse without blowing
More than likely the fan motor its self is short to ground try to unhook the wires to the fan motor and install a new fuse and then turn the fan on with the wires removed and if the fuse is still good you know it is the fan motor its self
Feb 12, 2010 | 1988 BMW 3 Series
Heater and a/c fan doesnt turn on
Your fan motor has either burned out or there is a short in the wiring. Check for voltage at the fan motor plug under the dashboard. If you have power there then the motor is bad, replace the motor and you should be good to go.
Oct 09, 2009 | 1999 Ford Ranger SuperCab
Dimplex Compact Electric Flame Stove Heater Logo
1,421 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
