Question about Kenwood KDC-V7017 CD Player
Kenwood kdc-v7017 wont turn on, fuse is good
I have a Kenwood kdc-v7017 that came out my brothers car , we replaced with a new pioneer, I want to fix it for my old beater plow truck, the fuse is good in the back of the deck , i was wondering if any one a had service manual that they could post of the steps in diagnosing the problem (tests of diods resisters, circuits) i would have to cheak.
I tested the cable from the face plate to the pcm with a ohm meter and fond that there were a few broken wires in the ribbon cable so i found a downloadable service manual got the part numbers for the ribbon cable and the recptical that the faceplate contacts and ordered them from the kenwood parts web site
Posted on Jan 03, 2009
I need the instruction manual for my kdcv7017 kenwood cd player
Kenwood has the manuals for many of their products available on their support web site: http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ . The direct link to the KDC-V7017 CD Receiver user manual is http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDCV7017.pdf . See the Kenwood site for the other available documentation.
I hope this helps.
Dec 01, 2011 | Kenwood KDC-V7017 CD Player
I have a kenwood kdc-x689. The screen went dim before it stopped working. The fuse on the back of the unit is still good. Please help me! Thanks!
There are more fuses which are to be checked other than the one at the back , The power supply fuse should be within the fuse box of the car , Do check them and you'll be fixed for sure , Just find the fuse box and how to replace one using your owners manual
thank you
Jun 01, 2011 | Kenwood eXcelon KDC-X689
Faceplate opens to remove the faceplate but there is no display?
you probably have a bad flexible cable (goes from the face to the main motherboard). unless you are good at desoldering and soldering, you may want to have it done by a professional.
Sep 08, 2010 | Kenwood KDC-V7017 CD Player
Pioneer Model KDC PM232 Showing "PROTECT" on display when I turned power on
try finding and pressing the reset button. sometimes hidden by a sticker or behind the face. there has to be power for it to work. also in line fuse may be incorrect
Apr 11, 2010 | Kenwood KDC-MP232 CD Player
Ejecting my faceplate
you probably have a bad ribbon cable.
Aug 06, 2009 | Kenwood KDC-V7017 CD Player
Kenwood kdc-119**
No, you have the battery wire hooked up to the ignition switch.
Here is the owners manual with wiring diagram.
http://inform3.kenwoodusa.com/manuals/KDC219.pdf
Yellow wire must go directly to fused HOT (battery).Not through ignition switch, red goes to switch.
Good Luck
Leadispenser
Jul 30, 2008 | Kenwood KDC-135 CD Player
Re: Fuses
Ordinarily you have two fuses specific to the radio that come with the radio. One for the main power to everything in the radio and one fuse to hold the memory in the radio (stations, time, etc.). The car itself will have its own fuse for the radio too. This will be located in the car's fuse block with all the other car fuses. It may only be 7 amps while the other fuses may be 10, 15, 20 amps or higher. The fuses that came with the radio will be inline fuses and will be located behind the radio in the dash of your car. Good luck.
Mar 29, 2007 | Kenwood KDC-V7017 CD Player
No power to the cd receiver.
There is a fuse both in the back of the deck...and in your fuse panel... Refer to your service manual for the car to find the correct fuse for the audion system. and Refer to your service manual for your deck to see what im talking about...all the fuses Ive seen just plug into the back of the deck.
Need a Kenwood Part #...
Partstore.com will have the part but you will need to go to manualsparadise.com first and get a pdf of the COMPLETE service manual with the parts breakdown in it. If you are lucky enough to get the actual part number from someone then you can of course skip the part about getting the service manual. Good luck.
Feb 06, 2007 | Kenwood KDC-V7017 CD Player
Kenwood KDC-V7017 CD Player Logo
192 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
