My Tenda 3G611R+ does not want to connect with computer
When i do the setup with the cd it does not want to conect with the computer even though it is conected and working in the network sharing centre
Benimur
  • 6966 Answers
SOURCE: Please help I can't conect to Router MR814V2 with wireless card Encore ENPWI-G2
On Windows XP, the OS will prevent a connection to an unsecured wireless network such as what you have.
You can try:
Double click on the red WiFi icon, click on the "Change the order of preferred networks",  Click on "Add", type in the Network name (SSID) of your router (you can get this by using the connected PC and log in to the NetGear's Webbased Interface), set Network Authentication to "Open", set Data encryption to "Disabled",  OK, reboot your PC.
Alternately, you can set the PC where the Encore ENPWI-G2 card is connected to manual configured settings rather than Auto obtain. Follow what is in the connected PC's settings except that the  last number of the IP add be different (ex. connected PC > 192.168.0.100, set the unconnected PC to 192.168.0.101, all the rest subnet, default dns be the same. Of course the 101 must not be in use, if double IP add, change to 102).
In some instances, you may need to use the Encore WiFi configuration utility (normally comes with the drivers in the installer CD) rather than the Windows buil-in WiFi Config utility,
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Oct 10, 2007
  • 139 Answers
SOURCE: 3 com hub tp4 home network setup failure
There are several possible problems here, and more information is needed to identify which one is causing trouble. First, are you using a high speed dsl or cable internet connection? ...or is your Internet connection a dial-up phone line? This will have a significant effect on how your cables should be connected between the hub and the computers. Windows typically defaults to a 169... address when it is not properly connected to a shared network connection.
Posted on Jan 10, 2008
  • 47 Answers
SOURCE: limit or no conectivity problem
I understand that you are using the Windows Internet Connection Sharing to share your internet connection to your other computer.
If you don't have a router to share the connection then you are using Windows ICS connection.
When you enable ICS, the network adapter connected to the local area network is assigned a static IP address of 192.168.0.1.
You can check this site for more information
http://www.annoyances.org/exec/show/ics_xp
You can try to connect the two computers first without the internet connection.
Example : PC A 192.168.0.2
You can set the IP addresses manually, just set the tcp/ip properties and from that area you can set the IP address manually.
And for PC B 192.168.0.3
You dont need to set the ip address for the gateway and dns since you are just testing the connection of the two computer.
They should belong to the same workgroup example HOME and set the computer name to PC1 and PC2.
You can right click MY COMPUTER then select PROPERTIES then you will able to see the computer name.
To start the wizard
1.
Choose Control Panel from the Start menu.
2.
Click Network and Internet Connections, and then click Set up or change your home or small office network.
http://www.smallbusinesscomputing.com/webmaster/article.php/3293481
http://www.homenethelp.com/connection-sharing.asp
http://practicallynetworked.com/sharing/xp_ics/
Posted on Mar 05, 2008
SOURCE: WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Posted on Aug 09, 2008
kenshin99
  • 89 Answers
SOURCE: Cannot setup home wireless network between computers
Hi!
Since all computers are online, you do not need to change any setting on the router for the computers to share file or resources.
If you are using Windows XP - try this link:
http://support.microsoft.com/kb/304040
For Vista:
http://windowshelp.microsoft.com/Windows/en-US/Help/e2e03106-2546-4085-bd07-6c3ac95003111033.mspx
I hope that helps!
Good luck and have a nice say!
Posted on Dec 02, 2008
I have installed Tenda W301A access point in my home. Only one PC can connects to the access point. If i try to connect other computer, its shows limited connectivity.
I assume you mean there is no internet connection except for one PC. You cannot connect an access point to the internet and distribute the internet access. For this you need a router.
AP does typically also not have a DHCP what would allow several clients at least to connect to each other.
Nov 03, 2014 | TENDA 300mbps Mimo Wireless N Access Point
I can't login to my Tenda AC1750 Router using 192.168.0.1 or 1.1
TENDA W300D connection problems Green lights but no connection solved
although a different model
this might help for apple users as it worked for me!
i think my problem ocurred after an update to mac software.
my service provider could not resolve it but i did. :)
1) select settings
2) select network
3) view ethernet if it shows a green light and states connected yet you can not connect to any web page or your set up page for TENDA
4) select the apple logo top left of desktop screen
5) select location
6) select Automatic
this is what was stopping my apple mac from connecting even though i could connect ok with iPad.
now try your browser again
7) contact your service provider and get all the details to fill in on your modem/router set up page.
i only have the aus info:
download soft wear updates from: www.tendaanz.com.au
www.tenda.cn
tel tenda (sydney aus) 0284057583
Sep 29, 2013 | Computers & Internet
I cannot connect "wireless" with my TENDA model
TENDA model W268R default IP 192.168.0.1 username: admin password: admin
Reset the Router and reconfigure again....
Jul 04, 2011 | Computers & Internet
My aunts router is giving lights for all icons except her internet (little earth icon) so its not using her modem to give internet her connection via modem to computer work but not to wireless
First go to a computer that you know has conectivity.
In your browser type //192.168.2.1 and hit enter. Here you should be able to manage the router. You need to make sure the wifi is enabled.
The easy way, is to run the setup CD. While normally I hate these things, well, normally I hate all things Belkin, they actually have a VERY nice assisted setup CD. People with absolutely no computer skills can manage to set up a router with their setup CD.
Belkin Routers will have wifi disabled out of the box to encourage you to use the setup CD. You have to do one of the things above.
May 06, 2011 | Belkin F5D7234-4 Router
How to instal 3g611R Tenda router
You do have to install any drivers for a "Router", to link your modem & PC to access the internet you just have to configure the router's settings.
Read this link @ How do I configure a Tenda router?
3G611R Default IP:192.168.0.1
3G611R Default Password:admin
3G611R Default Username:admin
Hope it helps.
Apr 08, 2011 | Computers & Internet
How i conect noika 6030 to my computer with mtnl sim
If your phone comes with a cd, put the cd in the computer and then go to my computer and enter the cd.Normally there is an application called ~setup~..Double click on it and install the software by following the instruction. then connect your mobile your mobile to the computer....
Jan 26, 2011 | Nokia 6030 Cellular Phone
How do i change my NAT to open on my tenda W307R
Im only a couple years late, but i spent an hour on my computer last night to figure it out. Enter your ip adress in the top bar thingy. Enter your username and password. You should now see something with the selections "System Status, Setup Wizard,etc" on the side. Click on Virtual Server. Under Virtual server, you should see something called "DMZ Settings". In there, enter the ip adress of the computer/console you want to open the NAT. Click enable, the hit apply. Your Done.
Nov 26, 2010 | Port Designs Tenda W307R-103421 Router
The computer can't hibernate when conected with
1st, I would turn off the screen saver and make sure it's not interfering.
2nd, would see if there where any updates on your manufacturers site for any hardware in your computer.
3rd, I would go into msconfig and disable all startup items, restart computer and see if that helps and maybe something running in the background is interfering
Please let me know if any of that makes a difference.
Mar 03, 2010 | ASUS G1 Notebook
Will not post
its failing the power on self test and say it was defective and send it back and get a new one
ive had to sought out a few laptops recently and one got to setup but kept corupting hdd and it damaged the hdd beyond repair so get a new one if you can
to se wehterh it is complety broke put a cd/dvd in cd/dvd drive and try to boot from it from what you said though i wouldnt bother and would just get a new one
ow i forgot to mention it could be somehting like a graphics car dproblem so load it up with built in graphics and cpu and no hdd conected
Sep 19, 2009 | Intel DG31PR Motherboard
CD in header and AUX in header
hi again
This is most likely not required on your setup since your equipment is newer. you can find more information about this here: http://www.pcmag.com/encyclopedia_term/0,2542,t=CD-ROM+audio+cable&i=39413,00.asp
I still prefer using the analog audio cable on CD/DVD drives on slower older computers
Mar 31, 2008 | Computers & Internet
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
