Question about Proform Pro Series 1500 Treadmill
Calibration Instructions for Proform Series 1500 treadmill
Can someone give me the calibration instructions for a proform series 1500 treadmill. Thankx
  • 64 Answers
SOURCE: Proform 450 X treadmill powers on, but trips current when started
There could be a combination of problems. I would first start with disconecting the motor leads and see if it trips the breaker. Then elevation motor would be next if no change from disconecting motor. More than likely it's a motor issue.
Posted on Jun 08, 2009
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
Posted on Sep 12, 2009
taran_2005
  • 10515 Answers
SOURCE: Proform 765 treadmill slows down when step on. Do
More likely time to replace the belt. Let me provide you with all the information you need. This information is already there on many websites.
BELT LOSES POWER
(Bogs Down or is Sluggish) This condition is when the treadmill operates normally without a person on the belt and then slows down when someone steps on the belt or when the treadmill operates normally for a given period of time with someone on the belt then abruptly begins to slow down.
There are four typical causes for this problem (listed in order of our experience:
1) The walking belt and/or deck are worn. (85% of the time)
2) The walking belt and/or motor belt are too tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has demagnetized. (5% of the time)
4) The controller is dropping output. (2% of the time)
Walking Belt is Worn:
The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. To test the deck, go back to the Troubleshooting section and download the belt and deck inspections instructions. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but most this tests works well upon). Fewer steps indicate high friction.
The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating the friction problem. On some heavily worn walking belts, this test will not eliminate the problem.
Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank down the belts and on treadmills, tighter is not necessarily better. The
tighter the belts, the more the drive system has to work to keep everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3” without straining. Tighter belts should be loosen but make sure you don’t create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating position. Loosen the belt if too tight. Make sure to test for slipping and if it does with the proper tension, replace the motor belt.
Needs Brushes / Demagnetized Motor:
Typically when we find a motor that has lost torque; it needs a new set of motor brushes. Typically we can make brushes for almost any motor if we don’t already stock them. Motor demagnetization is not that common but it does happen and it is normally easy to diagnose. If you have confirmed the belt and/or deck is not worn and the belts aren’t too tight, you can test for a motor torque problem. DO NOT USE YOUR HAND OR ANY OTHER BODY PART TO IMPEDE THE MOTOR…YOU WILL LIKELY LOSE YOUR BODY PART IN THE PROCESS IF THE MOTOR IS GOOD. The step to test for the motor is to use a foreign object preferably on a long shaft. First determine the direction of the motor spin (most have directional movement printed on the motor tag), then apply pressure with an object with downward pressure on the flywheel in the direction the flywheel is turning (do not attempt to put force against the rotating direction of the flywheel as you can easily injure yourself). If you can slow the motor, typically you need brush replacement.
To test for demagnetization, the motor must be disassembled. Once you have the motor retaining bolts removed, remove the motor core by sliding it out of the end of the housing. If the magnets pull the core against the housing and it is difficult to remove, the magnets are good. If the magnets do not attract the core, the motor has to be replaced.
Controller:
This is the most uncommon of the causes. Typically replacing a controller in this situation will not solve the underlying problem and then you will end up replacing a belt as well as a control. Normally if a control is dropping output, it will do it with a person on the belt or not. Tests of DC output dropping is normal in many controls since they have a current limiter which will automatically drop output to prevent burning up the board. This is best diagnosed by eliminating the other possible problems first. If you are left with the control as the cause, replace the control.
The site :-
http://www.treadmilldoctor.com/Treadmill-Belt-Bogs-Down
Any further assistance, let me know.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Oct 10, 2009
gymtech
  • 18 Answers
SOURCE: Treadmill is slippng badly
There should be an allen head bolt on each side at the rear of the treadmill going throughthe rear cover into the tail [rear] roller. Turn each one 1/4 turn at a time equally untill slipping is stopped. If belt tracks more to one side tighten slightly more on that side.
Posted on Feb 08, 2010
maxtreadmill
  • 832 Answers
SOURCE: How do you calibrate a ProForm 530x Treadmill?
To calibrate the speed and/or incline, please refer to the instructions that are under the motor hood cover or are mounted on the inside of the belly pan. Be sure to unplug your machine. If the instructions are not there, please contact our customer service department at {~1-888-533-1333} while you are near your machine.
Posted on Apr 11, 2010
My treadmill won't go down the platform how to lower it please help
If it is stuck in the incline position all you need to do is re-calibrate most of the time
The first step to re-calibrate the incline. ProForm provides calibration instructions in the treadmill owner's manual.
Hold down the "Stop" button and the "Speed" up button. Insert the safety key into the console then release the "Stop" and "Speed" buttons.
Press the "Stop" button then press either the "Incline" up or down button. Wait while the treadmill raises then lowers the incline ramp. Press the "Stop" button and remove the safety key.
Hope this helps or solves the problem, if you have any further questions please do not hesitate to contact us at 888-713-2880 or visit us online at
http://www.sportsmith.net/supportsearch.aspx
May 18, 2015 | Proform 1050T Treadmill
970 Proform Treadmill Console
Run the software calibration, go under the HOOD cover motor, and see the instruction, for easy diagnostic and fix it. God bless yo
You must clean the speed sensor, and lube the elemation motor.
Jul 16, 2013 | Exercise & Fitness
Proform Treadmill Memory Test Flash Fail
Run the software calibration for easy diagnostic and fix it.
Go under the Hood cover and see the instruction.
God bless you
Jul 07, 2013 | Exercise & Fitness
Proform 400 GI - Treadmill
go under the HOOD cover the instruction for RUN the software calibration for easy diagnostic , and fix it.
God bless you
Jul 07, 2013 | Proform 400 CT Treadmill - Treadmills
Proform power 995 treadmill incline button not responding after initial calibration
I suggest to RUN again the software calibration, and read carefully your instr. manual for to remember anything
However see the diagram attached, and lube the gear, shaft of the elevation motor, and tight any connectors or plug ,clean it.
God bless you
Nov 25, 2012 | Proform Power 995 Treadmill
Proform 860 treadmill, want to undo incline feature, & use it without it
Run the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
May 16, 2012 | Proform 860 Competitor Treadmill
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
The proform 980 turns on but just goes to incline
It is trying to its starting point I would suggest is to unplug the unit open the motor shroud unit. The shroud it has a mini manual this should have a calibration instructions that can be done and also upper electronics self test to see if the processor is functioning properly. It should give a better idea which to head. You can call Icon Fitness@ 1-800999-3756
Apr 30, 2010 | Proform 980 CS Treadmill
Apr 10, 2010 | Proform 530 Treadmill Walking Belt
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Jun 17, 2009 | Proform Sport 1000 Folding Treadmill...
Proform Pro Series 1500 Treadmill Logo
71 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
