My laptop ASUS X58L Not Booting My Bootable USB Flash
I want to boot my Bootable USB Flash in My Laptop Asus X58L But i Dont No I can I Boot My Bootable USB with Ghost Imaage File
billyatlas
  • 6 Answers
SOURCE: My Asus Laptop M2400N Will not boot up
If it boots in safe mode it means there's something the the startup causing problems. To find it, start in safe mode - run MSCONFIG from the run command - Select the Startup Tab - click diable all - reboot. If its till doesn't startup do the same with the services tab. from here its a process of elimination. Tick boxes on and reboot. You should then identify what's causing the problem - also check the event viewer in safe mode as that may also provide a clue.
Posted on Jun 10, 2009
rcirone203
  • 70 Answers
SOURCE: hp 530 booting problem
Check to make sure you have it plugged in and not working off the internal battery. Sounds like a low battery power shutdown.
Posted on Jul 11, 2009
sys_admin
  • 829 Answers
SOURCE: dropped something heavy on my laptop asus x58l now
Get the screen replaced as its can be a Physical damage . Did you find any damage on the screen. Good Luck
Posted on Jan 30, 2010
  • 93 Answers
SOURCE: I can't seem to get
Start up the computer and hit F10 a few times during start-up and login to the BIOS and check that the USB drive precedes the hard disk and CD/DVD drives in the boot order. Use the + and - keys to move the boot devices up or down within the boot order. After you have completed this, hit the ESC key and then choose Select Save Changes and Exit. The computer will now attempt to boot from the devices in the order you have specified.
Would you kindly rate my answer please if this has helped resolve the problem - thanks :)
Posted on Oct 22, 2010
haydz28
  • 115 Answers
SOURCE: Asus laptop is slow in
Go to start/ type msconfig on the search box/click the start up tab, a system configuration box will appear/click the disable button to uncheck all the programs that has checked, the only 1 ur going to disable is the antivirus, so look for it and check. Click apply and ok. Your pc will asked you to restart the NB. It should start up much faster after this procedure.
Hope this helps.
Posted on Mar 20, 2011
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
How to unlock Administretor password Asus K43U Laptop ?
Depends on the OS of the laptop.
There recovery disks or create one.
For most windows OS, you use a third party tool.
Some Tools ate CD based while some use USB bootable pen/Flash drive. So ensure you know your laptop supports boot from USB option.
7 Free Windows Password Recovery Tools
Jul 17, 2016 | ASUS Computers & Internet
Asus k50ij usb boot
Get you favorite bootable ISO image and using "ImageWriter.exe" application (under Windows 7/8) you could "transfer" the ISO to your USB device. In that way, your USB device becomes a bootable device. To boot from a USB device, your laptop should be "equiped" with a proper BIOS. Go to BIOS and change the boot order by having your USB stick already inserted in one of USB port (otherwise, you couldn't select to boot from USB!)
Instead of "ImageWriter.exe" application, you could use also "Win32DiskImager". For any of them, google it!
Jul 12, 2014 | ASUS K50IJ Notebook
No usb boot setting in available in Asus laptop aptio utility version 2.01.1
You can't because the usb root hub won't work until the PC boots. You'll never get the pc to boot from the usb drive with that bios version.
Nov 15, 2013 | ASUS " 14"" Laptop - 8GB Memory - 750GB...
How can used activated booting form usb or sdcard on my asus notebook k45dr
Make it 1st boot in BIOS. Plus it must be bootable. Plus you will need 3rd party software like Novicorp Win to Flash.
Feb 25, 2013 | Computers & Internet
"asus" laptop boot from bios
Hi.
If you are trying to install Windows 7 from the USB flash drive then you need to configure the drive so the system will see it as a boot drive, see link below for instructions on how to do this. If you have Windows 7 installed on the flash drive then the boot files may have become corrupt thus preventing you from booting into the operating system. Link for installing Win 7 from USB below >>>>>
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
Regards.
Feb 04, 2013 | ASUS Computers & Internet
How do i format my Eee pc 1000ha
You have to make a bootable stick with the desired operating system, or must have an external dvd rom and the operating system boottable disk. Make sure BIOS is set to boot from removable devices (press F2 when booting, modify: boot -> boot device -> boot device priority so you boot removable devices first, save the new BIOS settings).
For bootable stick click here
May 02, 2012 | ASUS Eee PC 1000H Laptop
Usb boot
If you have set it to boot FIRST from the USB drive, I would suspect that your USB drive is not bootable. Either that or it is defective.
Another cause could be a bad USB port.
Apr 29, 2012 | ASUS Eee PC 904HD
Problem regarding booting the laptop
first, check if the hard drive is detected on bios. if it's not then try reseating it. restart computer and enter advanced boot options (by pressing f8 upon restarting). select last known good configuration then press enter, if it still doesnt load windows, restart system and enter advanced boot options again and select safe mode. if it still doesnt boot then you need to reinstall windows.
you will need to get an external cd/dvd rom in order to reinstall windows.
you can try copying the windows disc content onto a flash drive and boot from it but that method is not guaranteed.
Dec 01, 2009 | ASUS Eee 4G Notebook
How to make bootable pen drive
A FEW THINGS BEFORE YOU DO THIS....
1. Your Laptop has to support booting from a PEN DRIVE. Some BIOS's may refer to your pen drive as a USB floppy or USB zip.
2. The USB flash(pen) drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. Below is a utility from HP that you can use to make your pen drive bootable.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=MTX-UNITY-I23839&jumpid=reg_R1002_USEN
Mar 26, 2009 | Computers & Internet
Computers & Internet Logo
275 people viewed this question
David Payne
David Payne
