Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
Posted on Jan 02, 2009
Motor Wiring I have an inoperable Jazzy chair that needs new batteries and who knows what else. I would like to keep the drive wheels and motors. Each motor has 4 wires, 2 white, 1 red, 1 black. I assume the 2 white are for forward or reverse. How do I wire these to run full forward with no speed control?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on May 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2766
Points
Two white wires are for the electric brake.  When the wheelchair is turned off while on an incline, the motors automatically lock up, preventing the wheelchair from rolling backwards.  The white wires disengage the electric brake when power is applied.
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Apr 03, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
20786
Points
48
Programmable through the joystick, need programmer
Jazzy 300. Tight drive wheel. Clicking naise
It's possible that the clicking noise is being caused by a loose or worn-out component within the left drive wheel of the Jazzy 300 power wheelchair. The tightness of the wheel could also be contributing to the problem.
To diagnose the issue, you may need to inspect the left drive wheel and its components, including the motor, axle, bearings, and any other parts that may be causing the clicking noise. Tightening any loose components or replacing any worn-out parts may help to alleviate the issue.
It's always a good idea to consult with a professional technician or the manufacturer of the Jazzy 300 power wheelchair for specific troubleshooting advice and repair recommendations.
How move ypushing--battery dead
On the back of the chair, there is a lever that dis-engages the drive motor to allow you to push the chair.
Jazzy 600 stops all of a sudden while driving, chair icon and wrench icon on romote appears
Likely 2, 3, 4 or 5 bar flash code. If motors are made by a company like "ELE...." then motor wiring is likely bad inside wire insulation where wires go into motor cap. Rebuild motors and try again. This is a common problem with these motors.
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
7helpful
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
7helpful
Chair won't go. Lights flash
Check your freewheel levers. They must be engaged or the lights will flash and the chair will be inoperable. These levers are under the shroud behind drive wheels. (One on each side)
Jazzy chair pulls left
Since each drive wheel has it's own motorand both are controlled by the joystick you can narrow it down to the motor opposite the side it is pulling to (probably not the joystick programming if it was working before). However, there may be another answer: if your home has a lot of carpet, or worse a dog, check where the wheel mounts to the drive motor and clear anything that might be wrapped around the wheel axle into the motor, similar to what happens to a vacuum cleaner brush wheel.
4helpful
Where do I find a wiring diagram for the jazzy 1103 ?
Here's a link to the Pride Tech Manual guides. Click on the 1103 for a PDF file.
http://www.prideservice.com/TechnicalProductGuides/technicalproductguides.asp
The wiring is pretty simple and straightforward. These operate on a 24VDC system provided by two 12VDC batteries. Power from the batteries goes to the controller into a Joystick/controller combo. It leaves the joystick down to each motor/gear/brake assembly. Power to the batteries comes from the charger which puts out 28VDC, with a 120VAC input. Very rarely does any of the wiring go bad excepting those people who grossly overload the chair, or run it into fixed objects at full speed. Other mishaps with overamping are caused when somebody tries driving over unstable surfaces like sand, gravel, mud/wet grass and spin the motors. This drives the controller crazy because its job is to keep the chair pointed in the right direction, and with wheels spinning, it doesn't know what to do. Overheating the motors or controller, or both. There are two sets of "brushes" on each motor that carry the current from the batteries to the motor. These are located under a black-plastic slotted screw port at the ends of each motor. Removing the plastic screw reveals the brush. It should have a flexible semi-copper lead that shows no evidence of overheating, or brittleness, and should be about 3/4 of an inch long. If 1/4 of an inch, it should be replaced. Check all four. Good luck.
1helpful
Batteries run low fast on jazzy jet 3, heard brakes might be failing or motor needs replaced after replacing batteries?
one battery was low,,,,not sure if anyting else is bad, used chair...by having only one battery low, it ran down the chair...
Jazzy 1200 power wheelchair is electrically inoperable after owner fell on back of chair at night. Battery was charging at time of accident. Believe problem may be in multi-pin connector betweenjoystick...
When you say inoperable I am assuming you are not getting a flash code on the joystick. I would check the wiring from the charge meter on the rear? console - you will see a yellow slug in the harness that has a fuse in it - check all the wiring from the meter as this can cause a 'power loss' problem. Of course, check the battery connections as well.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
