Question about GE Refrigerators
GE YLT-15 no power
Outdoor timer with remote control. When I plug outdoor timer part into outlet, the power light does not illuminate and the outlets on the timer have no power.
jgwhomeequip
  • 1902 Answers
SOURCE: Refrigerator is getting no power
Check the relay and the compressor with a volt meter. Make sure that you are getting proper voltage. 110 - 120 volts at both the relay and the compressor. If nothing happens or everytime you try to test and the circuit keeps popping first check for bad wiring make sure nothing has come loose. If all the wiring checks out including the ground then the only thing that will pop a circuitbreaker is a bad compressor meaning it is drawing to many amp and you will either need to have a company replace the compressor for around 600 dollars or get a new unit
Posted on Feb 21, 2009
aasc
  • 1606 Answers
SOURCE: GE Artica, pulsing lights
Your refrig display , has lost communication , with the main control board , located , behind the refrig , behind an 8 " X 10 " panel . The control board , is easily replaceable , with 7 or 8 plugs , attached to it . The part number , for your board , is WR55X10942 . It runs about $150.00 .
Posted on Dec 09, 2009
Testimonial: "You confirmed what we thought was the problem. Thank you for taking the time to respond!!"
  • 3 Answers
SOURCE: Westinghouse 3-Outlet Outdoor Heavy Duty Digital Photocell Timer
http://www.thencc.com/westinghouse/LS/Instruction/28499_TimerManual.pdf This is the manual that you seek!
Posted on Jan 06, 2010
  • 351 Answers
SOURCE: whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Posted on May 05, 2010
jyackle5
  • 8197 Answers
SOURCE: i need the owners manul
You can get the manual on the link beow.
http://www.hardwareinnovations.com/pdf/SA_220_IB60642_73.pdf
Good Luck
Posted on Nov 28, 2010
Timer is programed & is currently in off state but my stuff is still on
Specifically which timer do you have??
1) Reset timer to Clear programming, and then reprogram being careful to avoid overlaps and conflicts that can cause timer not operate as expected.
2) Move timer to different outlet.
3) Test outlet with circuit analyzer
4) Try plugging different load into timer. For example a light bulb instead of pump.
5) Check rating plate on timer and on pump to see if they are compatible.
For example Sylvania SA-210 outdoor timer is rated for 1/4 Hp at 120Volts
http://waterheatertimer.org/Sylvania-timers-and-manuals.html
While Intermatic P1261 timer is rated for 2 Hp at 120volts
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#outdoor
Jul 17, 2012 | Sylvania SA210 15 Amp Zip-Set Digital...
On sa 210, when timer off (either from program or manually switched off) correct "bulb off" status is displayed on the indicator, but the power doesn't go off from the outlets. this problem...
Most digital timers can be restored by resetting timer and then reprogramming.
http://waterheatertimer.org/pdf/Sylvania-SA-210-Manual.pdf
Sylvania tech support: 888-548-4484
Sylvania timer has 1 year limited warranty.
Sylvania timer can be used for 1000W incandescent Loads and Motor loads up to 1/4Hp
All outdoor timers are susceptible to power surge from nearby lightning.
Timers are also affected by line noise and incorrect outlet polarity.
Test outlet with circuit analyzer. Use timer to control different Load on different outlet.
If more than one timer has same problem, then suspect can be line noise and outlet polarity.
Heavier-duty Intermatic HB8800RCL timer has limited lifetime warranty, and controls 1800 watts and 1/3 HP.
http://www.amazon.com/Intermatic-HB800RCL-Seven-Outdoor-Digital/dp/B001KBZUNK/ref=pd_cp_hi_2
Aug 05, 2011 | Sylvania SA210 15 Amp Zip-Set Digital...
How do you program a Tork 602A timer? I can't get mine to cycle on and off at a desired time.
The Tork 602A mechanical outdoor timer with 2 grounded outlets.
Tork 601A and 602A manual
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Manual has images of timer that will help.
Plug timer into outdoor outlet.
To set current time, rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Dial is divided into light and dark sections that represent day or nighttime hours.
Reset time after power outage.
96 pins located around timer dial are used to set on-off times.
Each pin represents 15 minutes in 24 hour day
Move pins in-or-out with fingernail or ink pen to set timer on-off functions.
With Tork timers, usually when pins are out, timer is ON.
When pins are in, timer is OFF.
To double-check pin setting, manually rotate timer to watch when lights turn on-off.
Set multiple ON/OFFs each day.
Change on-off times by resetting a pin or two.
Timer repeats every 24-hours.
Manual ON/TIMER switch is located on inner dial.
Set Manual switch to TIMER for programs to operate.
To override time and turn on Load, move override to ON position.
Dec 09, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
How to program a intermatic outdoor timer/photo control hb51rc
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
1. Turn dial selector to the "off" position and
plug timer into three conductor outdoor outlet.
2. Turn dial selector to timing interval
desired (i.e., 2 Hrs, 4 Hrs, 6 Hrs, 8 Hrs,
dusk to dawn, etc.).
3. Plug outdoor lights into Easy-Setâ„¢ Timer -
lights will turn on automatically at dusk.
4. Lights turn off 2 4 6 or 8 hours later
depending on dial selection
Dec 07, 2010 | Intermatic Outdoor Timer/Photo Control...
How to set a GE outdoor timer product ID 51587 ?
GE 51587 has same instructions as Tork 601A single-outlet outdoor 24-hour mechanical timer.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
With GE timers, usually when pins are out, timer is ON.
Manual ON/TIMER switch located on inner dial.
Set override to timer for program to operate.
Dec 06, 2010 | GE 51587 MultiEvent Timer
I have a holiday living 6 outlet yard timer and i lost my directions....Model # lx28006
Woods brands sells timers that are packaged and sold under various names and numbers.
For example GE sells same yard stake under their brand.
Woods 6-outlet yard stake manual:
Add a comment and say if this is your timer manual.
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
Dec 05, 2010 | Hardware & Accessories
I HAVE MODEL #83643B POWER STAKE AND 15 FT DIGITAL TIMER AND HAVE LOST THE INSTRUCTIONS ON HOW TO SET THE TIMER CAN YOU PLEASE TELL ME HOW TO SET THE TIMER
That sounds like the Woods 17321 Dusk-to-Dawn yard stake
Product image:
http://www.amazon.com/Woods-17321-Outdoor-3-Outlets-6-Foot/dp/B000BHN4H8
Manual
http://waterheatertimer.org/pdf/Woods-17321.pdf
If this is not your timer, check following page:
http://waterheatertimer.org/Woods-timers-and-manuals.html
Instructions:
Yard stake control outlets, and turns ON automatically at Dusk
Rotate dial to set options:
Rotate to OFF > outlets OFF
Rotate to ON > outlets ON
Rotate to Dusk-dawn > outlets on at dusk and off at dawn
Rotate to 2 4 6 8 > outlets on at dusk and off 2 4 6 8 hours later
Dec 05, 2010 | Woods Outdoor Lighting Timer
How do I use SKU: 15112 timer
GE 15112 timer manual:
http://www.jascoproducts.com/support/manual-downloads/applications/DocumentLibraryManager/upload/Outdoor-15112-Manual-eng-spn.pdf
Same as Tork 652A manual
http://waterheatertimer.org/pdf/651A-652A-manual.pdf
Made for permanent outdoor usage. Outdoor usage only.
Timer has 2 grounded outlets located bottom of timer, maximum wattage for both 1000Watts
50-mini-bulb string of Christmas lights is 25 Watts
Plug timer into 125 Volt GFCI protected outlet.
Do not plug timer into extension cord.
Indicator light shows when timer has power.
Timer turns ON automatically at dusk.
Plug lights, small pump, fountain, motor into grounded outlet located bottom of timer.
Rotate dial to choose timer function.
Rotate dial to select timer function
- ON at dusk & OFF 2, 4, 6, 8 hours later - Rotated dial to number shown on dial
- ON at dusk, OFF at dawn - Rotate dial to dusk-dial
- ON continuously - Rotate dial to ON
-OFF - Rotate dial to OFF
Dec 03, 2010 | Jasco Ge 8HR Mechanical Blk Timer 2 Outlet...
Need instruction sheet
Your unit has a lifetime warranty. Go to this website to get the instructions in PDF format:
http://www.hardwareinnovations.com/pdf/SA_210_IB61056_33.pdf GOODLUCK
SA 210 Zip Set Outdoor Digital Timer with 3 Outlets features a Zip-Set One-Step Set-up where you simply enter your area code and the timer is programmed. Your lights will automatically turn on at sunset, and auto-adjust for seasonal time changes. Other features include a random setting for added security, a 7-5-2 setting for full weeks, weekdays, or weekends. Battery back-up (batteries included) to save resetting time in the event of a power failure. It has 2 timed outlets, plus 1 extra untimed outlet for use with other products. It has an easy-to-read, large illuminated digital display, and 15 amp capacity. Lifetime warranty.
Product Description
Zip-Set™ Technology with One-Step™ Set-Up Two Timed Outlets + 1 Untimed Outlet Controls three Products Simultaneously Controls Outdoor Landscape, Security and Holiday Lighting, Pool/Spa Pumps and Engine Block Heaters Optional 4 On / 4 Off Settings Random Settings for Added Security 7-5-2 Feature allows you to set times based on the 7 Day full week, 5 Day work week, or 2 Day weekend Large Illuminated Easy-to-Read LCD Display & Keypad Battery Back-Up (battery included) saves resetting time in the event of a power failure Weatherproof 15 Amps Lifetime Warranty
Dec 22, 2008 | Sylvania Hardware & Accessories
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Lawrence Oravetz
okcchemist
Level 1 Expert
