Question about Stihl Garden
Does a stihl 064 flywheel fit an old stihl red eye 066
    Sergeant:
  • Stihl Expert
  • 417 Answers
What's a red eye? If the first four numbers from the old flywheel match up with the ones on the replacement, they should swap. I'd suggest just getting the correct one instead of trying to jerry-rig a chainsaw. eBay is a great resource for used parts and they're usually fairly cheap.
Posted on Nov 28, 2014
5 Suggested Answers
  • 520 Answers
SOURCE: What is the red light
here is a copy from an article i was reading
It features a "red light" on the right hand side above the tuning screws which illuminates at a set RPM to assist in tuning the high speed mixture screw, which is great when using the saw out in the field as no tachometer is required to give the saw a quick tune before commencing work. It allows peace of mind knowing that your saw is always tuned correctly and not running a lean mixture which causes damage very quickly. Incorporated with this "red light" system is a rev limiter, so even if the saw is tuned incorrectly it will not allow the saw to over-rev due to a lean out condition and blow up the saw!!
Posted on Jan 02, 2011
steve_lima
  • 181 Answers
SOURCE: stihl chainsaw 066 died
mr siegs
remove the muffler and look inside the cumbstion camber and look at the piston.if you see marks (score) on the piston the piston and cylinder are bad and need to be replaced.this is caused from a lack of lubercation to the cylinder,possible water in fuel,spraying starter fluid into the saw,bad oil to fuel mixture,old fuel has no lubercating value.any more questions please feel free to contact me
Posted on Mar 12, 2009
SOURCE: STIHL CHAINSAW MIXTURE SETTINGS
one turn high and low 66 has compesator carby willrun rich up high but will lean under load
Posted on Sep 03, 2008
barterjoe
  • 338 Answers
SOURCE: keep burning up piston on
It sounds like you are running lean. Not a lean oil/gas mix but a lean Air/fuel ratio. This engine runs hot as a high performance engine. any air leaks such as crank seals, manifold gaskets or muffler gaskets can give you too much air for the fuel coming in.
Secondly from the fuel side:
Ethanol (curse it) combines with oils that have no nondispersants making a white chalky poweder in the fuel system causing less fuel to mix with air. any blockage or pin hole leak can cause less fuel to be brought into the engine thus less cooling and lubricating.
Your carburetor and fuel filter need to be serviced and adjusted correctly or they will affect the mix.
When done the engine should run no faster than 13,000 rpm top no load speed.
This engine should idle smoothly at 2,500 with no more than 150 rpm change
if the speed is not as listed above when the rebuild is done you need to go back into the machine.
Call up a shop like www.arcolawn.comto get a EDT8 tach. it is well worth the money.
good luck
Joe
Posted on Feb 12, 2011
Will a 56mm cylinder kit fit a 064
http://sawparts.ca/products/stihl-064-066-ms650-ms660-big-bore-cylinder-kit-nikasil-56mm
It seems that YES a 56mm aftermarket cylinder is available for the Stihl 064. Looking at the kit you need to just replace Cylinder, Piston and rings, bearing bush and clips. Worth also replacing the base gasket too.
May 01, 2016 | Stihl Models 064, 066, Ms640, Ms660
How to remove 064 clutch drum
Remove the E-clip, release the chain brake and the drum should lift off.
Here's the breakdown manual
http://www.mediafire.com/view/gzzx6a0g0xc3591
Apr 04, 2014 | Stihl Models 064, 066, Ms640, Ms660
Stihl Parts Diagram
You aren't a dealer or technician so you don't get to have one. I can sell you one, mommaNOSPAM5744@hotmail.com. You remove the no spam when you type it obviously
Oct 21, 2013 | Stihl Models 064, 066, Ms640, Ms660
Oil leak in tank
There are only a few ways for oil to be leeking
1. Crank housing gasket (most likely culprit)
2, Rubber O-ring on filler cap
3. Rubber seal fitting to Oil pump inlet.
4. Crack in the crank housing
Jan 25, 2013 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 carb diagram
Don't mess with the insides of a STIHL carb, just buy a new one. Why put new parts in an old carb?
Jan 18, 2012 | Stihl Models 064, 066, Ms640, Ms660
Sthil 066 chainsaw
You are absolutely right, an 066 is a STIHL model chainsaw. Good job!
Looking for a parts diagram for a stihl 066 chainsaw
The one with the two right angle connectors is the inlet line. The other is the return line
Nov 05, 2011 | Stihl Models 064, 066, Ms640, Ms660
Parts diagram
You don't get to have one, you're not a professionally trained STIHL tech.
Oct 02, 2011 | Stihl Models 064, 066, Ms640, Ms660
Garden Logo
163 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
