Question about GE Refrigerators
Samsung french door refrigerator 8a 88 code no fans are running
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
SOURCE: samsung refrigerator
There is a screw down foot in front of each forward wheel under the fridge. You can access this by looking under the front corners.
Posted on Apr 16, 2008
robmattie
SOURCE: GE French Door Frig control panel blinking temp #s
I had a very similar problem with our GE refrigerator. The main control board looked to be the culprit. I took out the board and did a visual inspection. Upon inspection I discovered that the (2) 470 micro farad capacitors were blown. I checked the power diode near these and it was still ok. I went to Radio Shack and picked up two 470 micro farad - 35V capacitors for and grand total of $2.60 and resoldered them myself. The refrigerator has been running great since. If you want to know more details email me and I will be happy to let you know what I know. I didn't want to pay $100 for a GE guy to replace a board either!
Posted on Aug 10, 2009
  • 1891 Answers
SOURCE: Samsung French Door Refrigerator not cooling
it's only 4 weeks old ./ don't mess with it it has a warranty you may void it if you work on it . it is probably in the main digital control in th fresh food .. but i would call the seller and they can set up a service for it .. mm
Posted on Dec 24, 2009
heatman101
  • 43501 Answers
SOURCE: Samsung refrigerator Not cooling below 45 degrees
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
dffg
Posted on Sep 29, 2010
Freezer temp is ok ref.temp too hot. fan doesn't seem to be operating
That model is twin cooling. Are you having any error codes on the display? Most models will shut off the fan when you open the door. If there are no error codes the thermistor could be out of range telling the fan not to run. You could try putting the refrigerator into diagnostic mode. You can look that up or reply I could tell you how to do it.
Mar 24, 2016 | Samsung RF217ACRS Bottom Freezer French...
Why is it flashing code 8Y?
88 8Y is a icemaker error code if no icemaker on that model,not sure you may have to get samsung invovled.
Jan 16, 2016 | Samsung RF265AA Bottom Freezer French Door...
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Why is my Samsung french door/freezer not working
It is very rare to have a freon leak. It is possible but there are there are things that can cause the refrigerator not to get cold. Is the compressor running. Are the fans running. Is the freezer or refrigerator coils blocked with ice. Usually freon is the last place i look.
Jul 23, 2014 | Samsung RF265AA Bottom Freezer French Door...
My samsung model RF263AEPN is flashing an 88 89 after the power went out
This is taken directly from the Samsung website:French Door: Why Is The Display Blinking 88 88 And Not Responding?Cyber
Drastic power fluctuations such as power outages and surges can cause electronic device to behave abnormally. If the refrigerator display is showing 88 88 (all eights) and is still cooling properly, unplug the refrigerator for 60 seconds and then plug it back in. If the display returns to normal after approximately 2 minutes service is not required. However, if the display does not return to normal service is required.
Sep 23, 2013 | Samsung RF263AEPN French Door Refrigerator
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
Jul 22, 2012 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Samsung side by side RFG297AAWP display shows 88 88
Press and hold the energy saver button, and the lighting button at the same time until it beeps and clears, 10 seconds. When it goes back to normal panel do the same thing again which will put the fridge in a running diagnosis mode and see if any parts of the 8's are flashing, if so look on the back of the fridge at the error codes.
Nov 24, 2011 | Samsung RFG297AAWP Side by Side Bottom...
Not cooling... error code 88...
I can fix this for you,
What is the last thing you did before the issue started?
Jan 13, 2011 | Samsung RF265AA Bottom Freezer French Door...
heatman101
dffg
Mar 14, 2009 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
