Question about Xerox Office Equipment & Supplies
Start up loop xerox 7545
The machine starts up after switching on but does not switch to ready, instead it starts the start up process again. The question mark light blinks all the time.
dg9dotorg
  • 151 Answers
SOURCE: on/off button blinking
Did you check your particular models warning lights page? Maybe your head cleaner is full or the printer needs maintenance. Take a look at your printer manual to see what the warning lights signify. Sometimes printers reset if you remove the plug from the back then push the power button and plug it in again while your still pushing the power button. Then you can try turning it back on normally again...
Posted on Dec 09, 2007
SOURCE: Printer turns on, then goes off... Seems like its in a loop
Hi tommilligan,
unplug the power cord from the printer and press and hold the ON button for 10 secs and try connecting to diffirent wall outlet directly.
regards,  raj_p5983
Posted on Jan 20, 2009
rj_8017
  • 22 Answers
SOURCE: LG flatron L1730S: Starting problem
change the power section capacitors..
Posted on Feb 10, 2009
  • 788 Answers
SOURCE: hp 6820s will not power up.
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
Posted on Sep 28, 2009
benwabnick
  • 2404 Answers
SOURCE: Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
Posted on May 01, 2010
Brewing stops end cycle
Sounds like safety switch (heat sensor) check warranty
Jun 03, 2016 | Saeco Coffee Makers & Espresso Machines
Xerox Printer not starting, A fault has occurred. Fault Error 116-201
The problem description is: Fault Code 116-201: HDD Was Not Booted Due to an HDD Error Detected on Booting. Try this link first: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=387,E=0000000005750000208,K=9799,Sxi=3,Solution=obj(542)
If this does not work. Unplug the machine from the wall while still on
do not power down first. treat it like the power just went off in your building. While the machine is still off not plugged to the wall. Press the power button several times. This will erase any saved info on memory.
Plug machine back on an try again. If it does it again you will need to replace your hard drive and that will take a service call.
Dec 10, 2015 | Xerox DocuColor 3535 Copier
Cleaned waste toner out but xerox 7545 wont ecept it says to replace waste tone
You didn't clean the bright plastic bubble at the upper inside end.
If dirty, machine thinks it is still full of toner.
Jun 24, 2014 | Xerox Workcentre 7545/PT 7545PT Color...
My A42T wo't finish loading the Ifit software. which means the treadmill won't start. The software is stuck in a loop. How can I reset it or get out of this so I can use it? Thank you.
Turn it off from Machine build switch, then turn it of from mains, then unplug it from mains, wait for some time and then Plug it to mains, switch on from mains and switch on local machine switch. If the process above fails, you should contact the Dealer or Authorized Service Center.
Apr 26, 2014 | Epic A42T Platinum Treadmill
Xerox dc 260 incident code 042-322
I have a Xerox DC-250 machine. Few days ago come a fault code 042-322, 1st I replace front door interlock switch & ready the machine. Next day morning when power on the same code come back, then I replace the MCU PWB & ready. Next day again same code, I replace the Xerographic Drawer & ready. Next day same code. So please help me how it possible to solve this problem for permanently?
Feb 05, 2011 | Office Equipment & Supplies
Xerox Phaser 8550 error code 07,01043:90804
This fault occurs due to the printhead being stuck in the tilted position. There are many reasons why this fault will occur, too many to mention.
More often than not, your problem will require the printhead and process gear to be re-aligned in order to get a reboot but sometimes it is possible to get a reboot by doing the following;
Turn the printer off, wait ten seconds then turn it back on again. Wait for the printer to start warming up to about 5 or 10 percent. At this point, switch the machine off again by the machine switch NOT your wall/plug switch. Wait ten seconds and switch on again. Now let it run through its normal cycle. The success rate for this method is small, possibly only 1 in 30 machines will recover.
The reason this will sometimes work is that, when you turn the machine off from the warm up, it powers down using its proper head parking routine, you will notice, it takes a while to shut down. If the original fault was due to say a power cut or someone pulling the plug out it is possible for the printer to find its home position and boot ok.
Unfortunately, a lot of the time, the reason for the fault is printer related and such, this method does not work. But it is always worth a try.
Hope this helps.
Jan 19, 2011 | Xerox Office Equipment & Supplies
Hi, we have a C525A but has not been used for the last 2 years. When I started it today I got an error code 016-370 with message Reboot Printer. I have powered it down and up for several times but didn't...
You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
Keep me posted abt the end result...
Oct 11, 2010 | Xerox DocuPrint C525A Laser Printer
171 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
