Question about Kodak EasyShare C142 Digital Camera
Saya punya kodak easy share c143 kenaa jika tombol on/off di tekan dilayar kamera terdapat tulisan Lens Obstructed....???
4 Suggested Answers
SOURCE: saya punya kamera digital kodakc142,
2 minggu yang lalu saya beli kamera digital kodak c142, tapi saat mau dipakai tidak bisa konek(terbuka)/digunakan, lensa sudah keluar tapi dimatikanpun tidak bisa, akhirnya saya lepas baterainya (lensa tetap tidak mau masuk). mohon solusi ya.
Posted on Feb 08, 2011
  • 11967 Answers
SOURCE: The lens is stuck open
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous interiors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particles that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Apr 06, 2011
  • 11967 Answers
SOURCE: when my kodak c143 turns
Posted on May 04, 2011
Pada saat menekan tombol power camera digital tidak hidup atau mati , bagaimana solusi menghidupkannya kembali ?
saya mempunyai camera samsung ES95 baru dua bulan 4 bulan entah knpa pas saya mau pakai terus saya hidupkan/ tekan tombo; power nda mau nyala2 padahal kamera saya aman2 ajx kondisi sebelum saya hidupkan batrai full kondisi nda aman
ada yang tau nda gaimn cara hidupkan
terimakasih ???
Jul 13, 2012 | Fuji FinePix A345 Digital Camera
Printer canon mx 366 saya. error 5B00. tidak bisa berpungsi ketika di hidupkan muncul error 5B00. sudah dilakukan reset manual tapi tak ada hasi. masuk ke menu tidak bisa. mhn petujuk untuk masalah ini....
I have best solution for reset error 5b00 Canon MX366 about waste ink absorber full :
1. Fisrt step : entering service mode, using this method (dont use other method!) press & hold "stop" button and than press "power" button, release "stop" button and still hold "power" button and than press "stop" button about 5 times ( 1, 2, 3 , 4, 5) and release "power" & "Stop" button.
2. Printer will be entering to Service Mode with indicators " Printer LCD to become full drak and CPU detecting new hardware (dont do anything).
3. Download Servicetool V 1074 for Canon IP2770, download and entering to this Sofware.
4. prepare paper on the printer and Clik "MAIN" on the Menu Servicetool V1074, if success canon MX366 printing "D=000.0
5. turn off Canon MX366 and remove power cord, wait about 60 second, reinsert power cord and turn on your printer,....... o la la la your printer was normal,..... ( ngono ae kok mumet)
6. if you have any qustion, send your email to : alfa_centrino@yahoo.co.id, thanks God bless U
May 15, 2012 | Office Equipment & Supplies
Hp nokia n95 udah lama mati karna rusak, saya serviskan dan udh bisa, yg jadi permasalahan saya lupa no lock kode hp saya, bagaimana solusinya?
Solusinya anda bisa melakukan Master Clear atau biasa disebut dengan Formating.
caranya :
1.matikan Ponsel
2.tekan dan tahan tombol Hijau/Tombol Panggil + * + 3 + Power
3.Tahan antara 5 sampai 10 detik hingga ponsel hidup dan
logo nokia berkedip,lalu lepaskan semua.
4.Setelah hidup anda diharuskan Melakukan setting ulang Negara,bahasa,dsb.
Dan itu tandanya Ponsel anda sudah sukses untuk Master Clear,dan otomatis tidak lagi terkunci.
Semoga bermanfaat ya...
Jan 21, 2012 | Nokia N95 Cellular Phone
Lense obstracted
yaa. lensa saya tidak bisa menutup kembali, ketika di sambungkan ke pc terdapat tulisan lens obstracted. bagaimana cara mengatasinya?
Dec 20, 2011 | Kodak M522 Digital Camera
Power on lensa tidak mau keluar.muncul tulisan turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN ditampilkan pada layar LCD saat Mekanisme Lensa macet atau ketika terpengaruh oleh kerusakan apapun. Jika memutar power on dan off lagi tidak menyelesaikan pesan kesalahan, coba lakukan reset kekuasaan dan Inisialisasi pilihan.
Melakukan reset tenaga manual
Matikan kamera.
Keluarkan baterai.
Tekan terus tombol daya selama 30 detik.
Biarkan kamera untuk tetap tanpa listrik selama 60 detik.
Masukkan kembali baterai.
Hidupkan kamera.
Untuk mengatur ulang Kamera kembali ke default pabrik, pilih Opsi Initialize dari Menu Utama Pengaturan 1 dari Kamera ke OK.This akan mengatur pengguna menentukan pengaturan kembali ke default pabrik. Gambar-gambar dan video tidak akan bisa dihapus.
Jika masalah berlanjut, mungkin diperlukan layanan.
Terima kasih telah menghubungi FixYa.
Feb 23, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
Bagaimana cara membuka kunci kawalan pada tv philips macth line 60" saya binggung ? karna tombol menu pada remote tv saya tidak tersedia...mohon di bantu ...thks before
adalah tihis adalah apa yang Anda berbicara tentang harapan ini membantu. jika tidak posting kembali
Philips set menggunakan kode empat digit untuk mengontrol v-chip. Kode override untuk set Philip 0711, meskipun mungkin mengatakan tidak benar kode yang pertama kali untuk menipu Anda. Jika kode yang ditampilkan salah, cukup masukkan 0711 lagi. Untuk menggunakannya tekan tombol MENU untuk sampai ke menu. Ke atas atau ke bawah sampai Anda mencapai atau SMARTLOCK kunci otomatis, tergantung pada model, dan menekan tombol panah kanan pada remote. Masukkan kode override, dan masukkan untuk kedua kali jika yang dikatakannya itu benar menu. Setelah di kunci otomatis SMARTLOCK atau, pergi ke BLOK, dan tekan tombol panah kanan. Pergi ke PILIHAN PEMBLOKIRAN dan tekan tombol panah kanan. Pergi ke MASTER LUMPUHKAN dan tekan tombol panah kanan sehingga mengatakan MASTER LUMPUHKAN ON. The v-chip sekarang ulang.
Dec 01, 2010 | Philips Magnavox 27MS343S 27" TV
Error 5202
printer 5202
malam ne aku dapat memecahkannya dengan coba-coba ternyata berhasil..
[b]untuk error 5202.[/b]
1.matikan printer jangan cabut kabel powernya.
2.tahan tombol resume kemudian tekan tombol power.
3.lepaskan tombol resume, tombol power tetap tahan.
4.tombol power tetap tahan, tekan tombol resume 4 atau 5 kali (mungkin 5 kali)
5.lepaskan semua tombol. printer akan hidup seperti normal. jika tidak ulang lagi dari 1-5.
6.jika sudah bisa, tekan tombol resume berkali-kali, 1 kali, 2kali, 3kali, 4kali, 5kali.
7.jangan pakai ngeprint dulu, masuk ke maitenance printer, klik roller cleaning,
tapi sediakan kertasnya 3lembar aja biarkan kosong 3 kali agar printer menghentak 3kali, masukan lagi kertas agar printer tidak sempat eror.
8.kalau kurang jelas add aja ke fb saya
khoirilnizam@yahoo.co.id tapi beri penjelasan konsultasi masalah printer,
sebab kalau tidak saya kurang mau menerima pertemanan kalau tidak jelas
tujuan, maaf ya? selamat mencoba.
Oct 13, 2010 | Canon PIXMA iP1200 Photo Printer
Saya punya kamera digital kodakc142, tapi setelah di play hasil rekamanya g ada suaranya, tolong dong, gimana cara nya biar bisa punya suara
Oct 07, 2010 | Kodak EasyShare C142 Digital Camera
Hasil photo saya terdapat goresan warna putih vertikal kalau pas photo di bawah sinar matahari
Saya punya kamera canon a470 kalau dibuat photo ada garis putih sedangkan dibuat video hasilnya baik apa permasalahannya juga diback uap pada komputer sama hasilnya dengan camera mohon penjelasan.
Sep 24, 2010 | Canon PowerShot A470 Digital Camera
Kodak EasyShare C142 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
