Question about Sport & Outdoor - Others
Lower unit oil change on 1995 40 hp johnson
4 screws in total , but no real indication which ones are for draing or venting or filling,pumping
Howdy, John here, I have a 40hp 1995 Johnson, of the 4 screws, two are screws and two are plugs, the top one is the vent and the bottom one is drain and fill. Oil is forced in from the bottom and out the top to prevent air pockets.
After filling, install the top plug first, then remove the filling device and install the plug.
You can get an online(pdf) service manual subscription from www.seloconline.com
Posted on Mar 28, 2009
How do you service lower unit on a 1989 Johnson outboard motor?
What do you need to do? It is easy to open the two screws to drain lower unit gear lube but drain into a container and not on the ground. I have a pump that I use to replace the lower unit lube. Pump hooks up to quart or larger size lube supply. I have seen U TUBE videos if you need instructions.
Nov 01, 2017 | Johnson Boating
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Gear oil change. how much oil
Each gear case has two plugs - an upper, and lower. Take both plugs out and fill from the bottom till lube starts to come out the top plug. Do not fill from the top plug as an air bubble may prevent the case from getting filled completely. Gear lube is usually sold in a squeeze bottle or there's pumps available. If it takes more than one bottle, simply switch bottles, or put your finger over the hole till you get the lower plug back in. In colder climates it's best to change the lube each fall. Inspect the drained lube (old lube) for water. Water will either settle to the bottom and come out first or the lube will have a yellowish color. If there's water present - have the seals checked/replaced before refilling. Sometimes it's simply replacing the seal around the plugs. Do not let water in the lower unit freeze, as it can crack the Aluminum casing. Smaller engines might take a pint, and larger take a quart - but have extra on hand and make sure it comes out the top hole. Also check for drip spots on the floor if stored.
May 27, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
Lower unit oil
On the lower side of the gearbox,below the line of the prop shaft,you will see a screw that is about10-15mm across.This is the drain for the g/box oil.If you look above that screw about 150mm(6 inches),you will see another screw the same.It may even be marked 'oil level'.Remove them both.
Checked the drained oil is not milky.It's a sign of water and the propshaft seal would need to be replaced.
The oil bottle you buy will have a tapered nozzle.You must fill the g/box from the LOWER hole by sqeezing the bottle.When it comes out of the UPPER hole,the g/box is filled.Quickly put the lower screw back in first,and then the upper screw.Done.
Before you refill the g/box,check the washer/seal on the screws and make sure they are still good. Hope this helps
Jul 09, 2010 | Boating
How do I check the oil level in the lower unit of a 70 hp Johnson outboard?
remove the bottom drain screw first then place a tube of the proper lower unit oil in it. then remove the top screw and gently squeeze the tube of oil and when full it will slowly come out the top drain hole. when it does replace the lower plug first then the top plug second. make sure the seals are in good shape and plan on changing the oil in the lower unit yearly for proper maintainence. make sure you buy oil designed for your particular type of motor. good luck.
May 29, 2010 | Boating
I need lower unit lube capacity for johnson 200 horse power out board
there is none listed . you fill them from the bottom plug with the top plug removed . when lube comes out the top hole it's full . put top screw back in which will not let oil out the bottom then put in the lower plug
Apr 10, 2010 | Boating
Have a Johnson 130 leaking gear oil on bottom of foot and bottom full of water
What year model? Tools you will need. (1)gear case pressure tester from any outboard dealer. why buy and not build. matching the threads on the drain plugs.(1) detergent and water in a spray bottle. troubleshooting step (1) Remove lower unit from engine as if you were changing the impeller.(2) secure lower unit in a holder so you can drain oil and do visual checks.(3)remove drain plug and vent plug, drain oil(4) reinstall lower drain plug and put pressure tester into vent plug hole(5) pressurize gear case(6)with spray bottle spray gear case at all seals and joints just like you would spray a tire looking for a leak. detergent will bubble at leak.(7) if you find leak at a seal were you will need to remove drive shaft or propeller shaft you will have to buy removal tools and a Clymer repair manuel from your local dealer.(8) hopefully the leak is at the shift shaft or the drain and vent plugs so you wont have to buy special tools to replace seals.(9)if you find a crack in the case have it welded at you local outboard dealer
Nov 03, 2009 | Boating
I have drained the oil from my lower unit on my 180 bow rider boat. how do i put the oil back in ? all yhe oil hase drained even from the resivor in the moter compartment . it is a 3litter moter.
Not quite a car question but basically you fill it the opposite way that you drained it. You can purchase a pump at you local marine store that attaches to your quart bottle of lower unit lube.
On the end of the pumps' hose there is a threaded fitting which screws in to where the drain plug goes. leave upper vent plug out.
Pump the oil into the lower unit until it comes out of the upper vent hole.Then remove the hose from the lower unit and quickly replace the drain plug.
Wipe the excess oil off of your hands. :)
Oct 25, 2009 | Chevrolet Silverado Cars & Trucks
2000 regal boat were is the screw to drain fluid in out drive
Look under the foot of the lower unit on one side of the nose cone. Slotted head screw with magnet. This one is used for draining and filling with the top one being the indicator for it being full.
Oct 08, 2009 | Boating
I have a 1976 65hp mercury outboard how do i change the oil
The drain/fill hole are the same. Put a coffee can or something like that to measure the amont of oil that comes out. Check with a boat parts, or marine or sporting goods section of biggy store. They (at least to) make a pump assembly with hose and threaded end that fits into the hole for the lower unit screw. the other part of the pump fits in a gear oil quart bottle. 80 or 90 is no matter, but needs to say marine grade or suitable for marine use. Nothing special, Penzoil for sure and I think a company Lubrite plus many others make an OK oil. Anyway, put the pump in the bottle and put back in as much as drained out. The level may be marked on the side of the lower unit. If you don't get almost as much out as you put in, check for leaky seal too.
Jun 12, 2009 | Boating
Sport & Outdoor - Others Logo
222 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
