Question about Sub-Zero 642
SUBZERO 642 DRIP HOSE
WATER LEAKING FROM REFRIGERATOR
    Director Badge:
    Uploaded 100 video answers.
  • Sub-Zero Master
  • 488 Answers
CLEAR DRAIN LINE, VERY COMMON PROBLEM - TRY TO PUT SOME TUBE INSIDE AND CLEAR EVERYTHING OUT OF THERE. I USE 1/4 " TUBE. HOPE IT HELPS
Posted on Apr 19, 2014
  • 4 Answers
SOURCE: subzero 550 water drain in refrigerator section backs up
The problem is that the water freezes in the drain, either because the door is not sealing good, it's open too often or there is mold in the catching tray and tube. Best solution is to take a turkey baster (pump), disconnect the flexible tube from the tray, by pulling down, take a large cup with very hot water mixed with a spoon or 2 of Clorox, fill the baster with that mixture and pump it on the drain tube. You have to do it several times, water will come out, but do it until you hear a "woosh" sound and the water goes freely on the drain. Also spill some of that mixture in the tray so it kills the mold.
Posted on Apr 17, 2008
  • 56 Answers
SOURCE: Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Posted on Jun 13, 2009
projdoc
  • 2237 Answers
SOURCE: Although my sub zero 642 is holding the
it's condensate from the evaporator coils. when the humidity collects on the coils, it should drain into a pan under the fridge that gets evaporated from the hot-side line. check to see if the condensate tube from the coils is still in the pan.
Posted on Jul 29, 2009
  • 102 Answers
SOURCE: Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Posted on Aug 05, 2009
  • 102 Answers
SOURCE: Sub Zero 642 side by side stainless steel leaks water from right
remove the crisper drawers and you will see a drain trough and a drain line . One or both is most likely blocked. If you pull the drain line off the trough usually you can clear it with a turkey baster filled with hot water
Testimonial: "Problem solved, thank you!"
Subzero 650 Drip tray full of water and factory grease....
Grease or oil,,,,,its common for some oil but if its excessive it could have a leak "refrigerant leak"...Does it cool?
Jul 25, 2015 | Sub-Zero 650 / O Bottom Freezer...
Does a refrigerant leak mean we must replace the evaporator of our subzero 642 side by side?
Thank you for all this important information. Your units average life span is or can be up to 30 years, with this being say. The rule of freon is 5% less in a 12 month period is allowed, over that it this unit must be fixed, charging a leaking unit with out a plan to fix is against EPA guidelines. Now Verify the age of this unit, if 12 years or younger the parts are covered under factory warranty. You can call the factory to verify this if you like. Back to your question, yes the evaporator is most likely the reason of less freon. I personally change 4 to 5 a month during this time of year. Your evaporator part number is 4204430 and a drier 7006964 is needed also. Call subzero for assistance if you like. Good Luck, remember your unit was and investment for this is just a maintenance issue after about 10 years.
Aug 08, 2014 | Sub-Zero 642
LCD panel and lights not working
On your Sub-Zero 642 Your display will not work unless your refrigerator lights work.
1st. Make sure your light bulbs are good.
2nd. Check your refrigerator door light switch.
3rd. The subzero uses a thermal overload to kill your lights if the door is left open to long.
http://www.on-timeappliance.com/subzero.html
Mar 26, 2012 | Sub-Zero 642
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Subzero 642 Ice maker issue
Called repair service that seller recommends.
Aug 22, 2009 | Sub-Zero 642
Sub Zero 642 side by side stainless steel leaks water from right door. evaporator pan is dry, water/ice dispenser door catch basin is dry. Several times per day water collects right under the stainless...
Jul 01, 2009 | Sub-Zero 642
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Subzero 642
if you fridge runs for 6 cycles with out a cycle off .. your vacuum condenser light will come on. you can check the evapator if there is only a frost on the top ar an Ice at the top ...you have a leak and will need to have the evapator replaced...let me know if it helps
Jun 10, 2008 | Sub-Zero 642
Refrigerators Logo
80 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
