Question about Canon PIXMA Office Equipment & Supplies
Cannon pixma mp560 error code u043
Replaced all ink
SOURCE: MP500 ink tank cannot be recognized error U043
I had the u043 problem on the blue cartridge on my mp830.
I was using non-original replacement inks but re-using the chips from the originals - replacing the blue cartridge would cause it randomly work but i then noticed the chip holder was not centred so I realigned it and hey presto! the problem was solved first time.
Posted on May 14, 2008
I have a canon mp510 pixma same message U043 and a u150 fault.
I cant see any chip to replace and have replaced my original cartridges with a non branded cheaper type, this might be why. Does this make a difference or is this the same problem occurring with replacement canon cartridges as well.
Dont want to buy genuine ones if its not going to make any difference.
Anyone who can help me would be appreciated
Posted on Jun 25, 2008
SOURCE: Cannon PIXMA MP150
I wrote this on another help site I thought I'd post it here.
Let me just say this I have had many dealings with this printer type.
Before we start what needs to be done is that the two little filters under the printer carts need to be cleaned as well as the two little rubber parts housing the filters; wash these in water (after taking out of the printer) the filters should come up white-ish.
Also make sure that while you have the filters out to clean in and around that area with a cloth / tissues something to absore excess ink. After you clean this however you still need to service resert your printer.
The method for doing so is worded very badly on alot of sites so I will explain my way.
(1) have your printer power down ie. off, just to make sure pull the plug out and wait 10 seconds.
(2) plug printer back in, now Hold down the Stop/Reset button don't let go.
(2a) push and hold the on/off button
----at this point both fingers are holding down the buttons.----
(3) take your finger of Stop/Reset, pause maybe a second now press stop/reset button once and then press again and hold.
--- both fingers at this point are hold down both buttons----
(4) take your finger off on/off and now finally take your finger off stop reset.
---wait for the printer to go into its service mode ie. wait maybe 30 secs a min whatever till the printer carage has moved back into ints original spot.
---after this has occoured you should be able to press Stop/reset to cycle though the options
each time you press Stop/Reset Alarm and on/off should alternate lighting up. Hope this helps.
0 time Green Power off
1 time Orange Service pattern print (auto teste)
2 times Green EEPROM print (dados da EEPROM)
3 times Orange EEPROM reset (EEPROM reset)
4 times Green Waste ink counter reset (Absorvente reset)
Also google MPtool and downlad that this can reset your ink carts to full again, and can help with other errors, BUT your printer needs to be in low level mode. Google that I can't find that at the moment.
Hope this helps good luck
Posted on Dec 10, 2008
cene765
  • 787 Answers
SOURCE: cannon pixma mp510 ~ error code 5100 help
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Posted on Nov 19, 2009
  • 74 Answers
SOURCE: cannon pixma mp145 printer error code e7 & e2
E2: Reload the paper correctly and press [Black] or [Color].
E7: The cartridges are not installed in place.
These are from the manual.
Posted on May 10, 2010
Whenever i turn on the printer i get a error 6C10
This error is related to the ink absorber/waste ink tank located internally in the printer. Normally you would have to send your Canon to be serviced to resolve this problem, but there is a video turotial on YouTube that shows how to reset this error: Canon MP550 Ink Absorber Reset (6C10 Error Code) - YouTube
Jul 19, 2014 | Cannon Office Equipment & Supplies
I have a cannon mp560 printer and receiving a error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. I would contact Canon Support to find the closest location to take it to or send it to. Thanks, Rick.
Jul 29, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP560 ink level override
Just press and hold down the STOP button :) Works a treat :)
Dec 28, 2009 | Canon MP560 All-In-One InkJet Printer
Error u043 with MP610 Cannon. cyan cartridge not recognised, tried new cartridges, same error. RESET DOES NOT FIX PROBLEM
This error indicate that the printer fail in detection the certain ink. The simplest one is to compare the ink tank with the good one. If this doesn't fix the problem,carriage unit or logic board might be faulty.
More information
Nov 29, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I get the U043 error on my Magenta. Cartridge is set properly.
Ink tank not installed.
[1660]
U043 (Applicable ink tank
icon)
The following ink tank
cannot be recognized.
Install the applicable ink tank(s) properly,
and confirm that the LED's of all the ink
tanks light red.
Sep 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
U043
The U043 error code indicates that an ink tank is not installed. One or more ink tank icons on the LCD should also be lit up. The lit up icon indicates the applicable ink tank. Verify these tanks are indeed fully seated in the print head and that they are lit up red.
You can also press the OK button to clear this message and continue.
May 19, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Error U043 - Ink Tank Cannot be recognized
Try to open and close the main cover a bit, ... ink recognition will start and may solve the probleme ...
... otherwise remove the cartridge and clean the chip contacts e.g. with spirit
Maybe also pressing the stop/reset-button for >10s will also help to continue printing, but in this case the fill level of the cartridge will no longer be shown
Apr 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Nov 14, 2007 | Office Equipment & Supplies
404 people viewed this question
old marine
old marine
