Question about Canon PIXMA MP470 All-in-One Printer
Error 5100 we have restarted, disconnected cables, restarted, etc and still are getting the error 5100
  • 4,041 Answers
Hi You can Try 2 things.
Ok here try this good luck
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
Dimension 5100 wont start up .power led on MB is on changed mb.shorted out test done fan went.nothing else.what next ???
I have seen more than a few of these (Dimension 5100 series) die due to mainboard issues. If you haven't done so already, take out everything you can, (add-in cards, modem, disconnect hard drives, CD drives, etc.) Try to restart. If you get it to boot, you can add in one item at a time, and realize that when it won't start that is probably the culprit.
Next, If you have a second PC that has known good RAM of the same type, I would swap that out as well. Then try to boot with just video, Mainboard and RAM. If you see any blinking lights/sounds/etc. then report that on here as well. There are beep codes and on Dell's there are light error codes.
I you do happen to have a spare CPU, you could swap that out as well if you can, but I would not bet that is the problem as they are pretty durable for the most part.
If none of these comes up with a booting PC, it could be your replacement mainboard is bad.
Mar 19, 2011 | Dell Dimension 5100 (D51L1) PC Desktop
SERVICE ERROR 5100
for error 5100 usually i turn off my printer, then disconnect the usb cable then connect again to computer
then i turn on my printer again
try it
i hope this helpful
thank you for using fixya
Feb 19, 2011 | Canon PIXMA iP1300 Printer
Error 5100
Issue: ERROR: Service error 5100 appears while printing from the computer
1. Allow print head to cool down
2. Disconnect and reconnect the USB cable to ensure a secure connection
3. Press ON/OFF switch to reset the multifunction device
4. Reseat ink cartridge (MP160 / MP180 / MP460)
5. The MP180 may require repair
Try the above..
Oct 18, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Bis failure, media cable and insert boot disk
first step to check whether its a hard ware or software issue .........disconnect all the external devices and disconnect the power cable from the back of the computer , then press and hold the power button for 10-12 secs with the power cable disconnected and then reconncet only the power cable and restart the computer and check whether it restarts or not.................shut down the computer and while u restart the computer keep on tapping f8 key on the keyboard and on advance boot options select last known good configuration and hit enter and see whether it restarts or not .......................after that shut down the computer and while u restart the computer keep on tapping f9 key on the keyboard and do the diagonistic test and see wat error do u get if u get any biohd-8 then the hard has gone bad , if u get any other error then jast open the tower and reseat the hard drive and the sata cables , the hard drive cable will be jst below the dc/dvd driive looks lik a bunch of multi colured cables .............and also reseat the sata cables i.e a red ribbion like cables and restart the computer and see ....
Jun 08, 2010 | MPC Computers ClientPro 345 G PC Desktop
My kodak 5100 all in one printer will not print out my documents but only prints out what is on my scanner, how do i solve this?
did you recieved an error message printer not responding? If yes please double check the icons of printer on the printer and faxes, if you can see 2 icons delete both icons and unplug your USB cable, then restart computer.
Now if the computer is already restarted connect USB cable then try to print.
there are several reasons why it will not print using computer, there might a problem on USB cable and its connection or the drivers., Please verify the problem, or you may contact kodak toll free 1 800 421 6699. hey will help you on this issue., Gudluck!
Nov 04, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I have an older model MP130 and have a service error 5100. The printer will not work at all. What can I do to fix this and/or do I need to take it in for service? Thank you.
Go to Canon support here and enter "service error 5100" into the search box; you will get detailed instructions for correcting this error condition. (If you click on highlighted results, details ensue.)
The general instructions are as follows:
Solutions for service error 5100
Issue: ERROR: Service error XXXX appears while printing from the computer
4. Remove foreign object from paper feed area (MP130)
5. The MP130 may require repair
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 28, 2009 | Office Equipment & Supplies
Printer does not Communicate (connect) following Microsoft SP3
Try this, uninstall the printer drivers and shut down the system.
Disconnect the USB cable and restart the computer.
Once in windows reconnect the USB cable and let windows find the printer and install it.
If it asks for the CD insert it and follow the onscreen prompts.
Jan 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
Acer 5100 help me
hmmm..sounds like a bios issue...F2 when you start..and then check the drives to see that they are all present and enabled.
Mar 17, 2008 | Acer Aspire 5100 Notebook
Canon PIXMA MP470 All-in-One Printer Logo
49 people viewed this question
old marine
old marine
