I have a SHARP AR-5125 copier, when you turn it on it displays E7 (call for service)if you push the start button it then displays F5.
    Novelist:
  • 163 Answers
Error f5 = Exposure lamp blown
error e7 =Main board malfunction
means needs repair.
Posted on Jan 02, 2009
  • 15,935 Answers
You can try cleaning the white strip, and darkening the black line on the end with a sharpie. Most of the time this requires a new CCD.
  • blueextc3221
    blueextc3221 Jan 02, 2009
    For clarification....
    A charge-coupled device (CCD) is an analog shift register, that enables the transportation of analog signals (electric charges) through successive stages (capacitors) controlled by a clock signal. Charge-coupled devices can be used as a form of memory or for delaying samples of analog signals. Today, they are most widely used in arrays of photoelectric light sensors, to serialize parallel analog signals. Not all image sensors use CCD technology; for example, CMOS chips are also commercially available.
    "CCD" refers to the way that the image signal is read out from the chip. Under the control of an external circuit, each capacitor can transfer its electric charge to one or other of its neighbors. CCDs are used in digital photography and astronomy (particularly in photometry), sensors, electron microscopy, medical fluoroscopy, optical and UV spectroscopy and high speed techniques such as lucky imaging.
    President:
  • 2,110 Answers
The lens of the machine (CCD) is not "seeing" correctly the white strip located underneath the exposure glass, this may be because of accumulation of dirt in optical section+lens. OR/AND the exposure lamp is dirty/blown (or its fuse).
Laser bad is very unlikely but still possible.
Check al these out and let us know what resulted. A full cleaning service should be the first step.
    Master:
  • 413 Answers
You are leaving out part of the code so follow the link to this site and it will tell you what the code is telling you.
http://www.copierhelper.com/codes.php?mode=err&make=5
    President:
  • 1,990 Answers
Welcome to Fixya! You Definately need to get the Machine to a Qualified Service Center. The Codes are Very Similar.
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
My sharp al2021 showing f5-02 and e7-11 what can do to work
The service manual was not available for the AL-2021 but the error codes are the same for the AR-5316
F5-02 error cause and remedy
Sharp AR 5316 Service Manual Page 27
E7-11 error cause and remedy
Sharp AR 5316 Service Manual Page 26
Jan 07, 2015 | Office Equipment & Supplies
Display error code E7
Sharp copier AR5516 not working. Error code E 7 kindly help.
Jul 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Feb 28, 2009 | Sharp AR-M205 Copier
Copier turns on but will not copy
There should be a sub code for the E7. Depending on the sub code is what the error exactly is.
Jan 02, 2009 | Sharp Office Equipment & Supplies
AR201 displays e7
Could you be more specific? e7-03 is trouble in your laser unit, e7-04 is dirt on your inside white strip which helps your copy lamp find the home position, and e7-05 is trouble with your copy lens.
Apr 28, 2008 | Sharp AR 201 Copier
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Computers & Internet Logo
David Payne
David Payne
