Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Replacement of lock and unlock lever
Need to know how to replace lock and unlock lever. Thanks, John
    Problem Solver:
  • 12 Answers
Look for my posts on "Removing the motor cover". The lock is under the motor head. Its easy to find and fix.
Posted on Mar 16, 2009
How to tighten kitchenaid mixer motor head locking lever?
Adjust the head height first, flat paddle should just clear the bowl. Te head height adjustment can be seen in by the hinge looking from the front when the head is raised. Screw in (clockwise) to lower and out to raise. You cannot get the head lock right when head height is miles out
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Head moves when mixing
Have you tipped it upside down and checked the grub screw up inside the pedestal. It is for locking the hinge pin tightly into the tongue on the lower motor housing. If that doesn\'t solve it you really should get a Kitchen Aid service agent to look at it. They should be able to get it locking again without wrecking anything. Don\'t leave it wobbling about or it will get to the point that parts will have to be replaced. If you must mix a batch up hold the head down and lock that lever forwards as best you can while it\'s running. Too much forwards pressure on that lever can bend the rod inside so easy does it.
Mar 30, 2014 | KitchenAid Food Mixers
Head won't lock
It sounds like the latch, link & lever assembly need to be replaced, it does require taking apart the mixer, but is a fairly easy fix.
Here is a link to the replacement part:
And also here is a link to the service manual:
Page 15 will specifically talk about replaceing that assembly.
Jan 17, 2014 | KitchenAid KSM95 300 Watts Stand Mixer
Head Lift Lever retaining spring fitting ?
Request the service manual by contacting Kenwood directly.
Dec 20, 2017 | Kenwood Food Mixers
Speed lever replacment
The Service manual will walk you through removing the old speed control lever in an artisan mixer, and how to put it back together correctly.
Here is a link to the service manual:
Pay attention to pages 7 and 11 as these cover the removal and replacement of the speed control lever.
Let us know if you have any questions.
Thank you,
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Motor head locking lever is hard to unlock on Kitchenaid mixer after kneading dough.
Hello Flyfishing19,
The problem that you are experiencing is due to the torque that is put on the head while mixing dough. The lock is still working fine, although it is getting wear. You can replace the locking mechanism. However, it will work for a while longer. If you want to change the mechanism post back to this thread and I will be happy to locate you one and explain how to change it.
Mar 06, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My KitchenAid tilt head lock keeps coming loose while beating small amount of dough allowing the head to wobble gradually bad? This is the second mixer with same problem! I've heard some people talking...
In my case the lock was not engaging fully because the internal mechanism was bent too short. I'm not sure if this happened over time or if it is just a manufacturing defect. If your mixer still has some up-and-down play to it when the lock is engaged, then you might have the same problem as me
To fix it, search this site and others for instructions on how to remove the motor cover. I found this video useful:
With the cover removed you have access to the locking mechanism. In my case, the latch is connected to the locking lever via a bent S-hook. The hook was just slightly too short which kept the latch from engaging completely. If you remove the two screws holding the hook in place and that allows the lock to close completely, then you have the same problem as me. (You'll feel the difference immediately. When fully locked, there is practically no wobble in the mixer head.)
I lengthened the hook by placing it against a flat surface and hammering the bend out a bit.
Jan 05, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Speed control lever stuck or locked. How do I unlock it?
Hi BROOKLYNX. To answer you primary question, no there is no special speed control knob lock that you?ve inadvertently triggered. OK, so without a lock why?s your speed control knob stuck? It most likely that something broken inside your mixer to lock it into position. I wouldn?t continue to operate your machine as you are doing. It?s not good for the electric motor, the electric cord or the plug. It would be better to determine the root cause of your control knob?s obstinacy. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select one of the files listed under Parts List (check to see it this matches your mixer model). Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer, along with all the parts. You?ll want to focus on part #s 2, 3, 4, 5, and 6, which is our speed control assembly. Check to see if something isn?t blocking you?re the movement of #3. You should be able to determine if something has broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order:;;; Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on the gears, etc. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. Good luck and have fun. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Nov 30, 2009 | KitchenAid K45SS Classic Stand Mixer
I need help in correctly reassembling my Kitchenaid KSM 150 mixer. I used the help on the web to successfully take apart, clean and regrease my mixer. However, I have not yet been able to successfully...
First dissconnect the power supply.Next, the locking hook must be facing towards the back of the unit. However the lever itself must be placed inside the bottom portion of the unit going out to the side. Next you need to connect the metal link to the lever and UNDERNEATH the locking hook. Once you have done this you can now put the screw in to hold down the lever. Your one speed problem could be caused by the adjustment screws that are connected to the main board at the bottom. if these are not set correctly and most importantly EVENLY the mixer wont operate correctly. The next possible solution is that the main control board is faulty and would have to be replaced part number for the board is w10119326. Also I have added this link from Whirlpool that you can use. Hope this helps. Thanks
Nov 11, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Mixer will not lock
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Hope this helps!
Nov 03, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
1,093 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
