Question about NComputing L230 Network Terminal
VSpace console NComputing. when i try to connect to the server the following error message pops up
5 Suggested Answers
SOURCE: NComputing L230 won't connect to host
First Please check your Lan IP Address for host pc.
change IP address and subnet mask on L230
disable firewall or any antivirus that is blocking ports.
Then you will get connected.
Posted on Dec 30, 2008
SOURCE: Dear Mr. , I have VMware
Hello Rana,
Please recheck which model number you are working with, since what you are describing sounds like the L300 and not the L230. If it is the L300, then you may have initiated a firmware update from the console or from within the device. We'd be happy to walk you through this -- please contact us online or by phone by going to: http://www.ncomputing.com/techsupport
Posted on Nov 11, 2010
  • 86 Answers
SOURCE: We are using L230 device
There were some issues with single core vs. multi-core processors with earlier versions of vSpace. Perhaps the two server/hosts you're using as a reference point are different in that one is single core, the other is multi-core. Regardless, my recommendation is to uninstall the vSpace software, reboot, run their cleanup utility, and reinstall the latest version. Before reinstalling, make SURE that you have applied any Service Packs and ALL of the current MS updates. Additionally, browse Device Manager and make sure there are NO missing or conflicting drivers. Do NOT, I repeat, do NOT install from the provided CD. As of this posting date, the cleanup utility is available here: nc-eng.com/tools/ncuninstall. The most up to date vSapce for L230 is on the NComputing download site. If you hit this post later and the supplied URLs are not valid call NComputing TS at 888-365-1210. Lastly do NOT forget to register the vSpace software.
Posted on Aug 15, 2011
  • 86 Answers
SOURCE: i was crate ncomputing network
Please explain your problem better so we can help you. Download current version for yourOS from the NComputing download site, install vSpace and reboot and register. Do NOT, I repeat, do NOT install from theprovided CD and upgrade. Simply install straight from the downloadfile I provided in the link. Lastly makeSURE you REGISTER vSpace. Be sure toenable the background hardware activation option. This is available on the last screen of theregistration or in the NComputing System console, under System Settings.
We are using L230 device and when we try to connect to the server the following error message pops up" terminal server is not at ready. please try a bit later". But when i use the same device to...
Jun 23, 2011 | NComputing L230 Network Terminal
Cannot connect server ...... client PC diplay this message
Can you PING the L230 device from the server? In other words, are you confident there is a clear IP path from server to device? Also, if you're running on XP, turn off the XP firewall as a test. If that works and you still want to run with the firewall on, then you'll need to specify specific ports to be opened up on your firewall or your domain's firewall policy. Those ports, as listed from NComputing's website are:
Port Exceptions
  • For L-series device connection
    • TCP: 27605, 27615, 3581, 3597, 3645, 3646
    • UDP: 1027, 1283, 3581
  • For vSpace registration
    • TCP Port 3630
    • Point to:
      • register.ncomputing.com
      • or 85.214.107.229
  • For vSpace Update
    • TCP Ports 20 & 21
    • Point to:
      • 70.182.176.102
      • or 81.169.173.128
      • or 81.169.173.128
Jun 12, 2011 | NComputing L230 Network Terminal
First l230 connect to vspace ok,then i installed safe360 , then l230 report "terminal server - yet not ready. please, retry ..."
What is Safe360, an AntiVirus or Firewall software? If so, the program may have inadvertently blocked port access to the kernel which vSpace needs access to for user sessions. Below are the port exceptions for firewall configurations and file exceptions for Antivirus configurations. Current as of this post.
  • Port Exceptions
      • TCP Port 3630
      • Point to:
        • or 85.214.107.229
    • For vSpace Update
      • TCP Ports 20 & 21
      • Point to:
        • 70.182.176.102
        • or 81.169.173.128
        • or 81.169.173.128
  • File Access Exceptions
    • For vSpace functionality
      • C:\Windows\system32\KMServc.exe
      • C:\Program Files\Common Files\NComputer\Bootsrv.exe
    • For vSpace tray icon
      • C:\Program Files\NComputing vSpace\KmMsg.exe
    • For vSpace Registration
      • C:\Program Files\NComputing vSpace\KmRegWiz.exe
    • For vSpace Update
      • C:\Program Files\NComputing vSpace\KmUpdate.exe
May 01, 2011 | NComputing L230 Network Terminal
Ncomputing server 2003 hang problem when user (L230) login to server
Make sure you're on the latest vSpace software for W2K3, that version is v4.9.5 and is available on their download site. The issue you mentioned will be resolved if you update your software and register it. Make sure to enable bakground hardware activation in the system settings. That's managed through the vSpace console.
Apr 25, 2011 | NComputing L230 Network Terminal
How activasi L130 (6 units), because the problem when the program is run L130 vspace this message does not appear activasi ... and now L130 could not connect to the server because it was past 30 days ..
Simply register your vSpace software, the registration wizard is part of the Program group.run that registration, takes less than 90s, and make sure you enable background hardware activation from the vSpace Console, system settings.
Apr 21, 2011 | NComputing L230 Network Terminal
Terminal server - yet not ready, please, retry attempt a bit later, with L230 and vista 32 bits
Uninstall any current version of vSpace. Reboot. Makesure you have no missing or conflicting device drivers inside of devicemanager. Then run the NComputing cleanup utility located here:www.nc-eng.com/tools/ncuninstall.exe. Download current version for yourOS from the NComputing download site, install vSpace and reboot and register. Do NOT, I repeat, do NOT install from theprovided CD and upgrade. Simply install straight from the downloadfile I provided in the link. Lastly makeSURE you REGISTER vSpace. Be sure toenable the background hardware activation option. This is available on the last screen of theregistration or in the NComputing System console, under System Settings.
Mar 21, 2011 | NComputing L230 Network Terminal
Cannot get license, because server send error code:47-ncomputing
Cannot get license, because server send error...47
what is solustion this prbloems
Jan 31, 2011 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Cannot get license, because server returns error code:-47 NComputing Error
Nov 18, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Dear Mr. , I have VMware server and I create VM on it with WIN XP SP3 and install VSpace in XP, after that when I'm trying to connect NComputing devices with that machine it appears that machine in the...
Hello Rana,
Nov 11, 2010 | NComputing L230 Network Terminal
550 NCOMPUTING PROBLEM
when i insert ncomputing cd in my computers drive and want to install ncomputing softwere the massege appearce that "NComputing vSpace not installed
Error report:
This software is hardware protected. Your hardware is not supported. Please contact NComputing Inc. or its partners to purchase supported hardware. plz solve my problem as soon as thank u
Jul 16, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
NComputing L230 Network Terminal Logo
46 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
