Question about Mach Speed Computers & Internet
Jumper settins for 5 pin audio connector on p4sd la motherboard
NO AUDIO AND I DONT HAVE THE OLD CABINET WHICH HAD THE FRONT AUDIO CONNECTOR NEW CABINET HAS A 10 PIN CONNECTOR
  • 13433 Answers
SOURCE: MOTHERBOARD AUDIO PIN CONNECTIONS
The pins are pretty much universal, I'm 90% certan that the other one of these is correct for you.
Posted on Feb 11, 2008
SOURCE: asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
F_AUDIO <==> CASE
1- PORT_1L == MIC_IN
3- PORT_1R == MIC_PWR
5- PORT_2R == R_OUT
9- PORT_2L == L_OUT
-------------- OTHER SIDE ------------- (case wire)
2- GND
4- GND (other)
6- R_Return
8- key
10- L_Return
Posted on Mar 29, 2009
preachw996
  • 1179 Answers
SOURCE: FRONT PANEL AUDIO HEADER PINOUTS CONFIGURATION HELP
It really is your choice. You can use the AC'97 or HD but not both. Follow the wiring for the choice you select. Personally I'd go with the AC'97 setup as alot of games have issue with the Realtek driver. Hope this helps.
Posted on May 04, 2009
bad_theta
  • 31 Answers
Look this picture below, this is ASUS P4VM front panel.
Hpe its solve your problem....
Posted on Jun 01, 2009
  • 227 Answers
SOURCE: Asus P4SD-VL Motherboard manual wanted
I didn't find your exact model number, but if you want a detailed manual of your mobo the this is the link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
As I did not find your model number, please recheck the model number. If your numbers are correct you should be able to find the documentation you desire at the link above.
Posted on Aug 02, 2009
Audio wiring problem on HP Compaq DC7100 CMT with DC7700 motherboard
You have a problem with HP connectivity. When I moved my dx7100 motherbard into another casing I experienced that error and also chassis fan not detected error. Chassis fan error is easy to remove, You only need a fan with at least 3 cables (with sensor) and plug it into 4 pin chassis fan connector. Audio conector have 10 pins (eight pin missing for orientation (with followed numerication
2 4 6 10
1 3 5 7 9
If you only want to get rid of the error ( with no use of back audio(use of another soundcard)) then short pins 2 and 7. But if you want to use back connectors, then you must bridge with jumpers 1-3 for microfone, 5-6 for audio L and 9-10 for audio R.
I've bee searched thru internet and didn't find this trick anywere.
Feb 24, 2013 | HP Compaq dc7600 Convertible Minitower PC...
I have an xw9400 board on a normal case,after connecting usb on board with the front panel,board still cant recognize front USB,i need to change wires in the connector to match the board,same thing with...
The front USB header on the XW9400 board has a ground connected to pin #10. The USB standard #10 pin has nothing connected to it, so HP uses it to sense whether a connector is attached to the header.
Apr 01, 2011 | Computers & Internet
917-Front Audio Not Connected
Please connect front audio cable with motherboard in the a audio port of motherboard.If we work with sound card then connect front audio cable with sound card.
Feb 12, 2011 | HP Compaq dc7100 PC Desktop
How connect audio front panel in gigabyte g31 motherboard my cabinet is odyssey plz solve my query Nilesh Bhanushali
hello bhanushali19
my name is ausi.
the front panel audio header pins on most gigabyte motherboards is at the back near the rear usb connection close to the CPU.
find the front audio cables form the front of the case.
there are two rows of pins.
. . . . 2 4 6 8 10
. . . . . 1 3 5 7 9
g31 has hi definition audio
1 is microphone L, 2 is ground, 3 is microphone R, 4 is ACZ-DET (can be left blank as well.)
5 is line 2 R, 6 is fsense1 (line return), 7 is faudio-jd (can be left blank), 8 has no pin at all, 9 is line 2 L, 10 is fsense2 (line return.
hopefully this has helped you.
please vote for me
Jan 18, 2011 | Intel Motherboard
My Emachine T 3626 i got new motherboard, new power supply.new cpu fan and now is not working , i conect everthing but the power lec and power sw dont come out the only way is to turn oof from the...
1) The eMachines T3626 uses an ESC MCP61SM-GM motherboard,
http://support.gateway.com/s//MOTHERBD/Shared/4006233R/4006233Rnv.shtml
Click on > Product Views
Now click on > P- Front Panel Connector
http://support.gateway.com/s/MOTHERBD/Shared/4006233R/4006233Rmvr18.shtml
Did you connect the cables, (Wires), from the Front Panel to the Front Panel Connector, correctly?
Looking at the Front Panel Connector, observe where it has > 2, at the bottom.
(Right above the small round object with the Orange dot in it)
This is the Bottom of the Front Panel Connector
The pins are in Two columns.
The column on the Right side is numbered > Even
The column on the Left side is numbered > Odd
Starting at the Bottom going Up on the Right side,
Pins 1, 3, 5, 7, and 9
Starting at the Bottom going Up on the Ledt side,
Pins 2, 4, 6, 8, and there is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive Activity LED light
B) Pins 5 and 7 are for the Reset switch. (IF one is used)
C) Pin 9 is for the 5+ power
D) Pins 2 and 4 are for the Power On LED light
E) Pins 6 and 8 are for the Power On switch
F) There is NO Pin 10
Let me know in a Comment.
Dec 01, 2010 | E-Machines eMachines Desktop PC
HOW TO CONNECT FRONT AUDIO PINS
the connector is marked F_audio and it is located directly behind the rear facing audio jacks. should be only one plug either marked "hd audio" OR "ac97 audio". some cases are setup for either, but you only need one of them depending on what your motherboard supports.
11) F_AUDIO (Front Audio Connector)
This connector supports either HD (High Definition) or AC97 front panel audio module. If you wish
to use the front audio function, connect the front panel audio module to this connector. Check the pin
assignments carefully while you connect the front panel audio module. Incorrect connection
between the module and connector will make the audio device unable to work or even damage it.
For optional front panel audio module, please contact your chassis manufacturer.
By default, the audio driver is configured to support HD Audio. To connect an AC97 front panel
audio module to this connector, please refer to the instructions on page 72 about the software
settings.
Pin No. Definition
1 MIC
2 GND
3 MIC Power
4 NC
5 Line Out (R)
6 NC
7 NC
8 No Pin
9 Line Out (L)
10 NC
AC'97 Audio:
Pin No. Definition
1 MIC2_L
2 GND
3 MIC2_R
4 -ACZ_DET
5 LINE2_R
6 FSENSE1
7 FAUDIO_JD
8 No Pin
9 LINE2_L
10 FSENSE2
Mar 27, 2010 | Gigabyte GA-945GM-S2 (0818313003065)...
Asus p5pe-vm front panel audio connector (10-1 pin FP_audio)
Nov 26, 2008 | ASUS P4S533 Motherboard
USB problem
please let me know what do u mean by one pin?
Apr 09, 2008 | ASUS K8V-MX Motherboard
Where is the audio output to front napel?
The ECS page is here;
http://www.ecs.com.tw/
Enter your model number in the search box and you'll be able to download the manual, which has the info you want.
Oct 15, 2007 | EliteGroup PT800CE-A Motherboard
Computers & Internet Logo
301 people viewed this question
Top Mach Speed Computers & Internet Experts
David
David
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
