Question about Harman Kardon Audio Players & Recorders
My Harman Kardon HKTS11 sub woofer just makes a loud 'thumping' noise every coule of seconds when the power is turned on and stays in standby. Any ideas?
SOURCE: Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Posted on Jan 27, 2007
simplemitch
  • 752 Answers
SOURCE: bose acousticmass 15 sub-woofer making a noise
The sub contains the amp for the other speakers. But it sounds like the amp has a seriously damaged section and will probably have to be serviced by Bose.
Posted on Aug 05, 2008
ravichetty
  • 158 Answers
SOURCE: The sub has a loud buzzing when turned on (harman
sounds like your audio stage is blown
Posted on Jul 22, 2009
SOURCE: Subwoofer continuous buzz/signal noise
I just bought mine yesterday and have the same problem... did you find a solution (other than throwing it out the window)?
Posted on Dec 27, 2009
  • 3 Answers
SOURCE: sub woofer produces a very loud low tone
I have the same problem. JavaMan is right. In one case someone even reported the bridge rectifier had failed. I have mine apart right now, trying to decide whether to attempt to fix it. The power board has been warped a little from the heat, and I can no longer read the color bands correctly on the power resistors to try to change them. Thanks for the schematics, JavaMan; unfortunately they don't match my boards, so I'm out of luck, and can't find anything else.
The components aren't expensive, so you might be able to take it someplace and have it repaired (or have a friend do it) fairly cheaply if the schematics here match your sub. I think I'm gonna chuck mine, which I hate to do since the speaker and cabinet are still good. I've just wasted too much time on it, and already have another in its place.
Posted on Feb 07, 2010
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
My sub ts7 won't power on
check the cable , might be it burned bcoz of the voltage fluctations.
If not check the transformer if its buzzing or not. if not- buzzing replace the power cord
Aug 08, 2012 | Harman Kardon HKTS 7 System
Hello, my Harman Kardon HKTS 15 sub woofer don'st work, the light that suppouse to turn from orange to withe when i turn on my receiver stay orange.could be the cable from my receiver to the sub...
It could be because of your subwoofer AMP is gone.
Temp fix: Disconnect the subwoofer wire from receiver for 20-30mins and plug-it back. It did work for couple of months.
Aug 22, 2011 | Harman Kardon Audio Players & Recorders
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
My HKTS 7 Sub woofer makes no noise,the led burns from amber to blue as normal,and every so often i hear a low rumble noise. The Sub is powered and has 1 cable to the receiver, the fuse is also good.
Subwoofer is center speaker from A+B speaker signals. first check your wire to the receiver. Otherwise you need electronics service on the amplifier inside the speaker.
Dec 04, 2010 | Harman Kardon HKTS 7 System
How to connect speakers to the sub-woofer and my iMac.
i believe that plug is special because it feeds not only audio signal but also voltage to power the speakers. so unless u know that the speakers will get power from the plug, it will probably not work
May 24, 2008 | Harman Kardon iSub Computer Speakers
135 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
