Question about Zanussi WJD1257S Front Load Washer
Zanussi error code e10
E10 error code on tumble dry cycle
SOURCE: e10 code on a zanussi jet system washer
E10 on Zanussi W/D
I had E10 on Zanussi W/D.
The machine would wash but not dry.
Changed the water inlet valve assembly.
All working again.
All credit to wildwest1959, thanks.
Posted on Apr 24, 2009
SOURCE: e10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Posted on Feb 21, 2010
SOURCE: zanussi zwd12270w1 error code e10 during drying
Error 10 is a low water pressure alarm.Check that the drain tube is clear and in the drain pipe correctly.Does it take a long time to fill.There could be a problematic pressure switch or hose to this switch,or faulty Inlet valve or even a faulty Circuit Board.
Hope this helps.
Posted on May 23, 2010
  • 713 Answers
SOURCE: Tumble dry problem
Posted on Jul 14, 2010
  • 28 Answers
SOURCE: I have a Zanussi washer
it could be the cold water solenoid not allowing much nedded water into the condensor unit... i would check both the hot and cold water feed if both ok and allowing free flow of water into the system have somebody check the poer to both the solenoids if they working ok and allowing water in then check the water pipe from the solenoid going to the condensor which should sit at the backof the machine if this is blocked ornot allowing water to the condenser unit for what ever reason than that could cause the error...i ope thiss is off help kv
Posted on Nov 27, 2010
My washing machine keeps stopping during its washing cycle and says fault E10
Thank you for your inquiry, Barbara Constable!
I see that your Electrolux washer is displaying an "E10" error code. "E10" stands for fill time too long you may want to check the hoses to make sure they are not restricted or kinked this could cause slow fill within your washer. If the hoses look to be in good shape then I would suggest it could be a faulty sensor or control panel. You could additionally reset your washer by disconnecting power from it for ten minutes. If you restore power and it continues to flash "E10" I would recommend having a professional out to properly diagnosis your washer. Hopefully this information is helpful. -Matt
Dec 21, 2014 | Electrolux Washing Machines
Error code e10 on zanussi zjd1219
E10 on the drying cycle normally indicates a failure to take in water during drying
this is usually a failure of the triple water valve unplug your unit take the top off you will see the valve at the rear of the appliance change out the water valve and you should be up and running again the service manual states that it could be the triple water valve , the wiring , or the main control board if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations Thanks Rick
Mar 23, 2011 | Dryers
Tumble dry problem
Jul 14, 2010 | Zanussi WJS1265W Front Load Washer/Dryer
My Zanussi ZWF14581 washing machine shows an error
The error code E10 is in relation to low water pressure.Have you checked that the hose at rear is not kinked or check the filters in the ends of the hose.Also make sure when you have hose off check the pressure in the supply.If all that is ok then it could be a faulty solenoid valve.
Hope this helps.
May 09, 2010 | Washing Machines
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore front load washer, model 417
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Oct 15, 2009 | Kenmore Washing Machines
ZANUSSI FJR1454 W WASHING MACHINE E10 ERROR . IT TAKES NEARLY THREE HOURS TO DO A QUICK WASH. IT BLEEPS AT LEAST 4 OR 5 TIMES THROUGHOUT A WASH CYCLE AND THE CYCLE COUNTER DOESNT SEEM TO COUNT DOWN...
Oct 10, 2009 | Washing Machines
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Zwd1471s washer dryer
E20 code on Zanussi washer dryer ZWD1471
washing machine working but dryer is not .
Any advice please
Mar 24, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
E10 error code
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJD1257S Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
