Question about Hotpoint Washing Machines
Hotpoint WMf760 very noisy when on fast spin
When the W/M is on 1600 spin it is very very noisy
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
abhishek33
  • 1239 Answers
SOURCE: very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Posted on Jul 12, 2009
  • 104 Answers
SOURCE: Bra wire stuck between inner and outer drum how to
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Posted on Jan 28, 2010
beltronic205
  • 1467 Answers
SOURCE: I have a Hotpoint WF540 washing machine. When it
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
Posted on Apr 21, 2010
marka19
  • 1430 Answers
SOURCE: The wash dial on my hotpoint wmf760 is not selecting
The knob needs to be removed and the knob and the mating part will need to be replaced. The teeth on these parts wear off with time. There is a clip on the back of the knob that pulls off this holds the knob on. Then the mating piece will pull out. Eneter your model # at www.appliancehelponline.com for diagrams and illustrations. All parts come with installation instructions.
Posted on May 03, 2010
Hotpoint wdpg8640 very noisy on fast spin, noise has increased in the last week. Should I be concerned?
yes very concerned it could be a loose weight or bearings failed both need attention asap.
Jun 26, 2014 | Hotpoint Aquarius WD640 Front Load...
I have 'somehow' removed the tension spring that holds my washing machine seal in place... and i cant get it back in place. HELP!!! The model is hotpoint wmf760.
If you are talking about the door seal spring clip and you have difficulty in getting it to slide back in it's grove use a bit of washing up liquid in the groove and the ring. Is it not adjustable?
Dec 30, 2012 | Hotpoint Washing Machines
Noisy on fast spin
NEEDS A NEW BEARING AND OILSEAL REPLACEMENT..U REQUIRE AN EXPECT.
Feb 24, 2012 | Hotpoint Aquarius WF215 Front Load Washer
When fast spinning my hotpoint aquarius has become very noisy, sounds like its grinding
it sounds like the bearings have gone bad try to look for repair parts for that washing machine
Jan 02, 2011 | Washing Machines
May 03, 2010 | Washing Machines
I have a Hotpoint WF540 washing machine. When it goes into fast spin, the spin cycle is quite noisy....on slow spin it is fine......could this be a bearing problem? If so how easy are they to replace?
Apr 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WMA20 will not fast spin
It is rare that it would be the bearings as there would be play in the tub, it would be noisy and would probably leak. There is a small electrical box in the bottom of the machine. This is the speed control for the motor. You will also find the wireing diagram in a plastic bag in this location. You can check to see which wires require current to activate the different speeds.
I hope this helps.
Dec 28, 2009 | Hotpoint First Edition WMA20 Front Load...
Drive belt on hotpoint wm56 keeps coming off when machine goes on fast spin. I have fitted a new belt but it still keeps happening.
Make sure belt is reasonably tight, and it is in the center of the drum pulley, if it still comes off, then I would suspect that the drum bearings are worn, or the drum is running out of alighnment, or the motor bearings are worn, if it is noisy when you spin the drum by hand, then the bearings have definately failed.
Please rate my solution.
Thanks.
Sep 22, 2009 | Hotpoint WM56 Front Load Washer
Door locking & drum noisy
It sounds as though the main drum bearings are failing, if you spin the drum by hand and it feels rough or sounds niosy, then it is definately the main bearings. there should be little or no noise when you spin the drum by hand.. Re the door lock,I do not think the two problems are related, could be a faulty door lock that is taking too long to release.
If the m/c is under 5 years old, then you should be able to get it put right under Hotpoint 5 year guarantee
You pay for labour, all parts are free, and in your case the cost of parts, would in excess of £100.00
So it would be worth a phone call to Hotpoint to confirm if you are covered.
Plz rate my solution,
Thanks.
Jan 05, 2009 | Hotpoint WMA64 Front Load Washer
Washing Machines Logo
209 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
