Question about Refrigerators
My freeze leaks into my fridge through two holes. the bottom of the freezer should i plug up these holes. the bottom of the freezer already has a lot of frozen woter in the the bottom of it.
  • 1 more comment
  • kdruss Jan 03, 2009
    I have water in the bottom of the refrigerator. Is there a drain line from the freezer that might be stopped up when defrosting? If so, how do I open it?
  • Anonymous Jan 03, 2009
    The vent slots in the ceiling of my Amana TZ21Q2L refrigerator leak a lot of water into the fridge compartment. This is quite frustrating, but I don't know how to fix it.
  • Floski Jan 03, 2009
    I am having the same problem with my amana TZ21Q2L refrigerator. Has been doing it for a long time and I'm tired of dealing with it. It leaks from the vent holes in the ceiling just inside the front left of the door.
Do not plug the holes, it would only cause it to leak elsewhere. The problem is that the drain is freezing, go to and order a kit to fix it. It is called a drain block kit or something like that
Posted on Mar 05, 2009
Maytag bottom freezer refrigerator, leaks from the bottom.
As with all electrical, before you touch make sure the power is off! Taje the plug out, and make sure it stays out! Tie a plastic bag around the plug! Now, empty the fridge and freezer, and defrost, you can use hot water bottles and gave the hearing on in te house, be careful using hair dryers, you can warp or crack the plastic inner housing of your fridge or freezer.
Check on you tube or the Internet it Manuel whee the drain hole is! Get a funnel and out boiling water down, just in case there is any ice here. Then with a piece of wire (old cable )prod clean this drain hole. Check the internal plastic of the freezer for cracks or damage, use a torch and your hand. If cracks or damage is visible, you are safer with a bee freezer! Remember water and electrics can be fatal!
Think safe, be safe, remember it could be your child or partner killed just by touching the freezer if the water and ekectrics are causing a short. If there is no damage or cracks then plug in, and jet the freezer freeze, check for Leaks, if you have no leaks then happy days! If you still have to the electrical shops...... But to save shoe leather and time, have a look online, write prices down, see what warranties you are getting. Good luck
Mar 19, 2016 | Maytag Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Leaks water inside from the ports or vents under freezer but in fridge
Your problem more than likely is a plugged defrost line in the freezer...The freezer goes through periodic defrost cyles to keep the coils from freezing up. The water catches in a trough pan in the freezer and flows through a drain hole to the bottom of the fridge where it evaporates. This drain hole perodically freezes up and the water accomulates under the freezer bottom until the water level reaches your vent ports to the fridge section. Open your freezer and on the bottom floor of your freezer you should see two screws near the front on either side. Remove them and then take out the bottom tray....this will expose the drain hole near the rear of the freezer compartment. You will more than likely have to remove ice under the tray in order to see the drain hole. Remove the lower back panel on the back of the refrigerator and you should be able to see the drain line coming from the freezer. Unplug the refrigerator before you begin work. It will take a little while for the drain line to thaw to allow liquid to flow to the bottom. I find a hair dryer pretty handy in speeding up the process. To verify you have unplugged the drain line you should be able to pour hot water in the drain hole in the freezer and see it come out at the rear of the fridge in tube line just above a little catch pan
Feb 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Water freezing in the bottom of freezer and leaking out on the floor from underneath
Defrost drain hole plugged - probably with ice. Defrost fridge, verify that you don't have something like a green bean stuck in the drain line. A piece of uninsulated solid copper wire wrapped around the defrost heater and run down that hole about 1/2" past the opening - MAKE SURE IT DOESN'T TOUCH THE TUBING OR CABINET LINER will prevent future freeze-ups.
Oct 25, 2009 | Refrigerators
Water pools at bottom of freezer, freezes and water leaks out
Hello, this sounds like you have a blockage in the drain tube, remove bottom shelf from fridge and remove the may see ice build up...melt ice with hair dryer/heat will see a pan below evaporator...melt ice in pan...dry water up in pan with paper you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Aug 31, 2009 | Freezers
Things freezes up in the refrigerator section of the home frige
If fridge is freezing, check the door seal on the freezer part. Make sure it is completely sealed, The freezer can leak air, allowing motor to pump freon continuously to fridge.
If the seal looks ok, try turning down fridge temp. If you have done this already, than I would look into having thermostat or thermometer sensor replaced.
Jun 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Freezing eggs in fridge area and freezing produce in crisper
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Frigidiare PLHS39EESS9 Ice build up in bottom of Freezer
I had the same problem with my Jenn-air side-by-side
Your freezer has a defrost cycle and when the freezer temp is set too cold, your drainage pan and tube freezes up (behind the back panels in the freezer) and when that gets full it spills over too the bottom of the fridge and keeps building up until you notice.
  • Un-plug fridge and put your food in coolers or another fridge.
  • Defrost the freezer, remove the ice from the bottom.
  • Remove the back panel/s (in the freezer).
  • Check the drainage pan. If it is iced up, you'll have to carefully remove the ice and check the drainage hole.
  • If the hole is iced up, so is the first 1-2 inches of the plastic tube leading to the main drainage pan behind and under the fridge.
  • You can use a hair drier to speed up defrost.
  • To defrost the hole and tube I used round ended metal (nut pics or beater attachment ends- avoid sharp objects) heated up in boiling water and gently forced down into the hole and tube until defrosted.
  • Check flow(by pouring warm water) down and looking behind and under fridge(with flashlight) to see if flowing into main drainage pan.
  • Turn up your freezer temp and check with a thermometer. Your freezer temp was probably set too cold
Mine is going on 5 months with no problem. If this continues, it might be the defroster.
Good Luck!
Mar 22, 2009 | Frigidaire PLHS39EESS Stainless Steel
Bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
