Question about Mazzer Coffee Makers & Espresso Machines
I have lost my instruction manual for Mazzer Luigi sri
I have lost my instruction manual and would like to replace it.
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Posted on Feb 28, 2009
mikey270
  • 26 Answers
SOURCE: how to change mazzer luigi srl "major" blades
Start by closing the hopper and grinding all the beans through the unit. Remove the hopper and look for any lock screws on the top of the adjustment collar (or ring). Remove the screws if present and turn the adjustment collar clock-wise (coarser) until it comes off. Pull out the upper burr holder. You then need to take out the three screws that hold on each burr (blades) and remove them. Then you want to use a shop vac to clean out all of the grounds. Make sure there is no coffee on the burr holders that could cause the new burrs to not be level. Assemble the new burrs on to the holders. Take a dry towel and clean the threads of the collar and the threads inside the mill. You don't want any coffee grounds on the threads, that could cause the adjustment collar to lock up and may damage the threads which can be extremely expensive. Use a small amount of lithium grease on the threads and reassemble. Screw the adjustment collar all the way down to where the burrs are touching. Then back it up 1.5 numbers (12-14 little bumps on the outer edge of the collar). This is a good "starting point". Pull some shots and adjust as needed.
good luck mike@espressomachineexperts.com
Posted on Dec 18, 2010
z34aga
  • 137 Answers
SOURCE: i have a mazzer luigi
grinding setting is one simple operation but requires a bit patience:
1 turn on your grinder and continue setting to fine while burrs are spinning, you stop when you hear metal to metal touch sound(burrs maximally closed finest ginding) 2 from that point go back quarter of revolution and mark the spot where you stopped with marker to body of grinder and setting plate with one line 3 grind little amount of coffee only to fill one sector of dosser than test it at your machine(if it leaks too fast and with yellow color of cream you should go to more fine>><< if it does not leak from the filter holder or it leaks very slow you go to in opposite way. 4 you test grinding few times bit after each reset of plate grind little amount and take that in one other pot (that will provide to have pure new granulation) 5 after setting measure the grinded coffee that come out from doser it should be about 7 grams, better measurement you can get if you measure 10 doses in one place because you don't get never same amount from 6 sectors of doser.
PS: the pump pressure of coffee machine should be from 8 to 10 bar and steam pressure should be from 1.1 to 1.5 bar> depends on type of coffees you use.
Posted on Feb 10, 2011
The digital screen says 2 and will not grind. What is the problem?
If no mention to failure diagnostics in your user's manual, you should contact MAZZER
You can fin contact information, eeven phone number, on websiter
Electronic on demand Mazzer grinder doser Robur Electronic
If you don't have a manual, check this link:
http://www.lamarzoccousa.com/wp-content/uploads/2014/03/Mazzer-All-E-Grinders-User-Manual.pdf
Aug 30, 2015 | Mazzer Robur Electronic Grinder
We have a Mazzer Super Jolly grinder and we can not get the dosing lever to move without pulling very hard while holding the machine with the other hand. Please help.
your doser mech is possibly gunked up with old grinds, first off try stripping it and cleaning it out, if that doesnt work you may need a new return spring but i think its far more likely to just need a good clean. this is from the mazzer mini but the doser design is pretty much the same so it should help you with disassembly
http://www.home-barista.com/grinders/mazzer-mini-component-photos-t3577.html
May 09, 2011 | Mazzer Coffee-grinder SUPER JOLLY Electric
How to change mazzer luigi srl "major" blades
Dec 18, 2010 | Mazzer Mini Burr Coffee Grinder
I have a mazzer luigi coffee grinder on which set is the best coffee you get
Nov 14, 2010 | Mazzer Coffee-grinder SUPER JOLLY Electric
How do you change a mazzer mini from timer to manual
Once you have an on/off switch you will remove the bottom panel ans timer, you will see 4 wires, 2 brown and 2 blue. Just make sure you connect brown to brown and blue to blue on the correct terminals. Use your Ohmsmeter to correctly match terminals.
Sep 02, 2010 | Mazzer Grinder-doser MINI
Lost our rules sheet for Zathura board game. How can we get another one?
1) is that the board game from the movie?
2) Where can I get one?
3)google instructions! Just put what is on the top cover word for word.
ex.Mario & Luigi
Partners in Time.
Apr 30, 2010 | University Games Staying Alive Murder...
Mazzer luigi super jolly
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
Mazzer Super Jolly Manual
Check out this link for the Super Jolly manual:
http://www.wholelattelove.com/manuals/Mazzer/Super%20Jolly%20Product%20Manual.pdf
Feb 19, 2008 | Mazzer Coffee-grinder SUPER JOLLY Electric
Coffee Makers & Espresso Machines Logo
76 people viewed this question
Top Mazzer Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Mazzer Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
